[ROM][I9300][7.1.2][NG][OFFICIAL][FINAL] **Resurrection Remix N Rom v5.8.5** [17.12.2017]
  • 475 Antworten
craP_cillA
craP_cillA
Dauer-User
569
Forum: Resurrection Remix
Website: Resurrection Remix - Android in all its Glory
XDA-Thread: [ROM][7.1.2_r29][i9300]RESURRECTION REMIX N [5.8.5][OFFICIAL]
Facebook: Resurrection Remix OS
Die Resurrection Remix N Rom basiert auf den CM / LOS, Slim, Omni & Original Remix Rom Builds.
Dies schafft eine wunderbare Kombination aus Leistung, Anpassungsmöglicheiten und den neuesten Features.
Viel Spaß mit der Rom!
Features:
Based On Latest Google Android 7.1.2_r29 Release
Based On Cyanogenmod 14.1 / Lineage OS 14.1 Sources
Resurrection Remix Crowdin: https://crowdin.com/project/resurrectionremix
RR Customizations
- Enable/Disable Navbar
- Navbar Button Customization smartbar
- Navbar Pulse
- Navbar Fling
- Double Tap To sleep navbar
- Statusbar
- Brightness Slider
- Enable/Disable Show Notification Count
- SuperUser Indicator Switch
- Double Tap To sleep Statusbar
- Carrier Label
- Carrier Label Switch
- Carrier label Color
- Carrier Label Size
- Clock Customizations
- Time & date
- Day & date Toogle
- Center/Right/Left Clock Choice
- Date Format
- Clock Font Styles
- Battery
- Battery Bar customization
- Battery Icon Customization (circle/landscape/Potrait and more)
- Battery % Text
- Network Traffic Indicator
- Network Traffic Arrows Switch
- Incoming/OutGoing Traffic
- Network traffic Color
- Statusbar RR Logo
- RR logo Color
- Position
- Custom Logos
- Logo Color
- Position
- Style
- StatusBar Weather
- Weather Color
- Weather Position (left/right)
- Weather Font Style
- Weather Size
- StatusBar Ticker
- Ticker Text color
- Ticker Icon Color
- Animations
- Toast Animations
- ListView Animations
- System Animations
- Power Menu Animations
- Misc Animations
- Gestures
- Gestures Anywhere Feature
- 3 Finger Swipe Screenshot Gesture
- App Circle Bar
- Choose apps in AppSidebar
- Trigger Width
- Trigger Hieght
- Trigger Position
- App Sidebar
- Choose apps in App circle
- Trigger Width
- Trigger Hieght
- Trigger Position
- Pie
- Pie Trigger (left ,Right ,Bottom)
- Pie Targets
- Pie Colors
- More Pie Features
- Recents Panel
- Clear All button Switch
- Clear All Tasks Switch
- Clear All Button Location (Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
- Full Screen Recents
- Recents Styles
- OmniSwitch
- Clock Widget
- Clock And Alarm Customizations
- Weather Panel Customizations
- Calender Events
- Lockscreen
- Lockscreen Bottom Shortcuts
- Lockscreen General Shorcuts
- 100+ Icons for Shortcuts
- Double Tap to Sleep Lockscreen
- Lockscreen Media Art/Enable Disable
- Quick PIN/Patter Unlock
- LockScreen Wallpaper
- Lockscreen Weather Widget
- Lockscreen Icons Color
- Quick Settings Draggable Tiles
- Customizable Tiles
- Dynamic Tiles Adjustment
- Number of columns/rows
- Tile Animations
- Notification Drawer
- LongPress Toogles to Enter Settings
- Disable Immersive Mode Messages
- Force Expand Notification
- Quick PullDown
- Smart Pulldown
- Notification Panel Transperency
- Volume Dialog Transperency
- Notification Panel Stroke
- Volume Dialog Stroke
- Buttons
- Backlight Timer
- Backlight Strength
- Advanced Reboot Menu
- Power Menu Customizations
- Power Off
- Reboot (Recovery, Bootloader, Hot Reboot)
- ScreenShot
- Power Menu End Calls Switch
- Restart SystemUI
- Airplane Mode
- ScreenRecord
- On the Go Mode
- Sound Panel
- Home Button (For devices with HW keys Only)
- Home Button answer call
- Long Press Actions
- Double Tap Actions
- Menu Button (For devices with HW keys Only)
- Short Press Actions
- Search Button (If Device Supports)
- Long Press Action
- Volume Buttons
- Wake Up Device
- Playback Control
- Ringtone Volume Control
- Keyboard Cursor Control
- Swap Buttons on Landscape mode
- Volume Key Answer
- Miscellaneous
- SElinux Switch (Switch Between Permissive and Enforcing SElinux if Device has SElinux Enabled)
- Clock Shortcut
- Disable Battery Saver Warning Color
- OTA UI
- Camera Shutter Sound Enable/Disable
- SystemUI Tuner
- Enabled By default
- Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
- StatusBar Icons Cuzomizations
- Quick Settings Customizations
- Other Features
- OMS (Overlay Manager Service)
Magisk
- Performance Profiles
- LCD Density
- Expanded Desktop Mode
- Heads Up Switch and customizations
- Live Display
- Configurable 0,90,180,270 Degree Rotation
- Lock Screen Autorotate Switch
- Native Tap to Wake From Marshmallow
- Double Tap Power Button To enable Camera gesture
- Prevent Accidental Wakeup
- Wake Phone on Charging Plug
- Battery Light Customizations
- Notification Light Customizations
- Font Size
- CM privacy guard
- Performance Tweaks (Kernel Aduitor Inbuilt)
- CM root inbuilt
- RR OTA
- A Whole new RR Configurations
- OverAll Smoothness Improvements
- Optimizations to Improve Battery
- Includes All Android Nougat Features
- Includes All CM / LOS 14.1 Features
- And Much, Much More....
Installation:
Erst-Installations-Anleitung:
- Ladet euch die aktuellsten RR Rom & GApps Versionen herunter und kopiert diese auf eure SD-Karte, danach:
- ins TWRP Recovery booten
- Backup anlegen und einen Full Wipe / Clean Flash ausführen
- Rom flashen
- GApps flashen
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
- Fertig!
Update-Anleitung:
- Backup anlegen und einen Dirty Wipe / Dirty Flash ausführen
- Rom flashen
- GApps flashen
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
- Fertig!
Downloads:
Reaktionen: pjozsef54, juwel, SGS-Ultra und 9 andere
Geht nicht. Bootloop beim Samsunglogo.
MfG
Reaktionen: funkenwerner
also bei mir funktionierts einwandfrei! ;) dachte auch erst das ich einen bootloop beim samsung-logo habe..aber das dauert beim ersten mal nur einfach "ewig" 15 minuten warens bestimmt bei mir..
hab da aber trotzdem ein problem: kann einfach nicht mit meinem wi-fi/router connecten, verbindung wird einfach nur gespeichert..wlan schlüssel ist aber korrekt! hat das noch jemand der die rom geflasht hat??
kamera funktioniert bei mir auch nicht, aber das ist kein problem, werde eh open camera nutzen! :)
edit: problem gelöst! :D also falls ihr auch wi-fi probleme haben solltet, einfach die neueste boeffla-kernel build flashen! :)
Reaktionen: Sunny und funkenwerner
@waldyman
Wenn du mit beiden Roms keinen Erfolg hast, es bei anderen aber funktioniert muss der Fehler bei dir liegen.
Da du mit Infos nicht gerade um dich schmeißt wird es schwer dir zu helfen.....
LG
Sunny76
Reaktionen: waldyman
neue build online:
-Battery Bar Colors
-Battery Bar Gradient and Charging Colors
-Fix Selinux Switch onboot
-Improve QS tile layout settings and mechanism
-Fix Mouse Pointer Speed Crash in Settings-
-Remove RR wallpapers as prebuilt. Rom zip is much smaller now
Also,die neue Build geht auch nicht. Nach 45 min immer noch Samsung Logo. Beim Flaschen erscheint im TWRP eine rote Zeile "E: unknown command". Vielleicht hat das ja irgendwas damit zu tun.
MfG
ja den fehler hatte ich auch...hat sich aber nicht negativ aufs booten ausgewirkt. welche gapps flashst du?!
Arm 7.1 pico
MfG
open gapps also? hm ich hab die mini geflasht und wie gesagt keine probleme mitm booten, wirklich helfen kann ich dir da leider nicht, warte einfach noch ein paar builds ab und probiers dann! :)
So,habs jetzt. Habe mal den Boeffla Kernel gleich mitgeflasht und sieh mal an es läuft. Werde jetzt mal alles testen. Dank an die Macher und eure Hilfe.
MfG
Reaktionen: funkenwerner und craP_cillA
na siehste! :)
bei Android 6 bin ich wie folgt vorgegangen:
  1. Resurrection Remix OS
  2. Open GApps (ARM, pico)
  3. Xposed
  4. Wipe Cache & Dalvik Cache
  5. Neustarten
  6. Boeffla-Kernel
  7. Neustarten
gilt diese Installationsreihenfolge weiterhin für Android N oder muss ich den Schritt "Wipe Cache & Dalvik Cache" am Schluss ausführen?
Ist es möglich von Android 6 direkt zu updaten oder muss man bei diesen "größeren" Versionssprüngen neu aufsetzen?
Ist doch in der Anleitung zum flashen der Rom von @craP_cillA
wunderbar beschrieben. Wenn du alles nach dieser Anleitung machst wird alles klappen.
LG
Sunny76
Reaktionen: DynOMIk und funkenwerner
die Anleitung hab ich selbstverständlich gesehen. Mir ging es hauptsächlich um den Boeffla Kernel. Für die Installation des Boeffla-Kernels war in Android 6 ein Neustart notwendig. Im Beitrag #10 jedoch erwähnt, dass dieser gleich mitgeflasht wurde.
andere flashen ihn gleich mit, ich machs so wie immer ;) und ja clean flash wird definitiv empfohlen.
Also ich komme bis Patching System Image danach folgt der Fehler mit E:unknown command
@sun110
E:unknown command ist weder ein Fehler noch beeinflusst es die Installation.
Hast du alles genau nach Anleitung gemacht?
Alles genau nach Anleitung. Backup erstellt usw. Doch nach dem Fehler Installiert der nicht sondern das war es dann. Warum auch immer :(
@sun110
Du hast eine Aktuelle Recovery drauf?
Falls ja, könntest du nochmals vor dem flashen 1 oder besser 2 mal kompletten Whipe machen. Dann erst die Rom und anschließend die Google Gaps.
Sollte es dann immer noch hängen bleiben (gib ihm Zeit!!)
Würde ich die System Partition nochmal komplett neu formatieren und anschließend nochmals neu flashen
LG
Sunny76
Wenn da E: für Error steht, ist das schon ein Fehler. Das heißt aber einfach das die Zeile / der Befehl nicht ausgeführt werden kann, es sollte dann einfach mit dem nächsten Befehl weiter gehen. Das kann nur ein Löschen von störenden Teilen sein, wenn er dann nichts findet, wirft es einen Fehler, macht aber nichts. Es kann aber auch etwas schwerwiegenderes sein, 'E:unknown command' ist schon etwas merkwürdig. Bist Du Dir sicher das Du auch eine richtige Recovery verwendest? (Könnte eventuell auch eine veraltete Version von TWRP sein.)
Reaktionen: arrotty
html6405
Verci
V
html6405
html6405
html6405
BenLue
BenLue
BenLue
