[ROM][I9300][6.0.1][MM][OFFICIAL] **Resurrection Remix M Rom v5.7.4** [20.09.2016]
  • 197 Antworten
craP_cillA
craP_cillA
Dauer-User
569
Forum: Resurrection Remix
Website: Resurrection Remix - Android in all its Glory
XDA-Thread: [ROM][6.0.1_r66][i9300]RESURRECTION REMIX M [UBER-GCC 4.9][CM13]
Facebook: Resurrection Remix OS
Die Resurrection Remix M Rom basiert auf den CM, Slim, Omni & Original Remix Rom Builds.
Dies schafft eine wunderbare Kombination aus Leistung, Anpassungsmöglicheiten und den neuesten Features.
Viel Spaß mit der Rom!
Features:
Based On Latest Google Android 6.0.1_r66 Release
Based On Cyanogenmod 13 Sources
RR Customizations
- Navigation Bar
- Enable/Disable Navbar
- Navbar Button Customization
- Navbar Slim Dim
- Animate Dim
- Dim Timeout Duration
- Dim Alpha
- Double Tap To sleep navbar
- Navigation Bar left/Right handed mode Switch for landscape
- Statusbar
- Brightness Slider
- Enable/Disable Show Notification Count
- SuperUser Indicator Switch
- Double Tap To sleep Statusbar
- Carrier Label
- Carrier Label Switch
- Carrier label Colour
- Carrier Label Size
- Clock Customizations
- Time & date
- Clock Colour
- Day & date Toogle
- Center/Right/Left Clock Choice
- Date Format
- Clock Font Styles
- Battery
- Battery Bar customization
- Battery Icon Customization (circle/landscape/Potrait and more)
- Battery % Text
- Network Traffic Indicator
- Network Traffic Arrows Switch
- Incoming/OutGoing Traffic
- Network traffic Color
- Statusbar RR Logo
- RR logo Color
- StatusBar Weather
- Weather Color
- Weather Position (left/right)
- Weather Style
- Weather Size
- Animations
- Toast Animations
- ListView Animations
- System Animations
- Gestures
- Gestures Anywhere Feature
- 3 Finger Swipe Screenshot Gesture
- App Circle Bar
- Choose apps in AppSidebar
- Trigger Width
- Trigger Hieght
- Trigger Position
- App Sidebar
- Choose apps in App circle
- Trigger Width
- Trigger Hieght
- Trigger Position
- Pie & Pie Trigger (left ,Right ,Bottom)
- Pie Targets
- Pie Colors
- More Pie Features
- Recents Panel
- Clear All button Switch
- Clear All Tasks Switch
- Clear All Button Location (Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
- Recents Search Bar
- Full Screen Recents
- Slim Recents
- OmniSwitch
- Clock Widget
- Clock And Alarm Customizations
- Weather Panel Customizations
- Calender Events
- Lockscreen
- Lockscreen Bottom Shortcuts
- Lockscreen General Shorcuts
- 100+ Icons for Shortcuts
- Double Tap to Sleep Lockscreen
- Lockscreen Media Art/Enable Disable
- Quick PIN/Patter Unlock
- LockScreen Blur
- Lockscreen Blur Intensity
- LockScreen Wallpaper
- Lockscreen Weather Widget
- Lockscreen Icons Color
- Quick Settings Draggable Tiles
- Customizable Tiles
- Show Two Main Tiles Per Row
- Dyanamic Tiles Adjustment
- Notification Drawer
- Weather Display Switch
- LongPress Toogles to Enter Settings
- Disable Immersive Mode Messages
- Force Expand Notification
- Task Manager Switch
- Time Contextual Header (HD,Modern,Poly)
- Quick PullDown Switch
- Buttons
- Backlight Timer
- Backlight Strength
- Advanced Reboot Menu
- Power Menu Customizations
- Power Off
- Reboot (Recovery, Bootloader, Hot Reboot)
- ScreenShot
- Power Menu End Calls Switch
- Restart SystemUI
- Airplane Mode
- ScreenRecord
- On the Go Mode
- Sound Panel
- Home Button (For devices with HW keys Only)
- Home Button answer call
- Long Press Actions
- Double Tap Actions
- Menu Button (For devices with HW keys Only)
- Short Press Actions
- Search Button (If Device Supports)
- Long Press Action
- Volume Buttons
- Wake Up Device
- Playback Control
- Ringtone Volume Control
- Keyboard Cursor Control
- Swap Buttons on Landscape mode
- Volume Key Answer
- Miscellaneous
- SElinux Switch (Switch Between Permissive and Enforcing SElinux if Device has SElinux Enabled)
- Clock Shortcut
- Disable Battery Saver Warning Color
- Disable Fc Notifications
- Wakelock Blocker
- Media Scanner On Boot Behaviour
- Camera Shutter Sound Enable/Disable
- SystemUI Tuner
- Enabled By default
- Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
- StatusBar Icons Cuzomizations
- Quick Settings Customizations
Other Features
- Performance Profiles
- LCD Density
- Expanded Desktop Mode
- Audio FX
- Heads Up Switch
- Live Display
- Configurable 0,90,180,270 Degree Rotation
- Lock Screen Autorotate Switch
- Native Tap to Wake From Marshmallow
- Double Tap Power Button To enable Camera gesture
- Prevent Accidental Wakeup
- Wake Phone on Charging Plug
- Battery Light Customizations
- Notification Light Customizations
- Font Size
- CM privacy guard
- Performance Tweaks (Kernel Aduitor Inbuilt)
- RR OTA
- CM Theme Chooser
- OverAll Smoothness Improvements
- Optimizations to Improve Battery
- Includes All Android Marhsmallow Features
- Includes All CM 13 Features
- And Much, Much More....
Installation:
Erst-Installations-Anleitung:
- Ladet euch die aktuellsten RR Rom & GApps Versionen herunter und kopiert diese auf eure SD-Karte, danach:
- ins TWRP Recovery booten
- Backup anlegen und einen Full Wipe / Clean Flash ausführen
- Rom flashen
- GApps flashen
- SuperSU oder Magisk flashen
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
- Fertig!
Update-Anleitung:
- Backup anlegen und einen Dirty Wipe / Dirty Flash ausführen
- Rom flashen
- GApps flashen
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
- Fertig!
Downloads:
Reaktionen: Black_Focus, Holomen, SaschaKH und eine weitere Person
Wie schlägt sich die ROM im direkten Vergleich zu der CM13 ROM von forkbomb? Schon Erfahrungen gesammelt? Besser, schlechter oder gleich gut? Wie ist hier der Entwicklungsstand?
Also es gibt natürlich mehr Einstellmöglichkeiten. RR halt ;-)
Läuft genauso flüssig wie die cm13. Allerdings ist hier der PUK bug vorhanden. Ich habe jez erstmal die sim sperre raus genommen. Aber eine richtige Lösung ist das nicht. Ansonsten top Rom. Fehlen noch ein paar Sachen die man von der RR Lollipop Rom kennt aber das kommt sicher noch
Bearbeitet von: hagex - Grund: Direktzitat entfernt
Geht nicht. Egal ob dirty oder clean. Immer Bootloop.
MfG
Ich hab keinerlei Probleme. Schon bei der ersten Build nich
So, ich bin erstmal wieder auf der CM13 Build7, da mir RR 5.6.0 nicht flüssig genug läuft. Gestern ist es drei Mal infolge eingefroren und dann neu gestartet. Ich warte auf die nächste RR Version
Habe gestern abend mal wieder RR geflasht. Dieses mal komplett clean.
- Nicht aktuell (logisch da CM Nightlys jeden Tag kommen)
- Läuft bislang ohne einzufrieren oder zu ruckeln
- Hatte bis jez nicht ein einziges Mal "das Bildschirm Flackern"
Das ganze läuft in Verbindung mit Boeffla 5.0 Beta2, Viper4Android, Xposed v79 und SuperSU Beta 2.64
Ich muss sagen das ich mit der ROM vom 13.12.15 die wenigsten Probleme habe. Allerdings funktioniert da nicht alles. Zum Beispiel den das recorden vom Desktop
Mit der ROM vom 15.12.15 hab ich so meine Probleme. Entweder ich bekomme angezeigt das die su-Bin aktualisiert werden muss und wenn das erledigt ist habe ich einen bootloop oder ich habe, nach dem ich installiert habe, gar kein root und kann es auch nicht abändern durch flashen der supersu übers Recovery.
Das jeweils mit fullwipe.
Wenn ich mich an die Updateanleitung halte scheint es zu gehen. Muss ich aber noch testen.
Update (22.12.15): Ich habe es zwar installiert bekommen, aber die Version vom 15.12 läuft doch sehr harkelig gegenüber der vom 13.12 bin deshalb wieder zurück.
Version 5.6.1 ist erschienen!
ResurrectionRemix-M-v5.6.1-20160111-i9300.zip :: BasketBuild Download
Changelog
Changelog:
ResurrectionRemix - v5.6.1 - Marshmallow 6.0.1_r10 :-
Add Screencast by default
Theme chooser : Update theme to stock material look
SystemUI : SystemUI Tuner settings modifications
QS: Gesture Anywhere Tile
SystemUI: Add longpress action for TaskManager button
Base : Update default material popup animations
FWBase: Add 7 more power menu animations
[WindowManagerService] fix starting window issue
Qs: systemUI Restart Tile
QS:Add App SideBar Tile
Update private copy of Palette
Navigationbar: Add just one more button
QSpanel: few new vector drawables
SystemUI: Expose Add Tiles DetailedView Title and Icon Color
fix setting new encryption password
Base:Add Option to Disable Brightness Icon In Brightness Slider
base: add CPU info overlay
base: app notifications hide when locked
Reset battery stats
QSBrighnessIcon: Make it show in notification panel
base: add auto brightness toggle to qs
Fw_base - Proximity speaker
Themes tile
QS: add headsup tile
SystemUI:Add LTE Tile
SystemUI : Add RR Configurations Tile
Themes: Re-enable changing keyguard wallpaper
QSpanel: Fix FC when adding New Tile
CamcorderProfile: Add 1440p camcorder profile
SystemUI: Fix statusbar clock font size at times not updated on boot
Live Volume Steps
Max Lockscreen Notification count
SystemUI: fix flicker when removing tiles
SystemUI: add tiles detail view
FWB: Add clock/date in recents while in fullscreen mode
FEB: Disable/Enable screenshot sound
Lockscreen Clock Widget Fonts
Launch app privacy settings when tapping on PG notification
network tile: Change long click action
Show 4G intead of LTE switch
Do not start music app when headset is unplugged
Themes: Expose hard code for themes
Dotted circle battery
IME animations
NavBar: add power button
Slim Recent App Sidebar
Add SlimRecents
Add Battery Saver QS Tile
Reboot/Recovery QS Tile
Add Music QS Tile
Quick Settings: add some more tiles
Themes: Expose hard code color for divider sim pin
Themes: Expose Hard coded colors in Quick Settings Tiles
Rotation anim to Power and reboot menu
Power Menu animations
SlimDim performance boost
NavigationBar : Switch to display orientation from config orientation
PowerManagerService: Log when proximity blocks wake
Add custom camera shutter
Lockscreen shortcuts improvements
Make user avatar long clickable
Frameworks: Slim doze options
Add Vibrate on long press Header Buttons
Status bar header long click actions
SystemUI: use new visualizer from Eleven
LockscreenToggleTile
Services: DO NOT send Broadcast On boot
Frameworks: Remove duplicated audio files
SystemUI : Fix perf profile tile index calculation
SystemUI : Add location tile from 12.1
Navbar on/off and custom dimensions
SystemUI: fix tile pages not filling up
FWB: Hold back to kill timeout
FWB: PIE: Always on the right switch
Update contextual headers per original from Omni
New contextual header images
Fix other minor issues
Performance improvements
Reaktionen: funkenwerner
Benutzt eig jemand diese tolle Rom? Hab sie jetzt seit dem Update auf die neue Version laufen und bin sehr zufrieden. Gute Akkulaufzeit, keine freezes oder reboots. Läuft flüssig und ne Menge Einstellmöglichkeiten
leider hänge ich im bootloop
clean geflasht: aktuelle Rom, open_gapps-arm-6.0-full-20160122.zip und BETA-SuperSU-v2.67-20160121175247.zip
verwende ich ein falsches file?
LG
Hallo. An den files liegt es nich. Hast du eine saubere Installation versucht? Dalvik und cache gewiped nachm flashen?
mit twrp aktuelle version gewiped: cache, dalvik, system, data, sogar interen storage und nach dem Flash wieder
cache und dalvik
kann es am Kernel liegen,
sei so nett und leg mir mal den link für den Kernel
LG
Findest du im start-post
Ich denke gerade wenn man Probleme hat, sollte man nicht auch noch anfangen mit anderen Kerneln zu experimentieren. Klar kann ein anderer Kernel Vorteile bringen, aber gerade am Anfang sollte man doch erst mal beim mitgelieferten Kerner bleiben. Wenn die ROM dann gut läuft, kann man mit den Experimenten anfangen.
just my 2c
Version 5.6.2 ist erschienen!
https://basketbuild.com/filedl/devs...ResurrectionRemix-M-v5.6.2-20160124-i9300.zip
Changelog
#ResurrectionRemix - v5.6.2 - 20160123
- Revert Fix protected apps implementation (Fixes setup wizard fc)
- DisplayMetrics: set noncompat DPI as well
- Dashboard tileview double lines toggle
- FWB: Power/reboot menu transparency
- FWB: Volume dialog transparency
- FWB: QS header transparency
- SysUI: Recreate volume dialog on theme change
- Update adb tile drawable
#ResurrectionRemix - v5.6.2 - 20160122
- Rework and fix navigation bar layouts + buttons
- Notifications: Custom colors
- FWB: QS shade transparency
- Notification Colors Switch
- Hide Multi Window Again ( Causes system UI freezes )
- Update notification and power navbar drawables
- SysUI: Fix notification panel alignment after theme change
- SysUI: Clean up objects when recreating statusbar
- Themes: Fix applying theme for notifications
- SysUI: Pass themed resources on to NavBarEditor
- SystemUI: Add battery saver tile
- Notification drawer: Custom clear all icon color
- Framework: safe headset volume option
- Remove system ui tuner settings
- Change to 12hr clock
- long press torch tile to open camera
- Longpress power lockscreen torch
- Immersive Recents
- Keyguard: set separator for multi-sim CarrierText
- pm: Add persist property to enable lazy dexopt
- SystemUI: fix qs tile page regressions
- Add left QS quick pulldown
- SystemUI: Screenshot rotation
- Screenrecord: save screenrecord in "Screenrecords" directory
- Add a timer to screen record
- FWB: Battery saver and low battery notification toggles
- Less notifications sound
- SystemUI: fix disappearing tiles
- SystemUI: fix tiles per page when changing top tile type
- SystemUI: fix viewpager page recycling
- Paella: Enable Spanish single shift table
- Configurable dashboard columns
- Breathing missedcall/voicemail
- fix race condition between HWUI cache and renderThread
- SysUI: Guard against NPE in SignalClusterView
- SysUI: Check that backgrounds are RippleDrawables
- Add enabled pre-installed carrier apps
- SystemUI: fix lock screen tile state refresh
- SystemUI: handle custom tile long press PendingIntents
- SystemUI: improve qs tile layout mechanism
- base: correctly save app notification config
- Themes: Call recreateTheme when theme changed
- SysUI: Fix keyguard wallpaper not updating
- Change carrier label default font style condensed
- Reduced carrier label default font size
- Disable Quick Settings on secure lockscreen
- SystemUI: Make lockscreen visualizer battery friendly
- SysUI: Re-add status icons in recreateStatusBar()
- Have Battery bar controller obey Hide value
- Frameworks: Slim Shortcuts
- Fix WallpaperCropper crash when setting wallpaper over 8MB
- base: fix num cpu check for CPU overlay
- Add IME Switcher icon back into the statusbar
- Reduce log verbosity: Don't spam logcat
- Turn advanced devices and file sizes on by default
- SystemUI: Fix NPE
- Animate backlight quickly when display state request to change or power
- FWB: Make all 18 font variants available to Statusbar weather temp
- FWB: Make all 18 font variants available to Statusbar Clock
- SystemUI: Removing padding on mobile signal group.
- Ringtone: Add support for selection of phone ringtone for SIM-2.
- Update translations
- Update Turkish language
- Fix other minor issues
wo finde ich die gapps für die V5.6.2-20160124-i9300
Du solltest mal den Thread lesen bevor du was postest...
Im start-post, wie immer!
Reaktionen: SaschaKH, Holomen und funkenwerner
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
