[ROM][I9300][5.1.1_r26][LP] Resurrection Remix 5.5.9 Final [20.11.2015]
  • 199 Antworten
Black_Focus
Black_Focus
Dauer-User
622
So, dann stelle ich hier mal die Resurrection Remix Rom rein. Und zwar die aktuellste Lollipop, in dem anderen Thema geht es um die ältere KitKat Version.
Quelle: Resurrection Remix Downloads
Forum: Resurrection Remix
XDA: [ROM] [5.1.1_r3][FULL-O3][i9300] RESURRECTIO… | Samsung Galaxy S III I9300, I9305 | XDA Forums
Das Resurrection Remix ROM basiert aus den CM12.1,slim.omni und original Remix ROM builds. Dies schafft eine wunderbare Kombination aus Leistung, Anpassungsmöglicheiten und den neusten Features.
Features:
-Navigation Bar
-Enable/Disable Navbar
-Navbar Ring Switch
-Navbar Ring Targets
-Navbar Button Customization
-Navbar Dimensions(Potrait & Landscape)
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Quick PullDown Switch
-Smart Pulldown Switch
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center Clock/Right Clock Choice
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Theme Chooser
-RR exclusive PITCH BLACK THEME
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Gestures
-Gestures Anywhere Feature
-App Circle Bar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Shortcuts
-Choose upto 5 Shortcuts
-100+ Icons for Shortcuts
-Quick Slider Shortcuts
-Notification Drawer
-Weather Display Switch
-Quick Settings
-Choice to Add 20+ Tiles
-Enable 2/3/4 Tiles per Row
-Enable Disable Birghtness Slider in Notification Panel
-Advanced Location Settings Switch(Choose Battery saving/Device Only/High Accuracy Directly in Notification Panel)
-LongPress Toogles to Enter Settings
-Buttons
-Backlight Timer
-Backlight Strength
-Navigation Bar left/Right handed mode Switch
-Power Menu
-Power Menu End Calls Switch
-Home Button(For devices with HW keys Only)
-Home Button Wake Up
-Home Button answer call
-Long Press Actions
-Double Tap Actions
-Back Button(For devices with HW keys Only)
-Wake Up device Switch
-Menu Button(For devices with HW keys Only)
-Wake Up Device Switch
-Short Press Actions
-Long Press Actions
-Search Button(For devices with HW keys Only)
-Wake Up Device
-Short Press Action
-Long Press Action
-Volume Buttons
-Wake Up Device
-Playback Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-All New CM Audio FX App
-Heads Up Customizations
-OverAll Smoothness Improvements
-Quick Unlock
-Optimizations to Improve Battery
-ALL cm12 Features
-AND MUCH MUCH MORE
Screenshots
Installations-Anleitung
Ladet euch die aktuelle Rom und die Gapps herunter und kopiert diese auf eure SD-Card
dann
1. ins vorhandene Recovery booten
2. Backup anlegen und Full Wipe und Factory Reset ausführen
3. Rom flashen
4. Gapps flashen
5. Neustart
6. alles einrichten
Update Anleitung
- Download der aktuellsten Resurrection ROM und kopiert diese auf eure SD-Karte
- Reboot ins Recovery (z.B. TWRP)
- Erstellt ein nandroid backup
- Flasht die ROM
- Flasht die Gapps
- Wipe cache
- Wipe dalvik cache
- Reboot
- Fertig
Changelog
Downloads:
Rom: downloads for Samsung Galaxy S 3 by varund7726 | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
GApps: [GAPPS][DAILY] Open GApps for Android 5.1,5.0,4.4; arm,arm64,x86,x86_64
PitchBlack-Themes: https://play.google.com/store/apps/developer?id=Altan+KRK+(westcrip)
Boeffla-Kernel: Boeffla-Kernel Download
Boeffla-Kernel-Profil (empfohlen): [Unofficial] Boeffla Kernel Profile Sharing Thread - Post #1506 - XDA Forums
Xposed für Android 5.1.1 [Unoffocial]: [UNOFFICIAL] Xposed for Android 5.1 - v68 / 20150727 / SDK22 - XDA Forums
[Für das Galaxy S3 GT-I9300 immer die "sdk22-arm" nehmen! Nicht arm64 oder x86!]
Xposed für Android 5.1.1 [Official]:
[OFFICIAL] Xposed for Lollipop [Android 5.0/5.1, v75, 2015/10/07] - XDA Forums
Reaktionen: det-happy, knorke007, Cytronic und eine weitere Person
Danke für die Vorstellung der Rom.
Funktioniert die manuelle Netzwerksuche?
Wie oft gibt es updates?
Was funktioniert nicht wie es sollte.
Wäre schön ein paar Informationen darüber zu erhalten.
Also die Netzwerksuche funktioniert. Hab ich grad getestet.
Updates gibt es, wenn ich das richtig sehe meist alle ein bis zwei Wochen!
Ich will ja ehrlich sein: Bin leider noch nicht so sehr in der Thematik drin, weswegen ich deine letzte Frage nicht wirklich beantworten kann.
Ich habe das Problem, dass ab und an mal der Bildschirm schwarz wird und (ich denke mal) die ganze SystemUI neugestartet wird. Kann aber auch an was anderem liegen.
Ansonsten muss ich mal in den XDA Thread gucken, ob da was drin steht
Also ist es möglich den Mobilfunk Anbieter manuel auszuwählen.
Die Liste mit Vodafone, Telekom, O2 ist vorhanden?
Bildschirm schwarz?
So mitten drin beim benutzen oder nur nach Neu starten.
Nutzt du Boeffla Kernel und wenn ja, die alpha3 oder alpha4?
Oh hatte ich wohl falsch verstanden sorry.
Beim Suchen des Netzwerkes kommt immer "Fehler bei der Netzwerksuche"
Bildschirm schwarz mittendrin ja. Aber nur selten.
Ja nutze Boeffla Alpha 4.
Ah ja, okey.
Das ist dann wohl doch ein CM 12.1 bug der durch alle Roms geht.
Aber gut zu wissen das alpha4 läuft.
Tut mir leid, dass ich da noch nicht so die Ahnung von habe. Ich dachte nur, ich stelle die Rom hier rein, da ich sie auf meinem Z2 auch habe und ich sie echt sehr gut finde. Und der andere Resurrection Thread ist ja sehr veraltet
Ist ja auch in Ordnung.
Wollte nur mal nachfragen.
Habe zur Zeit die Bliss Pop am laufen und da geht Netzwerk suche auch nicht.
Hab seit über ner Woche RR 5.4.4 mit SlimZero Gapps und Boeffla alpha3 (ZaneZam) auf meinem S3. Meines erachtens ist ResurrectionRemix zur Zeit das beste Rom mit den wenigsten Bugs. BlissPop hab ich auch ne ganze Weile getestet, aber da ist CastleVille Legends (sehr viel RAM-Verbrauch) fast unspielbar mit vielen FCs. Bei RR läuft das Spiel einwandfrei ohne bugs/FCs. Die RR 5.4.5 hab ich allerdings noch nicht ausprobiert..
@Black Focus
Der andere Thread war Up2date, er enthält die 4.4.4 Version die es von RR auch noch gibt, wie von vielen anderen ROM´s auch.
Und die letzte Final Version von RR erschien im Dezember, weil RR danach die ersten waren die sich an LP trauten im Dezember.
In dem Changelog den du gepostet hast steht auch in den letzten Zeilen: " -all CM12.1 Sources Updated"
Nicht böse gemeint nur eine kleine Anmerkung :)
Aber schön das die ROM jetzt auch hier angekommen ist.
Reaktionen: Black_Focus
Sorry das hab ich wohl übersehen!
Nur was das mit dem CM12.1 Sources updated zu tun hat versteh ich nich.
War nur eine Bemerkung falls du den Changelog durchgelesen hast hättest du es daran erkennen können :)
Aber genug OT.
RR ist einer der ersten ROM's unter LP gewesen und wirklich Top. Von der Leistung und Akku Performance wirklich gut im Gegensatz zu anderen ROM's. Bin zwar momentan nicht auf Ihr, aber wer mit der Entscheidung ringt sie zu flashen, tut es! :)
Hallo hat einer die Rom RR 5.4.5 schon drauf und mal ausgiebig getestet? :thumbup:
Hallo Zusammen, ich kann leider keine Gapps installieren. Ständig bricht die Installation ab. Was kann ich machen, oder wer kann mir einen Link senden?
Vielen Dank für Eure Hilfe
recovery updaten..siehe startpost liegt mit hoher wahrscheinlichkeit daran.
Ich habe die angegebenen Links auf der ersten Seite benutzt. Alles heruntergeladen auf SD Card. Dann die RR-Rom installiert. Hiernach die Gapps 5.1 pico und später die etwas größere Version. Als Fehler kommt Nr. 6
@ craP_cillA: bin ein "Fast" Beginner. Wie aktualisierte ich die recovery?
Also ich habe alles mit den Links der ersten Seite installiert. Ohne Probleme! Ich hab TWRP 2.8.6.1
So, habe das twrp geladen. Nun klappt es mit den gapps. Sorry, wenn ich mich nicht so gut auskennen. Momentan aktualisiert der Playstore meine Apps.
Danke!!!!
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
