[ROM][I9300][5.1.1][LP][BOSP][OFFICIAL] **BlissPop Rom v4.0.3** [12.12.2015]
  • 2.198 Antworten
Neue Version vom 25-06-2015
md5sum = 47386140237f1cb45fd8cfd9588fc4bd
Changelog
06-25-2015
* android/
d380399 Manifest for Android 5.1.1 release 5
* device/moto/shamu/
712e27b stick with these chains till i can try out new ones
* device/qcom/sepolicy/
6a2a0b7 sepolicy: Allow time_daemon to use POSIX clocks
* external/android-visualizer/
38d5cf3 VisualizerView: add ability to disable drawing
fc9b944 Revert "visualizer: don't draw fade out paint when there's no content"
* frameworks/base/
2fc41d5 Fingerprint: Make the existing FingerprintService semi-useful.
4fb774f Merge "Merge "Fix filedescriptor leakage in MediaMetadataRetriever"" into lp5.1
225c77b Merge "Fix filedescriptor leakage in MediaMetadataRetriever"
5fefb62 Merge "alarmmanager: Reduce calls to elapsedRealtime()" into lp5.1
212cb31 Merge "SystemUI: visualizer state improvements" into lp5.1
21628ee Merge "Remove some useless code in KeyguardUpdateMonitor." into lp5.1
c5cbf66 Merge "Optimize GPS property reloading." into lp5.1
c8544f6 Merge "Add sms short codes for Indonesia" into lp5.1
a80018a alarmmanager: Reduce calls to elapsedRealtime()
d97d952 SystemUI: visualizer state improvements
9a871c7 Remove some useless code in KeyguardUpdateMonitor.
018f24e Optimize GPS property reloading.
963295d Add sms short codes for Indonesia
* frameworks/native/
780991e surfaceflinger: use Mutex timedLock instead of tryLock loop
4a8106d SF: Reduce resync samples without present
* frameworks/opt/telephony/
dbf28fa Send out a new SPN_STRINGS_UPDATED broadcast if the sub ID changes.
2653937 Revert "SystemUI can not receive intent"
* hardware/samsung/
9aa3af7 ril: Fix compilation with debug messages turned on
e2b3653 libril: Fix element count
* kernel/moto/shamu/
84bc133 block: sioplus: set fifo batch to 16 to reduce overload on eMMC and CPU.
a5560aa block: zen: set fifo batch to 16 to reduce overload on eMMC and CPU.
* packages/apps/Settings/
4c5571f Merge changes Id6f705bc,Ia2c63b76,I6e64ad9b into lp5.1
23a2c8b Merge "Settings: fix confirm pattern crash on rotate" into lp5.1
9225f8e Settings: update turkish bliss_strings.xml (part 3)
147b05a Settings: update turkish bliss_strings.xml (part 2)
cbc3975 Settings: update turkish bliss_strings.xml
b7a00cc Fix up typo in lockscreen weather settings
* packages/services/Telecomm/
1cde049 Telecom : Add callInfo provider abstraction
* system/core/
b6ebd65 healthd: allow custom charger
* vendor/bliss/
e4932d0 Raise ROM version to 3.6
1bf2a06 Merge "Comment out all romstats" into lp5.1
2afbf65 Merge "Fix Sprint 3G" into lp5.1
472c8da Merge "vendor : Fix OTA For 64bit Devices" into lp5.1
f70947b Comment out all romstats
149d68c Fix Sprint 3G
Reaktionen: 66er
thread update.
Irgendwie klappt bei mir was mit dem Flashen der aktuellen Nightly nicht.
index · powered by h5ai 0.26.1+136~08cd031 (http://larsjung.de/h5ai/)
Habe sowohl die zip Datei als auch die md5sum Datei heruntergeladen und auf meine Micro SD Karte verschoben aber beim Flashen erscheint die Meldung das die md5 fehlerhaft sei und die Intallation der zip wird abgebrochen.
Kann mir jemand eine kleine Hilfestellung geben ? Habe es so gemacht wie im Startpost beschrieben.Habe mit der TWRP Recovery noch nicht so lange zu tun.Habe eben ein Backup der BlissPop V3.2 wieder eingespielt.Das klappte gut und hat nur sehr kurz gedauert bis es wieder hergestellt war.Im Gegensatz zu CWM Recovery ging das turboschnell :laugh:
defekter download, einfach noch mal machen.
Hier sehr gut (besser :blushing: ) erklärt.
Ich hab mir die nightly via Ota gezogen und dort stimmt die MD5.
Hab dann die zip auf die externe SD Karte verschoben und geflasht.
Versuch nochmal die zip über Ota zu laden und vergleich die MD5.
Matt kannst du mir bitte den Link dafür posten ? Wäre sehr nett.Danke im Voraus.Was muss ich denn genau in der Teamwin Recovery alles anwählen,damit ein Flash mit md5 check einwandfrei abläuft ? Sorry für die etwas laienhaften Fragen, aber wer bekanntlich nicht fragt der bleibt dumm :D
Ups oder meinst du mit OTA etwa den integrierten Updater der Rom ? :rolleyes2: Steh irgedwie gerade auf dem Schlauch
Genau den meint Matt [emoji6]
OTA = Over The Air
Hat jemand schon Bugs fest gestellt?
Einstellung - über das Telefon - Aktualisierung
Dann laden und wenn fertig auf md5 prüfen.
Von dort kannst du es dann auch installieren.
Es wird ins Twrp gebootet.
Dort dann die md5 Option abwählen.
Oder wie ich es mache die ZIP aus dem Download Ordner auf externe SD Karte verschieben und dann manuell ins Twrp booten und von der SD Karte flashen.
Ohne md5 Option.
Alle Wege führen nach ROM :lol::blushing::cool2:
Reaktionen: Saimen
Ja, aber nichts wichtiges.
Changelog wird nicht angezeigt.
Und über Ota wird diese Version erneut als update angezeigt.
Ansonsten läuft alle super.
Reaktionen: 66er
Changelog siehe hier oder hier :winki:
Schaun mer mal ob es heute nen Trikot tausch beim Damenfußball gibt :drool:
Ja, kenne die Seiten.
Ist nicht wirklich wichtig das es in der Rom nicht angezeigt wird.
War ja nur für die Neuen hier :winki:
hab mal den link zum changelog auch in den startpost gepackt! :)
Reaktionen: sgs9000A
Könntest du bitte auch noch den Hinweis hinzufügen das Boeffla alpha6 derzeit nur mit nightly läuft und für die offizielle derzeit nur Boeffla alpha3 läuft.
halte ich persönlich für überflüssig da die wenigsten wohl noch die veraltete official build nutzen...
Ohne md5 Option.
Habe es eben so versucht wie du es beschrieben hast Matt, aber irgendwie bleibt die aktuelle Bliss Zip beim Flashvorgang hängen.Habe die Zip auf meine externe SD Karte verschoben.Ebenso den Boeffla Kernel v.4.0 Alpha 6 sowie die aktuellen TK Gapps vom 20.06.2015.
Werde es für heute wohl erstmal lassen.Ein Glück habe ich das Backup der Bliss 3.2 mit Boeffla 4 Alpha 3 vorher gemacht.
Wenn das mit dem Flashen über TWRP zu keinem Erfolg führt werde ich wohl zurück auf die Clockword Mod Recovery gehen.Kann ich diese mit TWRP einfach wieder flashen und beim Boot ist sie dann wieder vorhanden ?
TripleH_72
Wenn alles schief läuft kann man sich damit trösten, dass man genau so viele Oscar's wie Leonardo DiCaprio hat.
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
Sossy
