[ROM][I9300][4.4] ArchiDroid V2.5
  • 121 Antworten
Hat es schon jemand getestet ?
Ich persönlich warte noch ein wenig ab ...
Statement vom Dev:
Thank you guys for awesome feedback. I'm very happy to see version 2.3 running that great.
I didn't notice device doesn't turning off (screen), I even checked that with 15 seconds options. All "stable" users shouldn't even face this issue, experimental users, please make a full wipe if you do.
All features such as Halo, ListView animations and more WILL be added at some point, because they're already on Omni's gerrit. There's no need to rush and there's no need to heavily modify Omni, especially because Omni is very community-based and it's better to contribute and wait for proper merge + updates than kanging on your own. Why? Because Omni is the community, I'm only one.
Exfat sdcards, sdcards in general - This should be handled by Omni itself. Exfat doesn't work at all, that's true. But my fat32-formatted external sdcards works great, so maybe it's third-party issue like kernel or something. ALWAYS try Bare Bones preset before pointing your finger on anything.
Inverted google calendar has broken sync, that's why I deselected that in default preset and I suggest to download from google play.
If any of your titanium backuped apps are not working, it's because of Android 4.4. Again, third-party issue.
That's all for now. Overall I think that new version is far better than 2.2.5 RC and close to perfect 2.2.4, which is oldstable now. Like I said many times, updates are optional. You decide when and if you want to update. For me, new version works truly great and I'm happy that I can share my work with you .
Reaktionen: craP_cillA
Problem bei mir ist, das ich kein Englisch kann.
Kurze Zusammenfassung:
Die ganzen Features werden erst in den nächsten paar Wochen kommen, das Grundgerüst von Omni läuft jetzt, so langsam kommen dann jetzt die "netten, bunten" Sachen. :)
Reaktionen: Edin
Hatte sie installiert aber immer wieder Reboots.
Man muss doch noch etwas warten...
Habe versucht es zu Installieren, hab aber nur Reboots bekommen habe nicht einmal die Rom gesehen.
Welches Recovery hast du benutzt?
ich habe CWM 6.0 Touch benutzt. Ist die zu alt ?
Ja.
okay habs jetzt aktuallisiert ... wusste nicht das die CWM zu alt ist :)
Werde die Rom gleich erneut Probieren.
Für die Installation muss CWM 6.0.4.3 (bzw. 6.0.4.4 Touch) oder neuer bzw. TWRP 2.6.3.1 installiert sein. (So ist es bei anderen 4.4)
Rom Läuft Super.
ja habs erneuert und läuft jetzt Perfekt. :)
ich kann machen was ich will, ich bekomme die Rom nicht zum laufen :sneaky:
Das ist schon sehr wenig Information und meine Glaskugel ist gerade in der Reinigung.
Wenn du willst, dass man dir hilft, dann gib mal bitte ein paar mehr Details! "Nicht zum Laufen" ist schon sehr wage!
habe die ROM mit TWRP 2.6.3.1 geflasht, nach Neustart des Handy bootet das Handy ganz normal hoch bis zur PIN-eingabe der Sim, ab da wieder Neustart.
Das gleiche, wenn ich mit CWM 6.0.4.4 Toutch flashe.
Ich habe es mit den beiden Möglichkeiten des flashens versucht die angeboten werden beim Installationsvorgang, Benutzerdefiniert und nicht Benutzerdefiniert.
Bei mir war es auch so allerdings bootet das s3 nur einmal selbst neu danach nicht mehr
NoobAnd schrieb:
Hm ... hast du einen Full Wipe gemacht?
Versuch mal die neueste Recovery von Philz:
[i93xx][CWM Advanced Edition] PhilZ Touch - xda-developers
Ich mache immer ein Full Wipe bevor ich eine Rom flashe.
Werde es noch einmal mit dem aktuellen Recovery versuchen und wenn es wieder neu startet ein 2. mal booten.
Mal schauen ob es klappt...
Edit:
Hat funktioniert, hätte wohl beim Neustart geduldiger sein sollen...
Reaktionen: NoobAnd
Ich hab ein neues Problem ich hatte bei 4.3.1 fast 48 stunden Akku jetzt wenn ich Glück hab 12-18 Stunden. Hat einer ne Idee woran das liegt?
Gesendet von meinem GT-I9300
