thisisme
YES, HALOSilene84 schrieb:V12 ist online
V12 (Current Version)
md5sum: 858753d151b54b447525b94d192fc236
FIXED - SystemUI force closing when Active display is enable when HALO is present. - Cristiano Matos
- Now we can have both Active Display & HALO present.
HALO - ParanoidAndroid
Add option to enable/disable HALO
ListView Animations and Interpolator - team ThinkingBridge
Restore "Add battery level around unlock ring"
- It was reverted in V10
Bring back all lockscreen Widget Settings - SlimROM
- this commits brings back adapted versions for 4.4:
- enable permanent maximized widgets
- allow carousel view
- disable camera widget (NOT WORKING YET)
- disable initial page hints
Revert Omni InCallUI for now
i9300 - Revert "Do not disable voice call route on adev_open"
fb: give the system proper values back if it is a hw key or navbar device - SlimROM
- as well allow this behaviour to be overwritten by system.prop like it is suggested by google.
- Needed to show eg the menu button in apps correct on the different device types
fb: enable navbar for hw key devices - SlimROM
- we moved this part into PhoneWindowManager which controlls the navbar. Due that we allow on all devices a navbar the check on PhoneStatusBar is not needed and prevent the navbar on coming up on hw key devices.
Implement a pin keypad shuffler - SlimROM
LockBeforeUnlock the new way - SlimROM
- Due that aosp removed the whole LockBeforeUnlock controll (show slider
lockscreen before an unsecure internal lockscreen) we must try to find another way without touching the security system itself. Long guess short solution, lmao.
fb: enable haptic feedback for lockscreen shortcuts - SlimROM
- more consistent to general lockscreen behaviour
Add support for variable size pattern lockscreen - SlimROM
smdk4412-common: camera: fix scene mode snapshot capture crashes - dhiru1602
smdk4412-common: camera: reorganize camera parameters - dhiru1602
smdk4412-common: camera: several fixes for autofocus - dhiru1602
smdk4412-common: camera: fix incorrect jpeg thumbnail height - dhiru1602
smdk4412: camera: include support for snapshot while recording - dhiru1602
Updated temasek translations
Updated cm source - lots of it. Help yourself and read it in cm gerrit.
Frage: Kann man die v12 über die V73 4.3.1 einfach drüberflashen? oder gibts dann FC`s?
