[ROM][I9300][4.4.4] Temasek's UNOFFICIAL CyanogenMod 11
  • 5.275 Antworten
Hat das einen Grund, weshalb die aktuelle Rom nicht mehr online ist?
V11 war kurz online, deswegen ist V10 zu "old" gewandert.
V11 hat Probleme gemacht und kommt im Laufe des Tages neu
Reaktionen: heavymetall66, Silene84, gordon-1979 und eine weitere Person
Die v9 ist sehr gut, 1 Tag und 5 Stunden Laufzeit, echt gut.
Kann man die die auf den homescreen erstellte Ordner, editieren, so dass ich mehr Verknüpfung einfügen kann?
V12 ist online :)
V12 (Current Version)
md5sum: 858753d151b54b447525b94d192fc236
FIXED - SystemUI force closing when Active display is enable when HALO is present. - Cristiano Matos
- Now we can have both Active Display & HALO present.
HALO - ParanoidAndroid
Add option to enable/disable HALO
ListView Animations and Interpolator - team ThinkingBridge
Restore "Add battery level around unlock ring"
- It was reverted in V10
Bring back all lockscreen Widget Settings - SlimROM
- this commits brings back adapted versions for 4.4:
- enable permanent maximized widgets
- allow carousel view
- disable camera widget (NOT WORKING YET)
- disable initial page hints
Revert Omni InCallUI for now
i9300 - Revert "Do not disable voice call route on adev_open"
fb: give the system proper values back if it is a hw key or navbar device - SlimROM
- as well allow this behaviour to be overwritten by system.prop like it is suggested by google.
- Needed to show eg the menu button in apps correct on the different device types
fb: enable navbar for hw key devices - SlimROM
- we moved this part into PhoneWindowManager which controlls the navbar. Due that we allow on all devices a navbar the check on PhoneStatusBar is not needed and prevent the navbar on coming up on hw key devices.
Implement a pin keypad shuffler - SlimROM
LockBeforeUnlock the new way - SlimROM
- Due that aosp removed the whole LockBeforeUnlock controll (show slider
lockscreen before an unsecure internal lockscreen) we must try to find another way without touching the security system itself. Long guess short solution, lmao.
fb: enable haptic feedback for lockscreen shortcuts - SlimROM
- more consistent to general lockscreen behaviour
Add support for variable size pattern lockscreen - SlimROM
smdk4412-common: camera: fix scene mode snapshot capture crashes - dhiru1602
smdk4412-common: camera: reorganize camera parameters - dhiru1602
smdk4412-common: camera: several fixes for autofocus - dhiru1602
smdk4412-common: camera: fix incorrect jpeg thumbnail height - dhiru1602
smdk4412: camera: include support for snapshot while recording - dhiru1602
Updated temasek translations
Updated cm source - lots of it. Help yourself and read it in cm gerrit.
Reaktionen: heavymetall66, tommey und kmr100
Wie bekommt ihr denn so Laufzeiten hin? Bin jetzt wieder zur gorgorid gewechselt. Hatte unter temasek so schlechte Werte kam vielleicht 10 Std hin ohne gross was zu machen
Kannst neue Verknüpfungen doch einfach in den Ordner rein ziehen.
ich habe es auf 38 Std. geschafft. Benutze den boeffla-kernel.
Den hatte ich auch. Egal welche Rom bei mir läuft da ist immer der boeffla kernel drauf. Aber trotzdem hat die Rom voll am Akku gesaugt.
Ja aber ab mehr als 12 Verknüpfungen geht nicht. Kann man das ändern?
Das wird dann wohl beim Standard Launcher das Limit sein. Sonst musste halt mal nen anderen Launcher nehmen. Hab den Nova Launcher drauf und da gehen auf jeden Fall über 20 rein.
Die Einstellungen der ROM bei der "Statusleiste sind schon super zudem die Farbänderungen die man vornehmen kann des Batterie Symbols und der Uhr ist toll aber was ich nicht verstehe ist warum man zB nicht gleich mit einbaut die Farbänderungen des Weckersymbols;Wlan;Netz etc. ?
Jemand ein Vorschlag bevor ich mir wieder irgend ein Theme drauf klatsche das nur zu 2/3 Kompatibel ist oder so ?
Grüße Nev
Hat einer von euch bei v12 auch wieder das Problem mit den multi task wenn man den bildschirm entsperrt? Also da kommt halt öfters mal wieder die Ansicht.
Gibt es eine Möglichkeit, flash ans laufen zu bekommen?
Flash Apk downloaden und installieren und einen Browser benutzen, der Flash unterstützt.
Mit den im ersten Post verlinkten Gapps, wird andauernd die Android Tastatur beendet. Jemand eine Idee?
habe keine Probleme also sollte es nicht an den gapps liegen. Hast du ein Theme installiert? schonmal Cache und dalvik wiped?
Es gibt sogar ein Video über diese Rom.
Wer sich inspirieren möchte, hier mal der Link.
youtube
So einfach ist das bei 4.4 wohl leider nicht mehr.
Mit dem Link von Magnum1824 funktioniert es jetzt aber.
Mopp schrieb:
@extralife
Danke für den Link
Hat jemand von euch eigentlich mal Real Racing 3 unter CM 11 getestet? Ich habe mein Backup davon eingespielt und musste feststellen, dass der Sound in dem Spiel plötzlich total ruckelt.
Hallo Mopp , hab die omni Rom am laufen , hab aber auch das Problem das rr3 gut läuft aber den sound kannst vergessen , hast du eine Lösung gefunden ???? Falls ja , wäre ich dir für einen tip dankbar.Gruß
html6405
Verci
V
html6405
html6405
html6405
