gordon-1979
Stamm-User
- 119
Was haltet ihr von omni?
Temasek schrieb:History of Temasek cm11
When I first started, a lot of cm codes in different segments were not
yet added by cm. I am sure a lot of cm stuffs isn't included in my
old builds resulting in complications as of time cm includes
msim stuffs (multi sim support).
2 key stuffs conflicts with cm msim.
1. Slimrom wifi & carrier labeling stuffs
2. Total missing signal cluster stuffs. That's why u don't find an
option to switch between signal icon, signal text or no signal icon.
Plus there are probably a lot stuffs missing or lacking
in sync with cm. Things like eg RTL support, etc.
I've asked myself this question again and again many times over
the last one week. Do I take the opportunity of this conflict to be
in sync with cm or do I continue with old build hoping that I can resolve it?
Since the last couple of hrs I finally found what's conflicting with the
cm msim stuffs as per mentioned above.
Yet I'm still asking myself the same question as above.
Adding back halo & active display is easy.
I can do it like immediately to the new build but I've chosen to drop it.
3 key features are lacking which I will find it a challenge to add back.
1. Slimrom Navigation bar rebinding
2. Slimrom hardware key rebinding.
3. Slimrom pie control.
Why I could add it in my old build? It's because cm didn't add
those when I added it before. Now with cm at this stage, I need1
to do lots of reverts just to add back the above.
It is not impossible definitely. I'm going to add that back soon anyway.
Clean full sync cm code base with less features as of
now or old build with hiccups here and there?
End of story.
Yprh schrieb:Wieso weshalb warum weiß ich leider nicht :/. Habe mal getestet woran es liegt bin aber selber auf keinen grünen Zweig gekommen.
heavymetall66 schrieb:Ja, Dragon verwendet den Stable Boeffla Kernel 2.1 !
HammDefy schrieb:Sehr schade, dass Tema kein Bock mehr auf die S3-Rom hat. Fusion Boeffla ist reizvoll, aber dass man keinen aktuellen Boeffla-Kernel installieren kann, stört mich schon sehr...
Im moment bin ich mit Temas V48 bzw. V50 sehr zufrieden, eventuell teste ich aber mal die SlimKat...
Yprh schrieb:Also mir soll es recht sein wenn es weiter geht aber dieses auf und ab ist schlimmer als bei einer schwangeren -.-.
Lord Boeffla schrieb:Ich kann nur vermuten: Eventuell hat Tema das Dual-Sim Zeugs von CM11 mit eingebaut. Dann müsste ich einen neuen Kernel bringen, aber vermutlich sogar einen eigenen Temasek-Kernel, der dann nicht mehr kompatibel zu Omnirom etc. wäre.
Und ausser CM11 und Omnirom noch einen dritten Kernel zu pflegen werde ich mir wohl nicht antun.
Mal schauen, aktuell ist Wochenende, morgen guck ich mal nach.
Andi
Lord Boeffla schrieb:Angeblich geht der cm11 boeffla kernel beta5a momentan mit der Temasek rom.
Das würde meine Vermutung mit der Multi-Sim Sache bestätigen...
Andi
Basti@DDorf schrieb:Mal eine andere Sache.
Kann mir mal jemand was zu Xposed sagen?
Hab's noch nie benutzt und wollte eigentlich nur wissen,
ob es das Gerät in irgendeiner Weise verlangsamt
und worum es sich bei Xposed genau handelt.
So wie ich das verstehe ist Xposed 'ne Schnittstelle
für verschiedene "Module", welche das GUI und gewisse Funktionen beinflussen.(???)
MFG
Yprh schrieb:Also ich nutze schon ziemlich lange xposed und das auch ziemlich gerne.
Ich merke keinerlei Verlangsamung und ich habe wirklich einige module am laufen.
In gewisser weise kann man durch xposed die Rom noch mehr verändern ohne viel zu tun.[/SIZE]
