[ROM][I9300][4.4.4] SlimKat [Stable 9.0][FINAL 26.12.2014]
  • 10.071 Antworten
4.2.2 Build 4
Dear SlimUser!
It took some time but here it is, Build4. It became a really good build with some awesome features.
Custom Tiles and the controversial SlimPIE to name the most prominent ones.
However we also included quick access to the Slim IRC, feel free to connect if you have a problem or if you just want to come by and have a wee chat.
And thanks to the power of the community our ROM gets more and more translated, thanks to everyone who helps us improving SlimBean and make it better and better with each release.
One last note before you go ahead and download it. We highly recommend a full wipe this time because we have some quite big changes this time.
And now go ahead and see if you can break the new server this time, last time you didn't even came close :p.
NOTE: Many devices have been renamed to be uniform with their codenames. Please check for the them specifically.
Changes and Features
  • Add SlimPIE
  • Add Custom Shortcut Tile
  • Add SlimIRC
  • Add Sound Recorder [deleted speechrecorder]
  • Add Camera sound toggle
  • Add Auto-Hide Statusbar
  • More Camera resolutions
  • New Blacklist functionality
  • Add ability to dismiss voicemail notifications
  • Polish and cleanup SlimCenter
  • Enhance NFC from upstream AOSP
  • Add complete IBSS Support in base
  • Tons and Tons of Translations... Thanks to all contributing in Crowdin :)
  • And as usual Tons of optimizations and Fixes
  • Added support for
    • Galaxy Tab 2 7" Wifi
    • Galaxy Tab 2 7" 3G
    • Galaxy S i727 Skyrocket
  • Device specific
    • Mako
      • Inline kernel
      • Added SIO & ROW
      • Added Conservative
      • Krait retention
      • Fast Charge (motley)
      • Thermal temp throttle selector (showp1984 & franciscofranco)
      • Basic sound gain (franciscofranco)
      • Fsync(Ezekeel)
      • Gamma control (franciscofranco)
      • Linaro toolchain
      • Other smaller changes
      • Added init.d support
    • N7100/I9100G
      • Update to 3.0.74
      • Fix wakelocks
      • Updated conservative
      • Updated Interactive
      • Updated Logger
      • Updated LMK
      • Updated android staging files
      • Enhance string arithmetic
      • Higher Read-ahead
      • Updated WiFi drivers from 3.4 [N7100]
      • One more mmc patch [N7100]
      • Added SIO and Interactive [N7100]
      • Tons more.
    • D2: Updated kernel to 3.4
    • I9100G: Added noise suppression for voice calls
    • I9300: OpenSource RIL [CM]
    • Nozomi: Added FIOPS
    • Tuna: Lean Kernel 6.4
    • Skyrocket: Added init.d support
    • Crespo and Crespo4g updated kernel to latest marmite
Fixes
  • Camera extra settings menu
  • Fixed DSP Manager
  • Fix Photosphere/Camera FCs
  • Fix Unable to pulldown Notification in Expanded mode
  • Fix some issues with Exchange and Email
  • Device specific
    • Nozomi: Fixed Intellidemand
    • Nozomi: Fix NFC
    • I9100: CM camera fixes upstream
    • N7100: Fixed thethering
    • I9300: Fix dock audio
    • D2: Phone call freeze fixed
  • Startpost aktualisiert
  • Download
Hallo, hat sonst noch wer da Problem das er nicht auflegen? Full wipe hab Ich gemacht :-[
Edit.
Fehler gefunden ril darf nicht verändert werden.
Reaktionen: pandabra
Jap. Kann auch nicht auflegen. :confused::confused:
Hast du das ril oder das Moden geändert?
Ja das war der fehler. Problem gelöst. Danke euch
Bei mir zeigt die Galerie nun nur die mir der 4'er Build aufgenommenen Bilder. Nutze die SD Karte für die Bilder. Es sind auch alle auf der Karte... Gibt es da so eine neue Einstellung?
Guten Abend
Ich habe slimbean build4 und yank 1.5i drauf.
Nun wollt ich mal fragen, ob jemand weiss, wie ich auf dem
Sperrbildschirm das angegraute grosse Viereck
- indem sich die Uhrzeit und das Datum befindet-
Transparent machen kann? Sodass es nicht mehr
sichtbar ist.
Mfg
Der ursprüngliche Beitrag von 21:22 Uhr wurde um 21:28 Uhr ergänzt:
... auch wuesste ich gerne , wie ich hier im Forum statt AW Antworten
meine Fragen und Anliegen als Neuen Beitrag schreiben kann,
falls ich mals was Frage ists ja keine AW lol:smile:
Gruss
Hey Leute.
Ich hatte vor dem Build 4 das Modem geändert.
Nun habe ich ich über 450k partial wakelocks durch die RIL...
Was kann ich dagegen tun???
Hallo liebe leute,
nochmal zur info das mit den reboots hat sich erledigt jetzt funktioniert es.
nun habe ich aber ein größeres problem ich habe momentan das Build 4 drauf mit yank kernel 1.5k
tjo so weit so gut nur dann hatte ich mir am samstag ne docking station geholt die orginale von samsung ED200 glaub heist die und seitdem lädt mein hande extrem langsam auch wenn ich es nicht mit der dockingstation verbinde ich habe jetzt von 0 Uhr bis 2:30 gespielt und in der zeit ist der accu von 55 % auf 58 gegangen kann doch ned war sein.
kernel settings sind stock einstellungen.
nix verändert...
sowie der accu wird auch leicht warm...
wenn ich das Handy ausmache und es an die steckdose packe dann lädt es ganz normal nur wenn es an ist geht es so langsam vorher war es viel schneller.
Versucht habe ich schon DATA/Factory wipe hat aber auch nix gebracht.
Dann habe ich schon versucht über ein anderen usb Port funktioniert aber auch nicht er zeigt auch an das er lädt aber es kommt nix rein.
aus lauter verzweiflung habe ich mir auch schon ein neues kabel gekauft. funktioniert aber auch nicht.
Angeschlossen habe ich es schon an USB 2.0 sowie USB 3.0 beides geht nicht.
ich glaub ich werd das handy nochmal mit der stock rom flashen und alles neu machen.
wenn jemand kein rat hat....
glaub auch das ist der falsche Thread dafür dachte nur wegen weil ich diese rom benutze.
MFG Dennis
Stell mal im Aroma bei USB AC auf 1000 dann sollte es klappen...
Die docking Station wird vermutlich als USB gerät erkannt...
Folgendes Problem: habe eben geupdated auf build 4, und neuen yank drauf geschmissen.
sobald ich nun irgendeine app im slimsizer deinstallieren will kommt ein popup "slimcenter wurde beendet" ... alten yank kernel klappt auch nicht, ich denke liegt am neuen build !
hat dieses problem noch irgendjemand oder hat jemand eine lösung ?
könntest du mir eventuell noch sagen wo ich diese einstellung mache ?? beim yank kernel in der installation mit der config oder wo anders ?
dem slimcenter superuser rechte entziehen und dann nochmal versuchen. Dann die rechte natürlich wieder gewähren wenn er danach fragt. Hatte das selbe problem. So hats geklappt
hatte ich auch am Anfang, habe einfach die Entwickleroptionen freigeschalten (mit dem drücken auf die Build nummer)
Und dann gings problemlos, hat dann nach SuperUser rechte gefragt und dann natürlich auf Zulassen :)
Über CWM den yank flashen dann im Aroma kann man 1000 mA anwählen
Hey ho,
Danke erstmal, ich hatte über nacht das handy ausgeschaltet und aufgeladen da es dort funktioniert heute morgen hatte ich 100 % accu. hatte dann accu Kalebiert und Dalvic cache gelöscht.
Mal sehn wie es sich verändert hat habe auch im yank es umgestellt vorher war stopck usb 2.0 jetzt habe ich mal auf usb 3.0 gemacht. mal sehn was kommt.
Kann mir wer was zu der Kamera und vorher aufgenommenen Fotos sagen? Werden in der aktuellen Galerie nicht angezeigt. Bislang war das nie ein Problem...
Nu hab ich mich doch getraut ..
und zum ersten mal mein Handy auf SlimBeam 4.2.2 gebracht .. klappte super ;-)
Die frage mit dem roten Ausrufezeichen beim starten des Handy konnte ich ja noch mit der Suchfunktion beantworten ....
Aber was ist mit dem Google Play Strore ?
Auf dem Handy funktioniert er super ... aber auf meinem PC nicht :-(
Da steht dann ich hätte kein Gerät :-(
Bin bei beidem mit meiner @gmail Adresse angemeldet ....
Bin ich zu doof, oder geht das nu nicht mehr, weil`s kein Original mehr ist ???
Hallo habe die built 4 geflasht mit den gapps aber leider bekomme ich keine Verbindung zum Playstore . Wie kann ich das hingekommen das er wieder funktioniert? Danke
Funzt jetzt
Built 4 läuft einwandfrei mit dem yank! Einziges problem: hin und wieder mal "keine Verbindung zur kamera"
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
