[ROM][I9300][4.4.4] SlimKat [Stable 9.0][FINAL 26.12.2014]
  • 10.071 Antworten
Stable 2.0 WIP
Changes and Features
  • Full JDQ39 base
  • Replaced cLock with Shiny new 'DashClock'
  • Added slide before unlock
  • Bring back long press to toggle PW
  • MMS: Add Quick emoji to text input
  • MMS: Back to Android emoji set
  • Phone: Set my phone number
  • Added full hardware key rebinding (home+back)
  • Added Kill App/Expand Notification Shade/Toggle Expanded Desktop to hardware binds
  • Fully configurable advanced reboot toggle
  • Enhance circle battery and clock
  • Camera: Add software HDR mode
  • Calendar: Add snooze to events
  • Enhance T9 and search
  • Settings: Add forget all networks to WiFi
  • Notification: Limit notification sounds for interval
  • Camera: Add animation to mode switch
  • Sound: Add configurable volume adjust sounds
  • Notification: Add custom carrier text
  • Enhance electron beam control
  • Tons and tons of more fixes and optimizations
  • And a little surprise for the savvy ones :)
  • Devices
    • I9100G : Samsung Kernel update
    • N7100 : Fixed WiFi tethering
    • SGS2/i777/Note2 : Update Mali drivers
    • d2: A2DP/Bluetooth updates
    • manta: Switch to Google Kernel
Fixes
  • MusicFX FC
  • Batterybar UI glitch
  • QuickPulldown flips notification shade
  • Phantom QuickSettings toggle
  • Color picker issues
  • Recents apps panel bug
  • Camera not animating
  • Color picker in landscape
  • Recovery touch
  • Expanded desktop
  • Contacts call grouping
  • Alarm FC on update
  • Notification shortcuts spacing/tablet transitions
  • Choppy lockscreen on Low-mem HDPI
  • Lockscreen browser shortcut
  • Longpress NavBar Home not loading recent apps
  • And finally ASS to 'Advanced Slim Settings'!!!
  • i9100/i777: Graphic glitches fixed
  • manta: Bluetooth fixed
  • Fixed system and YouTube FC
Known Bugs
  • I9100G : Statusbar freeze
  • Device specific
    • i9100: Touch Zoom buggy (use volume buttons to zoom)
    • i9100: WiFi Direct not working
    • i777: APN may take a while to load
    • i777: video recording broken
    • i777: WiFi broken
    • d2: Camera exposure not working (upstream)
    • d2: Camera HDR disabled (until exposure is fixed)
    • d2: Capacitive/Hardware keys shortpress can sometimes act as longpress (upstream)
Der ursprüngliche Beitrag von 07:59 Uhr wurde um 08:01 Uhr ergänzt:
Also bald ist es dann soweit. Denke 2 Tage wird es noch dauern :)
Hoffentlich sind mit der 2.0 dann endlich die WLAN Probleme weg...
Beste Rom die ich je benutzt hab!! Ich versteh nicht warum das andere nicht so hinbekommen.... Die Rom hat genau die Einstellungen die ich benötige und keine bloatware dabei... Die rom läuft grundsätzlich stabil!
Stimme ich Dir voll und ganz zu!
Habe sie mit dem Temasek Kernel kaufen und bin restlos begeistert!
gelöscht
Bin im Großen und Ganzen auch zufrieden mit der ROM.
Läuft flüssig und schnell.
Und doch hat auch diese ROM einige "Seltsamkeiten". Zumindest bei mir.
1. Im Ausland stellt sich die Uhrzeit immer wieder auf GMT um. Nach einem Neustart wird für ein/zwei Stunden die richtige Uhrzeit angezeigt, dann springt sie aber automatisch wieder auf GMT um.
2. Chrome erleidet immer wieder spontane Abstürze. Hauptsächlich, wenn SwiftKey ins Spiel kam, z.B. wenn man sich auf einer Seite einloggen wollte und ins entsprechende Textfeld klickte. Das gleiche mit Opera, aber hier seltener.
Die App AllAboutSamsung lässt sich seit einigen Tagen gar nicht mehr starten. Sind aber vielleicht auch App-Probleme? Auch wenn diese vorher nicht vorhanden waren ...
3. Die Batterieladeanzeige leuchtet bereits bei 91% grün auf. (Ist ja vielleicht auch so gewollt ...?)
4. Nicht schlimm und auch kein Fehler, aber stört ein wenig das "Gesamtbild": Unter Einstellungen --> ASS sind alle Punkte auf Englisch. Hoffe, dass das vielleicht mal geändert wird.
Bin ansonsten sehr von der ROM angetan. Tolle Arbeit!
WLan Probleme ? Das ist hier gerade das einzige was ich lese, weswegen ich mir die Rom noch nicht gezogen habe und auch deswegen noch nicht geflashed habe.
Wie steht es um die WLan Probleme ?
WLAN geht bei mir einwandfrei...
die rom hat doch eine "swype" tastatur integriert?
chrome ist bei android 4.2.x eh verbuggt... schon öfter von gelesen.
ich nutze den boat browser. der funktioniert 1a
das ist gewollt. ab 90% zählt der akku als "voll"
Wie steht es um die WLan Probleme?
wlan funktioniert einwandfrei. da wo es nicht geht ist ein einzelfall...
Ja und ich bin leider einer der betroffenen des WLAN Problems... Liegt aber glaub an der genutzten cm Version denn mit den aktuellen nightlys ist das Problem nicht mehr vorhanden...
Heut abend wird vermutlich eh 2.0 veröffentlicht...
Ansonsten beste Rom die es gibt vorallem in Kombination mit dem yank Kernel...
vom slim entwickler um 2:18 heute morgen:
"soon means anywhere between 24 - 48 hours"
update also in 1-2 tagen ;)
24 - 48 std sind aber 1 - 2 Tage, oder? ;)
ups.... da ist natürlich was dran xDDDD :D
Frage ist nur ob es dann auch für S3 da ist oder erst für da S1/S2 denn bis jetzt war es immer so das es für das S3 dann nochmal 2 Wochen länger dauerte als für denn Rest.
Ich bin der Meinung, die letzte kam zeitgleich!
das war nur bei den 4.2.1. beta's so, weils auf dem s3 da noch nicht lief. aber seit den rc's kommt alles gleichzeitig.
Ok dann halt noch 1-2 mal schlafen ^^
Bin schon sehr gespannt auf die neue version. Teste derzeit ein paar cm und aokp roms aber so richtig sagt mir noch keine zu.
Dann bist du hier richtig...
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
