[ROM][I9300][4.4.4] SlimKat [Stable 9.0][FINAL 26.12.2014]
  • 10.071 Antworten
Supi, dann warte ich mit der Neuinstallation. Ansonsten schon mal tolle Arbeit :thumbsup:
Findet hier , dass eine reine Android Rom smoother und schneller läuft als eine auf Stock basierende Custom Rom ?
Diese hier reizt mich schon sehr sehr sehr doll :)
Super Sache das Rom, ich warte auf den RC2!!
Ich bin echt sehr begeistert!!!
4.2.1 RC2 - WIP (Work in Progress) ~ca 2 Tage noch ;)
Details
Created on Saturday, 02 February 2013 19:59
=== Changes and Features ===
* Shiny new Slim OTA App
* Specific WiFi network priority
* Long press lockscreen handle to unlock
* Reworked WiFi AP to be more like PW
* Dual-pane settings
* Mms auto retrieval
* Forward port ClockWorkMod Touch Recovery from SlimRoms JB
* Improved RAM bar with additional mods
* Add Call statistics to Phone
* Add/update many translations to Gallery, Mms, People, Bluetooth, Browser and Deskclock
* Add option to shake/flip to control Alarms
* Add option to hide Alarm clock icon on statusbar
* Add option to toggle the pointer icon when using stylus
* Add ability to answer calls using home button
* Add Stylus gestures
* Last App toggle - Sethyx
* Status Bar: Fade CM widgets on Low Profile mode
* Add camera power modes
* Add High-end GFX toggle
* Add browser long press to "open in incognito" and new navbar buttons
* Add Status bar transparency and colors
* Add Navbar transparency and color
* Add option to switch between UMS and MTP/PTP
* Add "Don't wake up when plug in/out" option
* Add QS pulldown without notification
* New battery icon style
* Don't respond to touch in manual network search
* Display on while stopwatch running
* Tons of improvements and Fixes including some changes from 4.2.1_r1.2
* i9300:*
* Enable dock and power widget
* Enable Torch some missing stuff
* Enable Noise suppression
* Headphone speaker improvements
* i9100G:*
* Linaro Kernel
* Updated to 3.0.61
* LMK Fixes
* i9000/i777:*
* Add focus modes to camera
* d2 kernel:*
* Compiled with Linaro
* Merge Linux 3.0.y
* Add OC upto 1.9Ghz Max
* cpufreq/msm_thermal/ramdisk: Make sure max freq stays at 1.5Ghz
* Add Fast Charge - imoseyon
* CM based Ramdisks
* CM Upstream changes
* Tuna kernel:*
* LeanKernel v5.8
* Updated to Linux 3.0.59
* Fix sysfs functions - idle_time conversion
* Add some debug information on ROW queues
* Insert dispatch_quantum into struct row_queue
* Aggregate row_queue parameters to one structure
* Fix PEAP with dynamic WEP
* Hold mutex while removing reader
* Crespo/Crespo4G:*
* Update kernel sources by bedalus
* Enable Vsync
* Add MTP support (thanks mnazim)
* N7100:*
* Kernel fixes
* Camera fix attempts
* WiFi fixes
* Sound enhancements - NEAK
=== Fixes ===
* Camera Power shutter
* Incoming call widget display
* Notification drawer alpha
* Data restore on First Setup
* Window pop-up while marking as read from notification - CM
* Audioflinger: Fix to release wakelock after closeoutput
* A2DP on Samsung - CM
* Restoring network mode preference on reboot
* Cleanup on logcat output
* QS Animation
* Exynos 3: 2g/3g switchable
* Exynos 4: Signal strength
* Devtools FC
* WiFi Config FC
* Battery Temp display
* VideoCamera settings panel freeze
* Samsung WiFi logic
* Notification Cutoff at SlimDPI
* Multiple camera detection in Camcorder
* Volume wake fix
* Long press Navring
* Memleaks in various core OS components
* Toro+: GPS issues
* I9000: Play store compatibility issues
* I9000: Media duplication
=== Known issues ===
* Attach video in Mms causes FC on some devices
=== Device specific issues ===
* i777: Glitches in App Drawer and Daydream
Der ursprüngliche Beitrag von 17:24 Uhr wurde um 17:25 Uhr ergänzt:
Neuer kernel
Yank 1.4g
Reaktionen: 3nCoRe, netguru, Spider1996 und eine weitere Person
Ich hab nur noch keine DL-link gefunden...
Ist es schon offiziell raus für das S3?
RC2 schon raus?
Wohl leider noch nicht aber soll nicht mehr lange dauern.
Rc2 kommt scheinbar erst am Montag fürs s3.
WIP steht für Work in Progress ;) ab da dauerts meist so knapp 2 Tage ;)
Reaktionen: stephan1977, netguru und quaker_max
Ich kann nichts mehr über den Markt installieren .
Das kommt dann immer
@H5N1Martin
Menü - Apps verwalten - Reiter "ALLE" - Google Play Store - Cache leeren und Daten löschen.
Handy neu starten.
Dann sollte es wieder gehen.
Besteht leider immer noch das Problem.
Kann auch keine updates machen
Lade dir mal den Multi Dpi Store runter......
Guckst du: http://d-h.st/oiu
Das hat bei mir letztens auch geholfen. Hatte die gleiche Meldung. Wenn das Problem weiterhin bestehen sollte, geh mal in Einstellungen-Konten und lösche mal dein Google Konto und füge es dann wieder hinzu.
der multi dpi play store ist eig. schon integriert...
Der ursprüngliche Beitrag von 18:12 Uhr wurde um 18:35 Uhr ergänzt:
"The team is finalizing a few things...the rom WILL be released today. Its already done building and has been uploaded. Just waiting on the go ahead
Reaktionen: 3nCoRe
Ja ich weiß das er schon integriert ist, aber ich dachte mir eine neu Installation könnte nicht schaden und bevor er sich ein " Normalen Store" flasht ,hab ich ihn den verlinkt.
Aber das Google Konto löschen und neu einfügen sollte das Problem lösen.
Freu mich schon auf die RC 2 ...... an der stelle auch mal ein Danke an dich Alice!:beer ::)
Reaktionen: alice89
danke danke. aber ich verlinke ja nur und unterstütze hier so gut es geht mit meinem wissen :cool2:
Reaktionen: quaker_max
Auch das verlinken ist Arbeit bzw ein vertreib seiner Zeit die man auch anderweitig nutzen könnte! Viele sehen das mittlerweile als selbstverständlich an, was es aber nicht ist....:rolleyes:
Irgendwie, haben die Soundtweaks unter "stweaks" mit dem siyah kernel null auswirkung, egal was ich einstelle,...es bleibt immer gleich leise!!
Komm von Maddes Rom Light v9!
Hab fullwipe, plus format system,data,preload,cache gemacht.
Dann rom installiert, dann gapps, dann siyah kernel......dann noch mal wipe dalvik und fix permissons...dann reboot!
Aber wenn ich was in den stweaks unter sound verstelle, bleibt es leider immmer gleich leise!!
Haken bei Sound-Tuning..is selbstverständlich gesetzt!
Habe den siyah 1.8.9.
Mfg
Ich habe auch den Siyah und es bleibt bei mir auch alles beim gleichen.....:confused:
Beim Yank Kernel hatte es glaub ich funktioniert, da konnte man im Aroma schon alles einstellen usw.:screwy:
Übrigens 4.2.1 RC 2 ist draußen:
http://www.slimroms.net/index.php/downloads/all/viewcategory/75-i9300
Edit:
Wäre eventuell jemand noch so nett und erklärt mir jetzt wie ich das jetzt flashe? :D
Root mittels Odin u. CF-Root 6.4 hab ich durchgeführt, Backup mittels Recovery hab ich auch schon erstellt zur Sicherheit (und die Reihenfolge auch).
DANKE! :)
Reaktionen: 3nCoRe, Spider1996 und setfan9
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
