[ROM][I9300][4.4.4] Offizieller CyanogenMod 11
  • 13.268 Antworten
[FONT=&quot]CM 11 Kernel
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]===================
General Information
BetterBatteryStats version: 1.16.0.0_B3
Creation Date: 2014-05-26 06:19:31
Statistic Type: Unplugged to Current
Since 6 h 34 m 52 s
VERSION.RELEASE: 4.4.2
BRAND: samsung
DEVICE: m0
MANUFACTURER: samsung
MODEL: GT-I9300
OS.VERSION: 3.0.64-CM-gfd94358
BOOTLOADER: I9300XXUGNA5
HARDWARE: smdk4x12
FINGERPRINT: samsung/m0xx/m0:4.3/JSS15J/I9300XXUGMJ9:user/release-keys
TAGS: test-keys
USER: jenkins
PRODUCT: m0xx
RADIO: I9300DXUGNB1
Rooted: true
Battery Info
Level lost [%]: Bat.: -2% (88% to 86%) [0,3%/h]
Voltage lost [mV]: (4205-4124) [12,3%/h]
Other Usage
Deep Sleep (): 6 h 32 m 44 s (23564 s) Ratio: 99,5%
Awake (): 2 m 8 s (128 s) Ratio: 0,5%
Screen On (): 42 s (42 s) Ratio: 0,2%
Wifi Running (): 6 h 34 m 52 s (23692 s) Ratio: 100,0%
No Data Connection (): 6 h 34 m 52 s (23692 s) Ratio: 100,0%
No or Unknown Signal (): 6 h 34 m 52 s (23692 s) Ratio: 100,0%
Screen dark (): 42 s (42 s) Ratio: 0,2%[/FONT]
habe nix anderes gemacht wie beim CM11 kernel
General Information
Creation Date: 2014-05-28 07:38:47
Statistic Type: Boot to Current
Since 6 h 13 m 39 s
BRAND: samsung
DEVICE: m0
MODEL: GT-I9300
OS.VERSION: 3.0.101-CM
HARDWARE: smdk4x12
TAGS: test-keys
USER: jenkins
PRODUCT: m0xx
RADIO: I9300DXUGNB1
Rooted: true
Battery Info
Level lost [%]: Bat.: -5% (89% to 84%) [0,8%/h]
Voltage lost [mV]: (4121-4083) [6,1%/h]
Other Usage
Deep Sleep (): 6 h 10 m 12 s (22212 s) Ratio: 98,8%
Awake (): 3 m 27 s (207 s) Ratio: 0,9%
Screen On (): 2 m 1 s (121 s) Ratio: 0,5%
Wifi Running (): 6 h 13 m 39 s (22419 s) Ratio: 100,0%
No Data Connection (): 6 h 13 m 39 s (22419 s) Ratio: 100,0%
No or Unknown Signal (): 6 h 13 m 39 s (22419 s) Ratio: 100,0%
Screen dark (): 2 m 1 s (121 s) Ratio: 0,5%
[/FONT]
Ich lege mein S3 meistens abends zur Seite und schaue mir das dann morgens an. Dann habe ich sehr gute Werte.
Reaktionen: TheDud3
habe ich bei beiden auch so gemacht liegen ja bei beiden ca 6h
in dem zeit raum habe ich nul was gemacht
so wie ich den CM11 kernel vorgegangen bin , bin ich auch mit dem anderen kernel vorgegangen an den kernel an sich habe ich nix verändert be CM11 gehts eh nciht
Richtig gemacht. Ich lese auch nie unter 6h ab. Da hat man realistische Werte. Es freut einen dann zu sehen das der Akku nichts verliert wenn alles richtig eingestellt ist.
Werte sehen doch gut aus. Würde ich nichts mehr dran herumbasteln. :winki:
nur das ich bei Boeffla Kernel
auf 98% komme
und beim CM11 kernel 95,5%
verstehe ich irgendwie nicht
Weil der Boeffla mehr Einstellungsmöglichkeiten hat als der CM Standard. CM= VW. Boeffla = Ferrari. Nur mal so als Vergleich.:smile:
@Matthias:
laut Beschreibung : CWM und TWRP. Aber ich würde es an deiner Stelle einfach mal frech versuchen.
also das der Boeffla Kernel
schneller ist also wenn
wenn man die standart werte läßt hab ich fest gestellt.
aber beim surfen oder zum telefonieren
oder mal nintendo ds spiele spielen dafür mus ich den prozesor auch nicht übertackten ^^
gibt es aber was um den CM11 kernel zu übertackten ?
also ein app
zb mit setCPU kann ich den prozesor nicht übertackten
Der CM Kernel ist so eingestellt wie er ist. Du kannst da nur unter Einstellungen --> Leistung ---> Prozessor ---> Governor was machen. Die Taktraten sind nicht so variabel einstellbar wie beim Boeffla. Du hast beim CM eben nicht diese Vielfältigkeiten.
buffalo schrieb:
Nein, habe die apk gleich drübergebügelt, werde jetzt mal de- und reinstallieren.
Nope, alles wie vorher. Sogar die Einstellungen blieben erhalten.
Habe jetzt nach Deinstallation auch noch die berühmten zwei Wipes durchgeführt, alles wie vorher.
@ Mustang
Also das gibt es bestimmt. Aber ich finde z. B. die Soundeinstellungen die man beim Boeffla Kernel machen kann einfach genial. Da hat der Entwickler schon eine Menge heraus geholt. Oder das man den zRam aktivieren kann und einstellen. Das sind schon so ein paar Sachen, die mit dem Standard Kernel halt nicht gehen.
Aber wie schon mehrmals gesagt, les dich mal in den Kernel ein. Und es ist kein muß nur ein kann. Und wenn du mit dem Standard soweit zufrieden bist und die laufzeit und alles drum herum in Ordnung ist, dann bleib dabei. Niemand wird dir einen Strick daraus drehen oder dich verachten.
Gruß Matthias
@buffalo:
Welchen Govenor hast du gewählt?
zzmove und das Profil zzmove - battery extreme yank
Das ist schräg. Hast du ne andere Hardware als ich? :biggrin:
Reaktionen: buffalo
ok danke dir
ich denke für mich ist der tägliche gebrauch der CM11 kernel geschikter ich surfe viel wenn ich auf arbeit bin spielen tuh ich so gut wie nie.
wollte aber das CM team nicht was einbauen so ein Booster oder sowas ? weiß man da schon etwas mehr ?
@Matthias1968
das einzige was mich etwas stört ist bei poweramp
das ab und an mal vor kommt wenn ich musik höre ein kurzes gestope von weniger als 1 sec
hoffe du weißt was ich mein so an sich bin ich auch mit dem zufrieden
Der soll kommen. Nur weiß keiner wann und wie. Ich halte die Changelogs der täglichen Nightlys im Auge. Im Augenblick geht es wieder ein wenig ruhiger dabei zu. Man merkt das man sich in Richtung M7 bewegt.
@Mustang
Ich weiß was du meinst. Und ich weiß auch, dass dieses Problem unter Stock Rom bei einigen auch vorgekommen ist. Aber ich weiß nicht mehr, wie das behoben wurde und womit, weil ich dieses Problem auch noch nie hatte. Nutze auch Poweramp.
Matthias
Matthias1968
ok danke als ich auf 4.3 war da hatte ich es auch aber ich habs weg bekommen durch einstellungen von poweramp
nur seit ich auf 4.4.2 bin bekomm ich dies leider nicht ganz weg ist zwar nicht so mega schlim aber ganz bisele nervig ja schon :D
The_Voice_70
wie genau ist das mit booster
wird durch klick die cpu schneller oder was genau ist da mit bosster gemeint weißt du da mehr oder hab ich da was falsch verstanden ?
