WxK
Dauer-User
- 963
Dies ist eine auf CM11 basierende Rom. Sie wurde für all die jenigen entwickelt die viel einstellen möchten. Die Firmware bietet Real true -HD DTS Sound und HD display Optimierungen, perfekt für Spiele, Videos und Musik!
Multitasking und performance steht bei Sonic Open Kang an oberste Priorität!
Features
Mediafearures
Installation
Changelog
Download
Cyanogen Mod 11.00 Based.
Option to Hide Notification Lables
Notification Transparency
Contextual Notification Panel Header
Notification Power Widgets with changeable background and icon colors
Tiles layout customization with quick pull-down,smart pull down,quick collapse.,background and icon color options
Status Bar Customizations like Battery icon,Clock and Date,Status Bar colors
Network Traffic Meter
Signal Text Color,Hide Signal Bar option
Custom Carrier Lable
Double Tap to sleep Option
Breathing Sms Notification
Breathing missed cal notifications
Breathing voice-mail Notification
Customizable Low battery warning
Limit the notification sound of each application
Screen on Notification Light(enable/disable)
Custom System Animations
CRT Animation
List view Animation
Toast Animation
IME Animations
Multiuser Support in lock-screen security
screen lock options
Lock screen themes for rings and elements
Customizable Slider Targets and Shortcuts with Eight slider Targets
Lock Screen widgets with maximize and minimization option
Phone encryption
Lock Screen Notification Access control
Lock Screen Notifications
Customizable Lock Screen Icons
Lock-screen Power menu
Transparent & Blur Lock-screen
Lock Icon Torch
Halo floating Notifications
Customizable Power menu with lots of options
Advanced Display control Configure your screen colors
Chameleon OS Active Display
Gesture Navigations
Chameleon OS Gesture Every where
Customizable Navigation bar with Navigation Rings'
Custom Progress bar make your own color full progress bar
Slim PIE control
Chameleon OS Identicons
Recent View customization can chose stock or Slim recent view with memory indicators,clear all button
Customizable recent panel color
Build Prop mods enable disable option menu
INIT.D mods enable disable option menu
System Application remover
LCD Density Changer
Wake lock Blocker
Suspend Action When screen goes off
Scrolling Animations
Disable full-screen keyboard option
Recent ram Bar with customizations
Media Scanner Behavior Controller
Option To Disable FC Notifications
Default App grip option
Dual Pane options
Do not disturb option
Show notification count
Kil app back button with customizable timeout values
High end graphic effects option
Dark SOKP UI
App Permission Options
Advanced Kernel Tweaker Instead of Performance control with lot option to control CPU & GPU
GPS Location Fix
Build Prop Editor
Seeder Entropy Generator
X-Posed Framework
Per Application DPI
HyBrid UI>>>Phablet And Phone UI
Omni Duel Split Screen
Unlimited Floating Multi window
Network Connection Manager
Status Bar Battery Bar
Status Bar Brightness slider
Cast Screen
Screen Recorder with Audio option
Adoptive Back light
Privacy Guard
Sony Xperia Z2 application like Sketch (Pen Supported),Tasks,Converter ,Car launcher.
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Superuser fully embedded into the build and accessed from settings menu
Enable/disable wake up on charge option
insane amount of edits/tweaks/fixes to make this ROM absolutely fly
option to disable/enable vibrate on expand for notifications alerts
Numerous other options hiding throughout the Rom......will updated when i remember more
CRT Animation
List view Animation
Toast Animation
IME Animations
screen lock options
Phone encryption
Lock Icon Torch
Gesture Navigations
Slim PIE control
LCD Density Changer
Wake lock Blocker
Dual Pane options
Dark SOKP UI
GPS Location Fix
Build Prop Editor
X-Posed Framework
Per Application DPI
Cast Screen
Adoptive Back light
Privacy Guard
Mediafearures
X-Reality Engine Personally Ported from Xperia Z2 To En-chase True HD Display
Pure HD Theater Mode Video Rendering Enabled with High end graphic effects option
Latest Sony Walkman Player From Xperia Z2 With Clear Audio+
Latest Sony Movies & Album From Xperia Z2
Digital Dolby Ported From HWAUIE ACSEND P6 k3v2oem1
Unique DTS HD Audio System Designed By Me For True HD Sound.......Feel Your Ears Blessed.
Audio FX Widget As Standalone Equalizer For Music ,Video,Gaming Sound.
Installation
RECOVERY TWRP: Wipe Cache / Factory Reset
Install ROM
Install Gapps
Wipe Cache Partition
Wipe Dalvik Cache
Reboot
Install ROM
Install Gapps
Wipe Dalvik Cache
Reboot
Changelog
SONIC OPEN KANG PROJECT SOKP
CHANGE-LOG (Noteable new features)
#SOKP -KK443 RC-04
Android KitKat -4.4.3 KTU84M
TRDS-3.0
Peek
Hover
New CM Theme Manager
Theme Showcase
Rom Statistics
Sonic Papers
Launcher-3 with hotword Recognition*
App Circle Bar
New Sonic Control
AOKP Rom control
On-The -Go
Scrolling modifiers
New Halo
Omni switch which can be used as recent
Active Notifications
Tile colors
App Bar
Ad Blocker
Aokp Toggles
navigation Rings*
Ribbons
Updated DTS Engine
One Plus Camera
One Plus Gallery*
One Plus Theme
#SOKP Milestone-1
Re-added Daydream option in display settings
Implemented SOKP settings,Halo,lock-screen icons
Implemented SOKP Plat Logo
Added Omni Switch
Smart Phone Cal (Put on your ear ,and this will automatically cal current number in the message or dialer)
New Advanced control application in sokp controls
Updated X posed frameworks and Modules to latest
Added Per Application font
Implemented* Battery *Calibration .(Advanced Control)
Added Option to Wipe Cache and Dalvik cache with our rebooting to Recovery.(Advanced Control)
Added Common SOKP official Boot-animation to all devices.
New Busy and shut down animations
Added Sokp default official wallpaper to framework
Animation Scale reduced from 1 to 0.75 to*speedup the overall UI
Implemented Lock Screen Shake Security and Timer.
Added Accept all files options for incoming files via bluetooth
Removed Brodcast from QH Toggles
Fix for crash in location manger Service
Add pause, resume and stop functions *downloads application.
Added Security commits in settings
Fixes For Battery Saver Mode
Re-Added Missing Clock Application in RC-03
Removed Epic And Inspire launcher and added apex launcher as rom default launcher.
Added Some of The official Sonic-Developers Book marks to default browser.
Enabled Lock-screen rotation by default
Enabled show lock screen before unlock screen (PIN/pattern/password).
Some Fixes for stability.
Updated source to latest.
#SOKP RC-03
Fixed Display Settings force close in all devices
Fixed custom carrier label
New CM11 theme pack
Fixed issues of Sound Pack
Added On-The -Go**Service
Added Notification power widget
Added Notification shortcuts
Added SOKP PIE to power menu so that pie can be enabled and disabled from power menu
Added Netflix Workaround
Upgraded X-Floating Halo
Fixed Unknown *LCD Density text in LCD Density changer
Added Gesture supported Inspire Launcher As experimental
Disabled Some of the duplicates options in settings
Implemented some tweaks to improve audio quality
some minor tweaks to improve the stability of rom
Fixed USB Tethering issue in Note-2
Some minor Changes in system Graphics.
Removed Sony Media Applications from rom*
#SOKP RC-02
Integrated voice+ *info settings
New theme item to personalization menu
Fix LTE Power widget
Allow Power Notification Sounds for wireless
slim recents pass gesture detector to the card list view
Implemented Black list provider permission
Implemented Navigation Bar IME cursor
User configurable default expanded mode in slim recent
Fixed some force closes
Added epic Launcher as default launcher
updated cm changes in source
#SOKP RC-01
Android KitKat 4.4.2 -R2
Initial Build Taking Beanstalk and Cyanogen Mod-11 With Some New Cherry Picks
#SOKP -KK443 RC-04
TRDS-3.0
Peek
Hover
Theme Showcase
Rom Statistics
Sonic Papers
App Circle Bar
New Sonic Control
AOKP Rom control
On-The -Go
Scrolling modifiers
New Halo
Tile colors
App Bar
Ad Blocker
Aokp Toggles
navigation Rings*
Ribbons
Updated DTS Engine
One Plus Camera
One Plus Gallery*
One Plus Theme
#SOKP Milestone-1
Added Omni Switch
#SOKP RC-03
New CM11 theme pack
#SOKP RC-02
#SOKP RC-01
Download
