myreality
Enthusiast
- 3.898
Wenn Xplodwild den Thread fertig bekommt dann noch heute.
Wenn nicht dann morgen
Könnt ja mal Faryaab Sheikhs twitter Account checken
xXRobinhoXx schrieb:Gerade bei Twitter gepostet worden.
Freu mich schon auf die erste Experimental![]()
MikaKing schrieb:Ja, die sind aver nur für Amerekanische Galaxys
macspoiler schrieb:Nur schonmal um das zu klären. Von Miui kommend kann ich doch sicher direkt cm10 flachen oder muß ich den Umweg über eine Stock gehen? *schäm*
kalti1977 schrieb:naja bin gespannt ob die alltagstauglich ist.
mal guggn![]()
Gleich kommt schon die zweite Version heraus.... In wenigen Minuten... Ich würde euch empfehlen noch ein paar Minuten auf die neuere Version zu warten![ROM][GT-I9300][4.1.1] CyanogenMod 10 -PREVIEW- CyanogenMod is a free, community built, aftermarket firmware distribution of Android 4.1 (Jelly Bean), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include <std_disclaimer.h> /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. Hard. A lot. */
PREVIEW DISCLAIMER:
This is a PREVIEW : CyanogenMod 10 is nowhere near ready to be used as a daily driver (lots of features still have to be merged), and same is the device support. CHECK THE KNOWN ISSUES LIST BEFORE THINKING ABOUT POSTING.
IF YOU ARE BITCHING WITH "When this will be fixed!!!!?????" THEN I'LL JUST CLOSE THE THREAD AND YOU'LL HAVE TO WAIT EVEN MORE.
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
Quote:
KNOWN ISSUES
- FMradio, heh!
- Camera is unstable, though taking pics should work
- Wi-Fi tethering is semi-broken
Quote:
HOW TO INSTALL
- Make sure to run CM9 so you know you have everything
- Download the zip
- Download Gapps
- Install the update zip from recovery
- Install gapps
- WIPE DATA/FACTORY RESET
- Reboot
Quote:
SCREENSHOTS
Quote:
DOWNLOADS
Gapps package (also in preview):
http://d-h.st/fMY
Preview #2:
BBQDroid Download Cluster: http://cm10.bbqdroid.org/cm-10-XPLOD...EW-2-i9300.zip
Dev-Host: http://d-h.st/UZx
Quote:
SUPPORT
If you're encountering a bug that isn't listed above, make sure to attach a logcat with your report. If you don't know how to do it, then refrain from posting. Once again, if this thread is becoming a hassle for me, then I'll close it right away. And remember that CM10 IS A WORK IN PROGRESS. No complaints for missing features either.
Also, a donation on the www.teamhacksung.org webpage is really appreciated. Thanks!
"@xplodwild: Oops, false start for preview build 1 - the number 2 comes in just a minute."
