PJF16
Ehrenmitglied
- 10.817
- Themenstarter
- #21
Mal sehen wie es beim I9300 aussieht. Muss da ja nicht gleich wie beim I9100 sein.
https://plus.google.com/117962666888533781522/posts/BMQiaHhSMte[B]Jelly Bean Status Update[/B] schrieb:Repositories for all AOSP projects have been created on our github to alleviate any potential mismatches (branch is 'jellybean').
While Jelly Bean won't require a major rewrite of all the CM features, the source has been re-arranged and re-factored enough that a simple merge isn't possible. So we will proceed with manual merging (this was to be expected really).
The plan of attack will be to cherry-pick everything from CM9 and fix the merge conflicts and relocations. Its tedious but the only way. Ideally the original patch authors will forward-port their changes, so if you are out there and want to help out, join us in #cyanogenmod -dev.
+ Trebuchet might be messy to rebase onto JB.
+ Theme Engine will be messy.
+ SystemUI stuff will need to be restyled.
+ Lockscreen stuff will need to be restyled.
+ The current UX of Settings is good, no reason to change anything there.
A manifest (Cyanogenmod/android.git) will be going up later this afternoon, so the masses will be able to sync directly from our source at that point as well.
This will be it on the updates (so we can focus on actually working). Next post referencing JB should be when the merge/cherry-pick process is complete.
-CyanogenMod Team
Incompatible binarys.
Will result in no audio, no camera, no hwcomposer, no video codecs...
Enough said?
Let's wait for samsung.
Steve Kondik schrieb:I'm pretty impressed to far with the work that's gone into the Android HAL in Jelly Bean. It looks like there is the beginning of versioning support, and the graphics HAL is on-par with what OEMs are needing. The new display drivers for Qualcomm devices on JB don't require any framework changes at all, they just work. In the past, there were dozens of patches to implement specific optimizations for their hardware. I suspect that the PDK may be working![]()
--noname-- schrieb:Das dauert also noch lange...
