[ROM][AOSP][LINARO] CarbonRom 1.8 JB 4.2.2 [01. AUG]
  • 132 Antworten
PlaYOuT
PlaYOuT
Dauer-User
72
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods,
übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
CarbonRom is an aftermarket firmware based on the Android Open Source Project. The team is composed of former members of Team Liquid who have forked the code in an attempt to bring greater speed, better coding, and full authorship to code. We are in no way affiliated with Liquid0624. The rom was forked at Liquid beta 3.2.1 and has since undergone major code changes and modifications. Please note that on some devices the kernel is not yet linaro compiled.
We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Please feel free to look at, build, and use our code on CarbonDev GitHub.
We would like to thank CyanogenMod for their device trees, framework/settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
Special thanks also go to Slim Rom for some of their features, PA, AOKP, and anyone else we may have borrowed commits from that hasn't been mentioned here. If you feel you have been unfairly left out, please - let us know.
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device, family, pets, or perception of reality. We ask that you do your part to know your device and know how to recover from problems before you flash! If you have questions, ask your fellow users or ask us in #teamcarbon on freenode IRC.
Features:
Android 4.2.2
PIE
Xposed Framework (May cause stability or performance issues - use at your own risk!)
Comprehensive speed enhancements, including Linaro -O3 and processor-specific optimizations
Unofficial Voodoo Sound support on Note 2 and i9300 devices.
Option to hide lockscreen hints
Carousel lockscreen
Customizable lockscreen buttons and sliders
Chronus clock widget
Customizable hardware and software keys
Transparent navbar and status bar
Customizable navbar ring
Navbar arrow keys
Navigation bar widgets
Customizable power menu
Notification power widget
Notification brightness adjustment
Customizable quicksettings panel
Statusbar mods including center clock and color
LCD Density
Theme engine
Quiet hours
Volume rocker music controls
Full Rotation
Customizable battery and notification light
More that haven't even been mentioned, and more to come!
Screenshots:
Download Carbon:
All Carbon downloads and further information such as features can be found on our goo.im page.
Goo.im Downloads - Browsing carbon
Die Rom findet ihr auch bei XDA
[ROM][AOSP][LINARO] CarbonRom 1.4 JB 4.2.2 [i9300] » Feb 24 - xda-developers
Rom Entwickler : https://github.com/CarbonDev
Man sollte die international Variante flashen. Die ist für uns gedacht. Ich hatte die kurz drauf, aber war ziemlich verbugt.
Das Problem ist bekannt, aber nur bei der internationalen Variante.
Homebutton funktionierte nicht und das Internet öffnete sich nicht.
Vielleicht hatte ich auch nur Pech. Denn Linaro ist ein interessantes Thema.
Hoffe das es mal mit einem Update funktioniert.
Was hast du für ein Problem mit der hometaste Rom funktioniert bei mir einwandfrei ;)
Also bei mir läuft die Rom auch ohne Probleme, konnte bis jetzt noch keine Bugs veststellen.
Lg
Hmm. Keine Ahnung warum ich dann das Problem hatte. Wie seit ihr denn vorgegangen, bin auf der Hells Rom?
Factory Wipe , und dann einfach Installiert .
Also im CWM factory Reset, format cache/dalvik? Außerdem hatte ich auch kein Lockscreen und in der Benachrichtungsleiste war nichts drin.
Sonst zu frieden mit der ROM?
bei mir kommt beim ersten start nach dem flashen kein bootlogo komplett schwarz war das bei euch auch so? habe kompletten full wipe durch geführt
Da steht Du hast das S2 und das Tab...ist das aktuell?
ja ist es bin grade dabei das galaxy s3 von einem kumpel zu rooten
Ihr müsst auch die richtige Rom laden, es gibt mehrere Versionen.
Ihr müsst die Version für das internationale I9300 laden.
Lg
Ja das hatte ich auch. Falls du mich auch meinst :). Ich probiere es einfach nochmal.
EDIT: So jetzt funktioniert es. Obwohl ich wieder das Problem hatte. Erst nachdem ich einen Factory Reset und die Google Apps geflasht habe funkt es.
Reaktionen: PlaYOuT
hab mal ne frage. auf dieser seite Goo.im Downloads - Browsing carbon
werden ja die downloads angebenen. nur weis ich nicht welchen ich nehmen soll,
die version für International - i9300 oder die temobile version.
habe ein s3 von der telekom. Normal ist ja die telekom firmware drauf aber zur zeit habe ich eine andere custom rom drauf.
Fürs i9300
rom ist drauf hat super geklappt aber !!!!! irgendiwe kommen keine Facebook Benachrichtigung und Nachrichten an :-( aber Benachrichtigen sind in den Apps aktiviert.
weiß jemand rat?
Sync aktiviert?
ja whatsapp geht ja auch normal
Sehr gutes ROM, absolut empfehlenswert!
Habe mal ne Frage. Ich möchte diese Rom ausprobieren. Wird auch Exfat unterstützt ?
Ich möchte meine SD nicht neu machen.
exFAT dürfte es eigentlich nicht haben.
Reaktionen: störte
