[ROM][AOSP][JB][4.2.2][JDQ39E] SuperNexus 2.0 - I9300 - Milestone 1 [01-06-13]
  • 369 Antworten
-FlashFreak-
Gast
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods, übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
ROM Features:
  • Fully Deodexed
  • Zipaligned APKs
  • Rooted (Super SU)
  • BusyBox Installed
  • No 3rd Party App
  • ZERO Bloatware
  • Android Source Code vastly improved and optimized (i.e. Bionic, Dalvik, Webkit, Framework, libcore, SQlite etc)
  • Official Jelly Bean Bootanimation (From Official Galaxy Nexus Android 4.2.1 Factory Image)
  • Init.d Support
  • Rsync Support
  • UserInit Support
  • Bash & Nano Support
  • Native SIP/VOIP Support
  • OpenSSH Support (ssh, sshd, scp, stfp)
  • HSPA+ Support
  • OpenVPN Support
  • Ad-Hoc Network Support
  • EXT4 File System Optimizations
  • Large APN & SPN List
  • Framework Features:
  • Extended Power Menu (Reboot, Recovery, Download & Screenshot Options)
  • Improved Scrolling Cache
  • Tweaked Animation Values Of Progress Spinners (Silky Smooth Loading Spinners)
  • Enabled Rotation Lock Tile in Quick Settings for Phones (Previously was only enabled on Tablets)
  • Increased Lockscreen Widget limit from 5 to 9
  • Enabled Copy/Paste in Gtalk
  • Options for switching between USB Mass Storage and MTP/PTP (On Specific Devices)
Camera Features:
  • Burst Shot (Up to 20 Images at once)
  • ISO Mode
  • Touch Focus Duration
  • Power Shutter (Click Power Button To Capture Image/Video)
  • Color Effects
  • Shutter Timer
  • Zero-Shutter Lag (On Specific devices)
  • Control Zoom using Volume keys
  • Touch-to-focus timeout duration settings
  • Exposure and JPEG Quality settings in Video Mode
  • HDR (High-dynamic-range imaging)
  • Ability to choose storage location (Internal SD Card, External SD Card & USB OTG)
    Browser Features:
  • Increased Maximum Tab limit from 16 to 64
  • Incognito Tab Option (When long pressed on an URL)
  • Option To Close All Tabs With One-Click
  • Allowed Any Type Of File To Be Downloaded
  • Enabled WebGL (Ultra smooth browsing)
  • HTML5 WebSockets
    Phone Features:
  • T9 Dialer Support
  • Landscape Dialer Support
  • Transparency To Incall Screen
  • Noise Suppression
    Miscellaneous Features:
  • Allowed Installation Of Apps From Unknown Sources By Default
  • Allowed Any Type Of File To Be Sent/Received Via Bluetooth
  • Disabled Data Roaming By Default
  • Removed Google's Software Updates Option from Settings
  • Enabled Gesture Input By default
  • Hardware Information of the device (Settings>About Device>Hardware Information)
Changelog:
  • Updated source code to Android-4.2.2_r1.2 (JDQ39E)
  • Updated APN List
  • Updated SuperSU to v1.30
  • Added official device support for Samsung Captivate
  • Added official device support for Samsung Vibrant
  • D2TMO/D2ATT: Synced all CM Fixes (Should be in the same state as CM)
  • I9100/I9100G/I777/N7000/I9300/I9305: Using open-sourced RIL
  • I9100/I777/N7000/I9300/I9305: Updated Mali drivers
  • I9100/I777/N7000/I9300/I9305: Merged smdk4412 and smdk4210 kernels into one
  • I9100/I777/N7000/I9300/I9305: Updated bcmdhd (Wi-Fi) driver from GT-I9505 sources
  • I9100/I777/N7000/I9300/I9305: Enabled NFS support
  • I9305/I9300: Enabled dock support
  • I9305/I9300: Enabled stereo recording while recording video (2 Channel)
  • I9305/I9300: Fixed Touch2Focus crash in camera (No more FC)
  • I9305/I9300: Fixed front-facing camera preview freeze after initial shot
  • I9100/I9300: Fixed issue with Play Store
  • I9100: EXIF fixes
  • I9100G: Fixed exposure compensation & HDR
  • I9100G: Implement noise suppression for calls
  • GalaxySMTD: Changed Kernel to Semaphore
  • Camera: Added support for Storage Location (Internal SD Card, External SD Card & USB OTG)
  • Camera: Many translations
  • Camera: Many fixes and code cleanup
  • Dalvik: Tons of optimizations from AOSP's master branch
  • Framework: Optimizations and minor fixes
  • Framework: RIL Fixes
  • Skia: Optimizations from AOSP's master branch
Anleitung - Wie zu installieren:
  • Kopiere Google Apps und SuperNexus ROM auf Deine interne SD Card
  • Gehe in den Recovery-Modus
  • Mach ein Wipe Data/Factory Reset
  • [Flashe SuperNexus ROM
  • Flashe-Google Apps
  • Reboot, Fertig!
Downloads:
Hotfile.com: 1-CLICK Dateihoster: SuperNexus-2.0-i9300-M1.zip
Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip
Reaktionen: stevovo und -stephan-
Dann stell ich mal die Frage hier rein :D Wie läuft die FW bei euch? Ich überlege sie mir zu flashen.
Funktioniert denn Photosphere und WLAN -Hotspot einwandfrei?
Okay, die Kamera stürzt beim 2 mal ab -.-
Direkt wieder auf Stock zurück flashen...
Das mit der Kamera kann Ich nicht bestätigen, diese geht bei Mir!
Dies ist aber ein Testbuild, da kann das ein oder andere noch haken.
Aktuelle Statements von Fayaab zum Testrelease [KLICK!]
Ich hab sie mir jetzt noch mal geflasht und jetzt gehts zum Glück :)
@quasimodo
Kannst du mir sagen woher du den Wallapaper hast?
Und ich flashe noch das alte SuperNexus vor 2 Tagen. Jetzt bin ich mal gespannt wann eine Stable kommt, obwohl ich bis auf paar kleine Sachen kein Problem habe.
gesendet von meinem Nintendo 64
Werde sie auch mal für ein paar Tage testen.
Öfter mal was neues.
Kann mir jemand, bitte, bitte sagen, wie sich das bei den neuen CM oder AOSP Versionen mit dem Speicher genau verhält.
Hatte letzt mal die 4.2.1 vom Teufel probiert und damit wurde alles verändert, so das ich nicht mal mehr mein Backup einspielen konnte.
Das mit dem Backup hatte ich auch.
Im Internen Speicher befand sich ein neuer Ordner "0" da waren alle Ordner von 4.1.2 drin !!!
Einfach wieder zurück kopiert und alles lief.
Reaktionen: mareis1973
@quasimodo
@MS99,
Guggst Du Hintergrund Bilder:
Oh ich hab da gar nicht nachgeschaut :D Danke ;)
Heute im Laufe des Abends kommt ein neuer Testbuild mit BT und NFC fix und email app!
aus dem Schneesturm gemorst
Wie schauts denn nun mit Photosphere aus?Ist das schon integriert?.
Hatte schonmal irgendwo gefragt.Aber da bekam ich gesagt das es ein Nexus 4 Feature sei was aber nicht ganz stimmt.
Es ist definitiv ein Android 4.2 Feature.Also müsste es doch auch vorhanden sein.
Photosphere 4.2 feature ergo integriert!
Und funktioniert es einwandfrei in der Version?
Ich habe die Rom noch nicht geflasht! Müsste man testen
Achso...dann weißt du auch noch nicht wirklich ob Photosphere integriert ist,oder?
Ich will erst sicher gehen das es dabei ist bevor ich wieder flashe.
Ich bin mir zu 99,999999999% sicher das es dabei ist! Sonst mach ein Backup und flash!
Ich hatte eher gehofft das mir das jemand sagen kann der es schon drauf hat.Ich hab gerade Stock drauf und das ohne root.
