Scum
Moderator
Teammitglied
- 12.297
10.1 ...
-Fixed phabletUI
-Fixed stock browser and screen stuttering (we are currently test this)
-Ability to customize Navbar in TabletUI
-Some new HALO things, improvements and graphics changes
-Fixed a bug that was causing certain apps to FC when a notification appear
-Fixed JellyBam wallpapers and added AOKP, Paranoid and CyanogenMod wallpapers
-NEW Tabbed settings! Just like the S4 one!
-NEW Init.d settings
-Some more minor changes
-Bring back ListView options
-Merged CyanogenMod new display and audio settings
-New More settings
-Bring back Custom vibrations (ATTENTION: This thing can cause a process.acore FC loop. You can easy solve this by navigate to settings -> Applications -> All -> Contacts Storage -> Delete data)
-Update Android build to JSS15Q
-Improved AppOpps
-Re-designed navigation bar options on bamcontrol and allow the customization of the navbar in tablet ui
-New statusbar options: Fullscreen statusbar with customizable timeout
-New notification behaviors option
-Fix about jellybam
-Fix HALO in landscape
-Weather panel now works on tablet UI
-New animated ADB icon (thanks to andro for renaming the files)
-Many new translations
Download link:
From goo.im
From get.jellybam.com
The roms are being rolled out in no particular order, so be patient and wait for your device to roll out!
Changelog
From goo.im
Changelog
-Fixed phabletUI
-New More settings
-Improved AppOpps
-Fix about jellybam
egal danke
