mareis1973
Enthusiast
- 3.425
Erst hatte ich ein zwei kleinere Probleme, wie daß die Soundsettings in den Einstellungen abgestürzt sind u.ä. Aber nach Fullwipeinstallation alles bene vor allem, wenn Du noch den yank555 Kernel verwendest dazu.
CM Vendor: Removed SuperUser* Authored by iGio90
PA Vendor: PA Prefs: Fix restore and backup preferences* Authored by iGio90
JELLYBAM Vendor: Embed SuperUser into settings* Authored by iGio90
JELLYBAM Vendor: New bootanimation by Iluha Tsuprun!* Authored by iGio90
System core: add 32K 64K and 128K pagesizes in bootimage* Authored by championswimmer
System core: init: create mountpoint for fuse* Authored by codeworkx
Framework: PIE: one finger swipe-up for notifications* Authored by iGio90
Framework: A way to fix navigation bar systemui fc loop* Authored by iGio90
Framework: core/jni/android/graphics: Cache copy of pre-scaled Bitmaps* Authored by iGio90
Framework: NavRing rework* Authored by iGio90
Framework: Include android.permission.ACCESS_SUPERUSER permission in the base API* Authored by iGio90
Framework: BAMControl: NavRing additions* Authored by iGio90
Framework: FM Radio: avoid deadlock when disabling RDS* Authored by iGio90
Framework: BAMControl: Notification custom wallpaper alpha and wallpaper. 1/2* Authored by iGio90
Framework: More awesome actions* Authored by iGio90
Framework: Applying ChannelScrolling to remove calculateDragAngle* Authored by kiwon
Framework: Account malloc mmaped pages as native heap.* Authored by Ian Rogers
Framework: Track stack memory in MemoryInfo.* Authored by Ian Rogers
Framework: frameworks/base: vectorize Bitmap operations* Authored by Lucas Crowthers
Framework: Enable vecorized bitmaps for all devices* Authored by aaronpoweruser
Framework: FIX Null Pointer Exception on dialog cancel* Authored by amitkec123
Framework: Update QuickSettings* Authored by drcmda
Framework: restore transparent bluetooth for xhdpi & mdpi* Authored by drcmda
Framework: SysUI: Add fullscreen/PIE toggle, change global action string* Authored by drcmda
Framework: PIE: Restart launcher* Authored by drcmda
Framework: PIE: slightly smaller as default* Authored by drcmda
Framework: pie toggle, rootbox icons* Authored by drcmda
Framework: PWM: disable HW overlays for PIE* Authored by drcmda
Framework: simplify pie toggle icons* Authored by drcmda
Framework: circle battery* Authored by drcmda
Framework: circle battery bugfixes, margins, per-app-color* Authored by drcmda
Settings: BAMControl: enable/disable stylus pointer* Authored by iGio90
Settings: BAMControl: New navring settings* Authored by iGio90
Settings: New navring layout* Authored by iGio90
Settings: move superuser up* Authored by iGio90
Settings: Fixed LockScreen auto rotate* Authored by iGio90
Settings: New CMDProcessor* Authored by iGio90
Settings: Rewrite tiles and toggles. Merged into BAMControl* Authored by iGio90
Settings: fullscreen toggle* Authored by iGio90
Settings: New PIE Option: Restart launcher* Authored by iGio90
Settings: PIE: slightly smaller as default* Authored by iGio90
Settings: BAMControl: Notification background alpha and custom wallpaper 2/2 and NavRing cleanup* Authored by iGio90
Settings: Switch to new Superuser* Authored by koush
Settings: explicitly specify the dark theme* Authored by koush
Settings: Fix up concurrent su request handling* Authored by koush
Settings: Superuser & Rom Control Navigation Ring settings icons* Authored by bliss91
Settings: Add superuser permision to settings* Authored by aaronpoweruser
yank555 schrieb:Kleines Update des CM10.1 Kernels, auf den aktuellsten CM10.1 Stand gezogen (und auch kernel.org)...
Changelog CM10.1 v1.5b :
- YankasusQ : freq_step & sampling_rate untouched in suspend mode
- ramfs : added pgrep to /sbin (fix kernel settings not set on some ROMs)
- CM10.1 kernel update : s3cfb: disable spam (codeworkx)
- CM10.1 kernel update : s5c73m3: print s_ctrl and g_ctrl values (codeworkx)
- CM10.1 kernel update : s5c73m3: only use camera fw from system if newer than on data (codeworkx)
- CM10.1 kernel update : display: updates for t0 devices (codeworkx)
- CM10.1 kernel update : melfas touch: report touch events to cypress for backlight timeout (codeworkx)
- updated to kernel.org Linux 3.0.68
Download Link (MD5 faa06a1601a071e2bc25d115612469c0)
JP.
WalterH schrieb:Hallo Leute, ich hab bam 6.5 drauf, kann aber nicht mehr telefonieren, soll heißen, es leutet ich habe verbindung aber ich und der andere hören garnichts!!!
Komme aus Österreich und verwende Hutchinson 3 (3AT) als betreiber.
Mache ich was falsch oder gibts eine einfache Lösung für einen nichtwissenden Ösi ??
Danke Vorab!!
