[ROM][20Apr] Omega v7.0 AOKP JB milestone-1Android 4.2.2
  • 99 Antworten
Ich glaube die ROM gehört in der AOSP Abteilung ;)
Reaktionen: megafabian03
New version Omega v5.0 AOKP Jelly Bean Android 4.2.2:
Based on AOKP JB 4.2.2 Build 5 with all latest updates - read changelog here
New:
Modem XXEMB5
Kernel Stock
New:
SuperUser (Settings -> SuperUser)
AddFree Android
CPU Adjuster
Accounts Sync Profiler
Updated:
Googles apps for Android 4.2.2
Google Search
Apex Launcher
Nova Launcher
ZArchiver
Online Nadroid Backup
Hide It Pro
Dropbox
Talkback
hosts
All mods and updates from previous Omega JB versions added
Rom is no full Wipe - but full wipe is highly recommended
Please read the following before flashing v5.0:
1. Make sure to make and keep in a safe place an efs backup - a nadroid backup + titanium backup, in case you need to restore.
2. Flash Omega v5.0 only with Full Wipe
3. None issues -> Torch Toggle and Torch at Power Menu Force Close
4. All AOKP & CM10 based roms does not support exFAT formatted microSD cards,
if you flash rom with a microSD card, card ends up getting corrupted & needs format
Download Center has Changed:Donation:
If you like Omega v5.0 AOKP Jelly Bean please consider a donation to help me continue this project.
Enjoy the new Jelly Bean Omega
OP update auf v5.0.
New version Omega v6.0 AOKP Jelly Bean Android 4.2.2:
Based on AOKP JB 4.2.2 Build 6 with all latest updates - read changelog here
Updated:
Google+ v3.6.0.44338848
Gmail v4.3.1
CPU Adjuster v2.9.1
Accounts Sync Profiler v1.4.0
Online Nadroid Backup script
hosts
Please read the following before flashing v6.0:
2. All AOKP & CM10 based roms does not support exFAT formatted microSD cards,
Donation:
If you like Omega v6.0 AOKP Jelly Bean and you using it please consider a donation.
Omega AOKP v5.0 had 3148 downloads and no donates and v4.2 had 6081 and 1 donate
<b>
</b>
Reaktionen: teddy3
Sagtmal was sucht diese ROM im Sammy Bereich?
Frag mich nicht, ist von nem Mod hierher verschoben worden, als zwischen Sammy und AOSP aufgeteilt wurde.
New version Omega v7.0 AOKP Jelly Bean Android 4.2.2:
Based on AOKP JB 4.2.2 Milestone 1 with all latest updates - read changelog here
New:
Omega Theme for aroma installer by our artist anbech
Floating Omegadroids by NadMaj
Added to Custom Installation:
AdFree
Cpu Tweaks
EmojiKeyboard Android 4.2
Updated:
Flash Player v11.1.115.54
Es File Explorer v3.0.0
Nove Launcher 2.0.2
Dropbox v2.3.5
Google Search v2.4.10.626027
Google+ v3.6.1.44747389
CPU Adjuster v3.0.7
ZArchiver v0.6.5
hosts
Removed:
Download all files
CM Wallpapers
onadroid backup
Please read the following before flashing v7.0:
Donation:
If you like Omega v7.0 AOKP Jelly Bean and you using it please consider a donation.
Reaktionen: teddy3
im Omega V7 Rom(die wirklich sehr gut ist!) gibt es im Rom Control die möglichkeit unter Bildschirmsperre die Schltflächen selbst zu belegen.Das zu startende App kann ich auswählen es wird auch angenommen jedoch das Icon symbol lässt sich nict ändern kennt jemand die lösung des Problems?
Evtl fragst du mal direkt im threat der Rom.
Ansonsten kann ich dir nur die App "widget locker" empfehlen, da kannst du alles nach deinem Wunsch ändern
habe das S3 mit der Coustom Rom Omega V7 Android 4.2.2, ich wollte die Bootanimation ändern habe sie über CWM im Recovery Modus gewechselt. Seit dem lässt sich das Display nicht mehr über die Powertaste Sperren kennt jemand eine Lösung dieses Problems?
Eins habe ich vergessen die, bei längerem drücken der Powertaste erscheint das Auswahlmenü PowerOff, Reboot usw. nur die Bildschirmsperre geht wie gesagt nicht.
V7 erkennt meine externe SD Karte nicht mehr (64GB ultra scandisk)... Wer eine IDEE?:confused2:
OK der Kernel erkennt nur FAT32...
Hat wer einen guten Kernel für die Version laufen, welcher auch exFAT erkennt?
lg
t.
Hat jemand ne Ahnung wann man sich die 7er wieder downloaden kann? Komm, wenn ich aufs Downloadcenter will, immer auf ne Por**seite... o.O
Edit: Okhat sich erledigt...lads von der XDA-Page runter
richtig gute ROM, vielen DAnk :) daumen hoch !!!
Seite Down?:bored:
Hey Leute... teste grade die omega Rom. Hab mit damals die v4.1 gezogen. Nun finde ich in dem Einstellungen keine update Möglichkeit. Bin ich blind? Außerdem wird mir im Handy 4.1.2 angezeigt, dachte es wäre eine 4.2.2 Rom ?
Ach, läuft die Rom mit dem boeffler Kernel? Mit gefällt der besser als der shya und dual Rom brauch ich nicht
Mhhhh kein support mehr hier?
bin nach langer Zeit mit Omegarom mal auf AOKP gewechselt und jetzt aktuell bei der Mischung dem Omega 8.1 AOKP.
Mein Problem bei den AOKP Roms ist der unterirdisch schlechte Sound in der Google Music App. Ich höre sehr viel Musik mit dem S3, so dass dies für mich ein wichtiger Punkt ist.
Der Sound in den AOKP Roms klingt einfach sehr dumpf und wenig Basslastig, komischerweiße lässt sich leider nichts am Equilizer verstellen. Im normalen AOKP hatte man in Google Music den Standard Equilizer der App aber selbst nach vielem rumprobieren klang der Sound im Vergleich zur Standard Omegarom sehr schlecht. Nun mit Omega 8.1. AOKP wird man zu dem beim Rom gelieferten DSP-Manager umgeleitet sobald man auf Equilizer in der Google Music App klickt. Nur hat hier jede Einstellung absolut null Effekt auf den Sound.
Kennt jemand eine Lösung dieses Problems? Evtl. auch Installation von anderen DSP Programmen oder Equilizern, die hier etwas bringen?
Wäre für Hilfe sehr dankbar!
Hey, ich hab nun ein echt dickes problem :D
Ich hänge im Bootloop, komme nur bis zur "Samsung Galaxy S3 - I9300" meldung und von da loopt es ständig neu.
Ich komm auch nicht in den DOwnload Modus oder ins Recovery.
Jemand eine Idee?! :D
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
