[JB AOKP][28.OKT] BAKED Blackbean V6
  • 49 Antworten
myreality
myreality
Enthusiast
3.898
Und wieder eine neue AOSP Rom. Wurde von mir bei XDA gefunden und sieht auf dem ersten Blick ganz nett aus. Dank der inverted Apps recht elegant und Akku schonend. Auf jeden Fall einen Blick wert :thumbup:
Welcome to a #teamBAKED production. Where our goal is to get you all BAKED. Black Android Kang Everyone Desires that is.
What did you really think we could include that in the rom! LOL
Unser Ziel ist es eine völlig schwarze schlichte und edle AOSP Rom zu basteln.
  • Fully built from the ground up from AOSP 4.1.2 (then cherry picked from everyone!!!)
  • Includes Rom Control (kang from aokp but made into baked style)
  • Includes Aokp Toggles (aokp)
  • Includes Powerwidgets (cm)
  • Lockscreen shortcuts 5 phone 8 tablet (cm)
  • Lockscreen weather (cm)
  • Lockscreen calendar (cm)
  • Full customized Mms app (baked)
  • Includes DSPManager (cm)
  • All system apps and Gapps fully inverted for your pleasure (baked)
  • Many many more features in and even more stuff planned to come.
Mirror 1: Goo.im Downloads - Browsing i9300
Mirror 2: Index of /i9300
GApps: BAKED downloads - (nach unten scrollen)
Changelogs hier
Anleitung:
  1. Lade das Rom zusammen mit den jeweiligen GApps herunter.
  2. Reboot in den Recovery Modus.
  3. Flashe die Rom “baked_*****_blackbean-*.zip”
  4. Flashe die “gappsinverted_******-signed.zip”
  5. Reboote
  • All credit first and foremost goes to Google for making android and making it open source.
  • CyanogenMod obviously for giving onto the hacking community everything they have given.
  • AOKP for there amazing work on aosp.
  • Big thanks to faux for his kernels are our kernls of choice.
  • Pretty much everyone else that we either cherry picked code from or borrowed from to make things work THANK YOU.
  • If you are left out and feel you should receive credit please PM or tweet us and we will include credit.
#TeamBAKED || Github || Irc || Twitter || Google + ||
  • @travp624
  • @codemonkeyjava
  • @B_boyTM
  • @mastur_mynd
  • @nycbjr
  • @Dreamsforgott3n
  • @jdlogan151
  • @dhrb23
  • @ebs512
Thread @ XDA
Reaktionen: jenzy, mba und mareis1973
Hab die mal geflashed. Sehr gute Rom mit vielen Einstellmöglichkeiten. Def. einen Blick wert. Werde sie mal noch etwas testen
myreality was schneller:D
Danke für den schönen Thread werde mal einen Blick riskieren;)
Edit:
Oh die habe ich mir der Blackstar verwechselt. Wo hast du die Rom entdeckt?
XDA gefunden.
Wurde dort gestern schon gepostet unter Original Android Development
Hab den Thread mal verlinkt im Startpost ganz unten :)
hatte mal angefragt ob nen release fuer das S3 kommt. war vor ca. 5 wochen. musste es daher auch mal direkt testen als ich gesehen hab das es released wurde, da es sich sehr gut anhoert.. und die moeglichkeiten sind echt nicht schlecht.. gefaellt mir sehr gut.. einzig Cpu Control erzeugt nen FC aber ansonsten laeufts.. :D
Nach dem ersten bzw. zweiten tag muss ich sagen
das die Rom immer besser wird.
mich wundert das die anscheinend noch keiner getestet hat.
zusammen mit dem Nova Launcher unglaublich schnell.
Kenne die Rom von Infinity wo sie super läuft. Werde sie daher auch am S3 testen.
Moin zusammen
Kann mir einer evtl. erklären, wechen näheren Sinn die PowerWidgets haben?
Ich kann ja zusätzlich zu den Toogles auch noch die PowerWidgets aktivieren.
Nur sehe ich da absolut kein Sinn drin.
Und btw: laut Google+ wird das nächste Update B6 auf 4.1.2 basieren.
Ja kann man :D
Je nachdem was einem besser gefällt
hm,
also Null Sinn, weil sehen ja beide gleich aus.
oder hab ich irgendwas verpasst. so ohne sinn etwas einzubauen,, hm
Der ursprüngliche Beitrag von 12:36 Uhr wurde um 12:39 Uhr ergänzt:
Ok hab den unterschied.
Kannst bei den PowerWidgets unter anderem HapticFeedback etc. aktivieren.
Jesses da achtet doch keiner drauf :-D
Mit der Rom hat man generell viele Einstellungesmöglichkeiten :)
auf jeden fall.
hatte bis jetzt die viking drauf und nun mal wieder gewechselt. und muss sagen super rom. schnell,fluessig und akku ist ebenfalls IO
Nur schade das die anscheinend noch immer zu wenig benutzt wird.
sehe ich ebenso ist ne hammer romxD
Fyi. V6 ist released. :D
Thread aktualisiert :)
Sieht ja mal gut aus... Werde ich mal testen... Ganz schön klein für eine Rom oder? 148mb ist ja nicht Grad groß.
Läuft wie immer super :) lief schon vorher auf meinem alten Galaxy Nexus wunderbar. Ist für mich das beste Rom. Leider aber nicht so populär wie andere Roms. Warum auch immer
du musst hier natuerlich noch die gapps flashen. zusammen fann etwas ueber 210mb ca.
Ich habe die V6 mal auf mein S3 gepackt und bin begeistert von der Geschwindigkeit . Installation war schnell erledigt ,die Gapps nachinstalliert und nur ein paar Einstellungen angepasst,fertig!
Dann noch anschließend mal nen Benchmark( so nebenbei) über Antutu gemacht und gewundert das sie noch so unbeachtet blieb!
Flott das Teil!
Wie kriege ich die Lade LED aus???
Edit: Habs mit Light Flow deaktiviert, nun kann ich pennen ;)
craP_cillA
Sossy
HOMER123
Cornmat
Cornmat
Q
quasimodo
Q
