[AOSP-ROM][JB][4.1.2]PaRaNOiA RoM[CM10Hybrid]
  • 1.996 Antworten
amo66
amo66
Dauer-User
537
timthumb.php
Team Custom Freaks presents - PaRaNOiA RoM
Credits:
- PA für die BASEROM
- customworx
- Einsteinno1
- Sakaschi [Anti RamBug Script]
- Invi
- Team Custom Freaks
- und alle anderen
Wollt ihr mir was Spenden PayPal
Diese Rom hat als Basis wie der Name vlt schon erahnen lässt [Cm10 Hybrid] Paranoidandroid.
Veränderungen entnehmt ihr bitte aus der Changelog !!
Wird immer auf die aktuellen Paranoidandroid aktuellen Versionen Updated.
Aktuelle Changelog von der jeweiligen Basis entnehmt ihr Bitte auf Paranoid Android - Home ...
Developer:
rudl1220
Tester:
hellsgod, QuirLi, MrEd, Cpt, Caddyrn
Grafik:
Inviolate
Thread und Support:
amo66
Uploader:
rudl1220
Englisch Support: Cpt
Video-How To Install PARANOIDANDROID Hybrid ROM
Youtube Video
PaRaNOiA RoM V7.3.0
Status:
ONLINE
DOWNLOAD
TCF 4.2 Gapps Full
Whats New V7.2 to V7.3
SiyahKernel v1.8.4
This Version will fixed most Problem
Fix Sound in Spotify etc..
SiyahKernel v1.8.4
Changelog:
Ported CPU UV tab from AndreiLux’s STweaks config
Dynamic generation of STweaks config and initial GPU voltages are set correctly (mostly based on AndreiLux’s uci.sh script interface while trying to keep the changes minimum to support other guys using my scripts as base)
Workaround for CRT animation problem (at the bottom of the screen tab in STweaks)
fixed the problem of copying large files that some users experience
removed custom modifications from pegasusq governor and changed the tweaked values a little
v1.8.1 -> v1.8.2: fixed gpu voltage problems
v1.8.2. -> v1.8.3: fixed problem of fb earlysuspend delay not being persisted across reboots. removed automatic installation of stweaks (you can find it on google play).
v1.8.3 -> v1.8.4: reverted VM_MAX_READAHEAD commit. adjusted cpu hotplug in/out rates in pegasusq because they were just too low after decreasing the sampling time.
Rom Standart:
-Inverted MMS.apk
-Inverted Phonebook.apk
-Inverted Phone.apk
-Inverted Calculator.apk
Added
RootBrowser New Version
SdIncrease SDCard Boost
SD-Card speed improvement
Floating Popup Browser
Dolphin Browser Beta (Fast Browser-Gesture Features)
Floating Banner
Popup Video Player
Super Manager V3.0(For PopUp Video Player)
4.2 JellyBean Full Emoji-Keyboard
....... and all that I have forgotten ;)
Hot Plugging Script (battery)
Coming soon:​
Updates in der UpdateMe​
Reading That
ParanoidAndroid v2.54
XDA Thread
4.2.1 Gapps
Inverted 4.2 Playstore,GMail und GTalk
PaRaGaPpS Black_Full_Plus++ 12/10/12
PaRaNOiA_GaPpS 12/10/12
PaRaNOiA_MiN_GaPpS_12/10/12
PaRaGaPpS_White_12/10/12
Anmerkung
Paranoid DPI Backups nicht Restoren!!
Bei Siyah(STweaks) den Ladestrom für USB höher stellen.
Sonst kann es zu Probleme beim Laden über USB kommen .
STweaks-Misc-USB Charge - +mV (zb +650mV) --> Dann ladet das S3, wenn man es an einen USB-Anschlussanschließt schneller!
Neue PaRaNOiA RoM Aroma Apps
Download
Installation
CWM
--Wipe Data/Factory Reset
--Wipe Dalvik Cache
--Flash Rom
--Wipe Cache
--Wipe Dalvik
--Fix Battery Stat.
--Fix Permission
--Reboot
Wer von einem JB Leak kommt, der sollte am besten eine Stock ICS per Odin flashen: Danach nach der Anleitung vorgehen.
MODEMS
Dualboot Tutorial:
Es ist so weit, Dualboot gibt es jetzt auch für unser S3. Einige fragen sich jetzt sicher, Dualboot...? Was ist das denn? Mit Dualboot ist es möglich zwei Roms auf dem Gerät zu haben, und beim Start auszuwählen in welches man booten möchte. Es sind jegliche Kombinationen möglich, also Stock und AOSP.
Wie richte ich Dualboot ein? Ladet euch den aktuellsten Siyah Kernel von hier Bitte darauf achten, dass ihr den S3 Kernel nehmt! Bei der Version 1.7b2 sind Kernel und Recovery dabei. Seit 1.7b3 braucht man das Siyah Recovery nicht mehr! Es ist nun über STweaks unter dem "Dual Boot" Tab beim drücken auf "boot into 2ndROM recovery utility" möglich Dualboot einzurichten.Im Siyah Recovery (über STweaks erreichbar) gibt es dann zwei neue Menupunkte: "kernel specific options" - Um init.d Scripte und STweaks Einstellungen zurückzusetzten und die "dual-boot options" - Der für uns relevante Menupunkt. In den "dual-boot options" gibt es dann folgende Menupunkte:
View current status: Hier wird die CWM Version angezeigt, sowie freier Speicher und ob ein 2nd Rom aktiv ist, wenn ja, welches.
Clone 1stROM to 2ndROM
Clone 2ndROM to 1stROM
Remove 2ndROM
Swap 1stROM and 2ndROM: Hier kann man die 1st und 2nd switchen
Format 2ndROM system
install zip to 2ndROM from internal SD: Eine Rom oder z.B. die gapps bei CM10 vom internen Speicher direkt als 2ndROM flashen
install zip to 2ndROM from external SD: Eine Rom oder z.B. die gapps bei CM10 vom externen Speicher direkt als 2ndROM flashen
Wipe 2ndROM data/cache
Wipe 2ndROM dalvik-cache
Fix 2ndROM permissions
Backup 2ndROM (ext. SD)
Restore as 2ndROM (ext. SD)
Backup 2ndROM to internal SD
Restore as 2ndROM from internal SD
Um jetzt ein zweites ROM anzulegen, gibt es drei Möglichkeiten:
1. Möglichkeit:
Du hast nun RomA und möchtest noch ein RomB. Du öffnest STweaks, gehst zum "Dual Boot" Tab und drückst auf "Reboot into 2ndROM recovery Utils", um ins Siyah Recovery zu kommen. Dort machst du dann in den dual-boot options: "Clone 1stROM to 2ndROM" Damit wird dein aktuelles ROM geklont. Danach hast du also RomA doppelt. Sobald der Vorgang beendet ist, gehst du zurück ins Recovery und machst einen Full Wipe (format system, data/factory, dalvik cache) und flasht deine RomB und den Siyah hinterher. Siyah nicht vergessen, sonst geht Dualboot nicht! Danach machst du noch "fix 2ndROM permissions". Nun ist RomA 2nd und RomB 1st. Wenn du es umgekehrt möchtest, dann gehst du in die "dual-boot options" und machst "swap 1stROM and 2ndROM", damit werden die ROMs getauscht. Wichtig dabei, dass du mindestens noch 1.5GB freien Speicher hast, da eine ROM in ein temporäres Verzeichnis kopiert wird. Wenn du nun aus dem Recovery gehst und neustartest, kommt ein 3 Sekündiger Countdown wo du aufgefordert wirst innerhalb von 3 Sekunden den Home Button zu drücken um ins 2ndROM zu booten. Drückst du den Home Button nicht, startet die 1stROM. Herzlichen Glückwunsch, du hast nun zwei ROMs!
2. Möglichkeit:
Mit dieser Variante kann es zu Problemen kommen, wenn der Updater Script vom Rom die "/data" Partition mountet und unmountet. Ihr könnt es probieren, falls die Rom aber nicht startet, dann müsst ihr es mit Methode 1 machen. install zip to 2ndROM from... ist primär dafür gedacht Mods über das 2ndROM zu flashen ohne dass man swappen muss.
Du hast nun RomA und möchtest noch ein RomB. Du öffnest STweaks, gehst zum "Dual Boot" Tab und drückst auf "Reboot into 2ndROM recovery Utils", um ins Siyah Recovery zu kommen. Dort machst du dann in den dual-boot options: "Wipe 2ndROM data/cache" und "Format 2ndROM system". Danach gehst du auf "install zip to 2ndROM from internal SD oder external SD, jenachdem wo du deine Zips hast, flasht die RomB und den Siyah hinterher. Siyah nicht vergessen, sonst geht Dualboot nicht! Danach machst du noch "fix 2ndROM permissions". Wenn du nun aus dem Recovery gehst und neustartest, kommt ein 3 Sekündiger Countdown wo du aufgefordert wirst innerhalb von 3 Sekunden den Home Button zu drücken um ins 2ndROM zu booten. Drückst du den Home Button nicht, startet die 1stROM. Herzlichen Glückwunsch, du hast nun zwei ROMs!
3. Möglichkeit
Du hast RomA und möchtest noch eine RomB. Du öffnest STweaks, gehst zum "Dual Boot" Tab und drückst auf "Reboot into 2ndROM recovery Utils", um ins Siyah Recovery zu kommen. Dort machst du dann (wenn du ein Backup von einer Rom hast, welche du mit Dual Boot nutzen möchtest) in den dual-boot options: "Restore as 2ndROM". Das Backup sollte wiederhergestellt werden, und dann 2ndROM sein. Um die Reihenfolge zu ändern, swappt ihr die Roms einfach.
HowTo Install-English
CWM: YOU NEED TO FULLWIPE IF YOU WERE USING ANOTHER ROM BEFORE
Download last PaRaNOiA RoM
CWM: Install possible Mods/Patches:
New HW Composer (MIGHT be smoother, thanks to VSync. Caution: Fullscreen Video Playback hangs)
Undo=Old HW
Download Gapps
Install CWM
Wipe Cache Partition
Advanced/Wipe Dalvik Cache
Reboot and edit your Apps Dpi & Layout under Settings/Paranoid Settings - DO NOT RESTORE YOUR OLD PROPERTIES FOR NOW
If you're facing issues, please Fix Permissions
Installation Anfänger gerecht
Ladet euch die Zip auf eurem Pc.
Kopiert die PaRaNOiA_RoM.zip auf Eure SD-Karte.
Nun Startet ihr das SGS3 in dass Recovery System.
Führt ein Nandroid Backup aus.
Danach einen Full Wipe ausführen. (Wipe data/factory Reset, format cache, format system, format data)
Nun wählt ihr die Zip von eurer SD Karte. (install zip from sdcard -> choose zip from sdcard)
Beim ersten Versuch die Rom zu flashen kann es vorkommen das der flash nicht funktioniert ist ein Fehler von der 1.9.9.2 ! Einfach advanced —reboot recovery und neu flashen dann funzt es !!!
Installiert dann über die selbe Methode auch noch die [Gapps] Google Apps und den neuen oder alten HW Composer[Old empfohlen , sonst kann es zu Microruckler geben]
Wiped den Cache nochmal zur Sicherheit und unter Advanced findet ihr noch Wipe Dalvik und Fix Permissions, auch nur zur Sicherheit noch dazu ausführen.
Reboot und Spaß haben
Der Musicplayer gibt keinen Muks von sich?
Flasht den Acid v2 Mod aus der UpdateMe und es läuft wieder!
Was ist zu tun wenn Wlan nicht funktioniert
CM10 ODIN Version von hier runterladen und mit ODIN flashen: klick Danach nach Anleitung oben Paranoia ROM flashen.
einstellung---display---bildschirm ausrichtung 90 180 270 0
einstellungen-----system---navigationsleiste----softbutton aktivieren
einstellung--design ---theme wählen
einstellungen ---paranoid setting ---workspace und auf med tablet ui
Weder Ich Das Team Custom Freaks ,Paranoidandroid noch Android-Hilfe.de ist verantwortlich für SCHÄDEN die ihr euch beim Flashen zufügen könntet ..
Hier gilt wie auch bei allen anderen Custom Roms. Nur ihr seit für euer handeln verantwortlich!!
Spender:
Satarius x2, db_cooper, WickedSICK, steuerboy, S3Vati, gewürzwiesel, m1ch4, FlolB, LaBro83, seer
Wollt ihr, mir für meine harte Arbeit,
ein Bierchen Spendieren HIER
Bitte immer euren Nicknamen und die Rom eintragen!
Dann kann ich euch gleich im Spenden Spoiler eintragen
Reaktionen: monstermagnet und rudl1220
Gleich mal gelistet: Ubersicht derzeit bekannter Jelly Bean AOSP Roms
Post 3
Reaktionen: rudl1220
auch wenns unprofessionell ist ... mir egal ..... aber bei der rom ..... freihändig ..... kleenex ... danke fürs gespräch ;)
selten so was tolles in händen gehabt :)
Reaktionen: gewürzwiesel, quirli89, EdleRatte und eine weitere Person
Freut mich echt sehr das euch mein Rom , gut gefällt !!! :thumbsup:
Gruß Rudl
Muss mred33 recht geben...
Ich glaub ich bin verliebt... ;-)
Hab die Rom seit gestern abend darauf.
Läuft wirklich einwandfrei.
Hab den alten Hw-conposer darauf.
Auch Akku ist super. Bin seit über 4 std im akkubetrieb und display war fast eine std an.
Akku jetzt bei 84% :thumbup:
Hoi
Kann mir jemand nen Link zum Old-HWComposer posten? Die oben genannten rennen bei mir immer ins Nivana. Ausserdem habe ich wohl leider den WiFi-Bug. Versuche nun mal alles von komplett neu zu machen.
Ps.: Der Wifi-Bug hat sich jetzt nach dem 4. Flashen wohl in Luft aufgelöst :D
Danke schon mal
Humbug26 schrieb:
Hoi
Danke schon mal
New und Old Composer auf RapidShare uploadet ..
Reaktionen: Humbug26 und akaebi
@akaebi
Dake aber eben dieser Link funktioniert bei mir nicht
@rudl
Danke dir auch..hab mir gleich beide gezogen ;)
rudl, wie lange betreust du denn deine rom?
Also wenn es euch gefällt ,werde ich sie soooo lang aktualisieren und updaten wie ihr auch freude daran habt sie zu Flashen ;)
Mein haupt ziel und idee ist es, die base Rom von paraniodandroid so anzupassen .
Das es so gut wie es geht ,ein S3 tablet zu machen !!
In Vordergrund wird immer die Bedienbarkeit und nutzbarkeit sein .....
Manche werden zwar meinen das s3 ist zu klein doch ich finde das echt gar nicht !!
Durch die angepasste Bildschirm Auflösung sogar besser bedienbar als die base von paraniodandroid !!
Für Verbesserungsvorschläge habe ich immer ein Ohr und wer mich gerne unterstützten will gerne !!
Hoffe ihr habt lange Spass an meinen Rom ,so werde auch ich Spaß daran PaRaNOiA ständig zu bearbeiten,updaten ......
und den gewissen S3 tablet Stempel auftragen !!!
Happy flash grüße Rudl
Muss jetzt auch mal meinen Senf dazu abgeben...
Ich nutz die PARANOIDANDROID v1.992 seit Release als zweit Rom mit diversen Gimmicks und bin echt begeistert.
"Deine" Rom hier ist bis jetzt Quasi die selbe, nur mit irgendwelchen Apps die sich jeder nachinstallieren kann.
Also eine Rom zu klauen die dann mit Apps vollstopfen und dann als "MEINE ROM" zu Bezeichnen finde ich schon etwas dreist...
Nicht böse gemeint aber Dafuq :confused2:
Es wird ja jede Rom irgendwie auf einer anderen aufgebaut ....
Schon alleine paraniodandroid hat ja als Basis cm10 und es ist immer noch eine v1 daher versteht ich deine Meinung nicht ganz !!
Da bezeichne sie doch als inoffizielle paranoid oder was immer du auch willst !!!
Weiss ja nicht was du unter klauen verstehst ...
GaLAxY S3 ~PaRaNOiA RoM ~ gesendet
Du willst jetzt nicht wirklich den Sprung von PARANOIDANDROID zu CM10
mit PARANOIDANDROID zu PaRaNOiA RoM vergleichen das sind Welten Unterschiede dazwischen...
Mir fehlen bei dieser Rom einfach diverse Charrypicks, Gimmicks, Mods, Anpassungen die einen Dev oder eine Rom erst ausmachen...
Gehts nur mir so oder wird der Akkustatus "Voll" schon bei ca 90% angezeigt (Grüne LED-Farbe)? Es stört mich nicht wiklich, jedoch war ich zuerst ein wenig verwirrt, da ich nicht wusste, ob nun wirklich der Akku wirklich voll ist und die Anzeige nicht passt oder weitergeladen wird -> wird weitergeladen :)
Probiere vlt mall im CWM ----- advanced ----wipe battery stats
Hab ich schon...wollt cih eigentlich auch dazuschreiben, hab den Absatz aber dann wohl gelöscht :) Aber wie gesagt..stört mich nicht weiter, solange bis auf 100% geladen werden kann
Habe die Rom jetzt schon 3 Tage drauf ,doch habe ich davon nichts bemerkt ....
werde mal ein Auge darauf werfen ;)
Grüße Rudl
Wenn du genau darauf achtest wirst du bemerken das die LED in des Farbe des Akku anzeige leuchtet.
www.flash-freaks.com unterwegs
