[AOKP][JB][4.1.2] Psycho ROM V1.3 [Team Custom Freaks]
  • 649 Antworten
hellsgod schrieb:
So... der hells hat da was kleines gebastelt. Für User die noch etwas mehr auf den Akku schauen möchten, hier ein Script, welches das Hot Plugging Verhalten etwas ändert.
if [ -e /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold ]; then
echo "85" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
echo "50000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
echo "2" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
echo "30" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
echo "20" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
echo "40" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
echo "800000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
echo "1000000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
echo "800000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
echo "400" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
echo "400" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
echo "0" > /sys/devices/system/cpu/cpufreq/pegasusq/max_cpu_lock
fi
if [ -e /sys/devices/system/cpu/cpufreq/lulzactiveq/inc_cpu_load ]; then
echo "85" > /sys/devices/system/cpu/cpufreq/lulzactiveq/inc_cpu_load
echo "50" > /sys/devices/system/cpu/cpufreq/lulzactiveq/dec_cpu_load
echo "30000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/up_sample_time
echo "30000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/down_sample_time
echo "10" > /sys/devices/system/cpu/cpufreq/lulzactiveq/cpu_up_rate
echo "20" > /sys/devices/system/cpu/cpufreq/lulzactiveq/cpu_down_rate
echo "2" > /sys/devices/system/cpu/cpufreq/lulzactiveq/pump_up_step
echo "3" > /sys/devices/system/cpu/cpufreq/lulzactiveq/pump_down_step
echo "1000000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hispeed_freq
echo "7" > /sys/devices/system/cpu/cpufreq/lulzactiveq/screen_off_min_step
echo "40000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_sampling_rate
echo "600000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_1_1
echo "500000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_2_0
echo "800000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_2_1
echo "500000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_3_0
echo "1000000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_3_1
echo "800000" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_freq_4_0
echo "200" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_1_1
echo "200" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_2_0
echo "300" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_2_1
echo "300" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_3_0
echo "400" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_3_1
echo "400" > /sys/devices/system/cpu/cpufreq/lulzactiveq/hotplug_rq_4_0
echo "0" > /sys/devices/system/cpu/cpufreq/lulzactiveq/max_cpu_lock
fi
Zip von droidphile, Werte (Script) von mir.
https://www.dropbox.com/s/ktjfv7pp4rcd7le/BatteryTweaksGovernor.zip
Was macht das script :
Dieses script soll dazu führen, dass bis und mit 500mhz nur 1 kern läuft.
Ab 600mhz kommt kern 2 dazu, schaltet sich bei 500mhz wieder aus.
Kern3 schaltet sich ab 800mhz dazu, schaltet sich bei 600mhz wieder ab,
und kern 4 kommt erst ab 1000mhz und schaltet sich bei 800mhz wieder ab!
hells
Reaktionen: chrissi77 und Bocke
Gibt es da schon persönliche Erfahrungen rudl?!
you've been tapa'ed by me and MY S3
Zum Akku kann ich noch nicht all zu viel sagen. Ruckler hatte ich aber keine. Mir selber gehts weniger um den Verbrauch, mehr ums Prinzip. Es bringt einfach nichts, ab ca. 500mhz alle Kerne aktiv zu haben.
hells
Reaktionen: Bocke
Geht der script auch bei Sammy Roms mit Sihya RC1.
Ja, geht bei allen Roms und Kernel welche init.d unterstützen.
hells
Reaktionen: optx
Hab die Zip mal geflashed. Irgenwie will das bei mir nicht so. Mit Cool sah ich schon 2 kerne mit 1400 und 4 kerne die zwischen 200 und 400 schwanken. Wenn ich nur auf der HS bin, bleibt meine CPU auch nicht ruhig. Geht ständig 200,400,200,700,200,800,1400. Wie wenn es ein Loop wäre. Soll ich nochmal die Zip flashen ?
Edit: Hab jetzt nochmal einen Reboot gemacht, Cool zeigt mir das mit den Kernen jetzt richtig an,also funktioniert es.
Die wild umherspringende CPU hab ich immer noch. Geh mal auf Fehlersuche....
Gesendet aus einer Psychoparanoiden Galaxy
Also ich hatte vorher immer Omega kitchen benutzt aber diese Rom ist ja der burner :OO
Der ursprüngliche Beitrag von 11:56 Uhr wurde um 12:54 Uhr ergänzt:
Habe allerdings ein Bug gefunden die ROM erkennt meine 64gb SD Karte nicht. Oder soll andauert beschädigt sein
Wenn ich mit handy Formatiere passiert nichts mehr der ist nur am laden...
Kein bug ,formatiere sie in fat32 dann funktionierts !
Laut Windows geht nur NTFS und exFAT
Und auch Handy bekommt es nicht hin hm :(
Versuch mal, die Karte mit dem "Panasonic SD-Formatter" (Modus Full erase on) zu formatieren.
Hat bei mir schon etliche solcher Probleme gelöst.
eu
Jap schon versucht dann gibts nen Windows Bluescreen o_O
Es keine chance meine SD krte auf Fat32 zu formatieren... geht nur NTFS und exFAT
Bin jetzt von der Samny Rom hier hin.
Muss sagen beides super Roms aber diese hier gefällt mir dann doch besser :)
2 fragen aber.
1. Wie bekomme ich Tastatur und Telefonbuch von der samny Rom hier in diese Rom?
2. Wieso klappt der yank kernel hier nicht?
Würde der erste Punkt gehen wäre ich schon sehr glücklich.
Lg
Hey Leudz,
bei funzt weder das deaktivieren des Bootscreens noch die Auswahl einer neuen ZIP.
Über CWM gehts aber dann hab ich zuerst den YinYang Bootscreen und danach noch mal z. B. das X von Nexus.
Wie lös ich das Problemchen?
Sers....
Turmoe schrieb:
Hey Leudz,
Sers....
Du kannst die Boot animation auch manuell einfügen.
Einfach mit nem Root explorer in System/media die Bootanimation.zip ersetzten und nen Reboot vollführen.
chalie78910 schrieb:
Gibt es da noch ein besseren Link? :D
Link führt ja eh zur dropbox von hellsgod !!
Besten Dank an den User Turmoe für die Spendierten Bierchen !!!
Prost ^^
Bist im Spenden Spoiler geadded !
Grüße Rudl
Hi. Sollte nicht eine neue Version kommen?
html6405
Verci
V
html6405
html6405
html6405
craP_cillA
craP_cillA
craP_cillA
