[ROM][MOD] WIUI 2.1.20 Stable (GB) v4 (ICS - soon) - MULTiLanguage + RTL Fix
  • 64 Antworten
V
vogi
Dauer-User
516
[ROM][MOD] WIUI 2.1.20 Stable (GB) v4 (ICS - soon) - MULTiLanguage + RTL Fix - xda-developers
Wajk schrieb:
WajkIUI™ based on MiuiAndroid & CyanogenMod 7
thnx for the developers
Multilanguage support
About STABLE ROM:
  • - based on MiuiAndroid 2.3.6 (GB) 2.1.20
  • - Siyah kernel
  • - base language set to english (chinesse characters removed)
  • - all app recompiled and optimized with my tweaks and language files
  • - improved 3D performance
  • - added CM7 modules & some driver (check changelog)
  • - added some CM7 app (Camera, DSP Manager, SpareParts...etc.)
  • - improved camera quality
  • - added multilanguage support (24 languages)
    (arabic - brazilian - czech - danish - dutch - english - french - german - greek - hebrew - hungarian - italian - korean - persian - polish - portugese - russian - slovak - slovenian - spanish - thai - turkish - vietnamese)
  • - added multilanguage T9 dialer
  • - added 4-Way Reboot mod
  • - added Skip track via volume press mod
  • - updated Calculator
  • - updated keyboard, support more languages
  • - removed some MIUI apps
  • - optimized battery usage
  • - optimized memory settings
  • - removed unneeded files
  • - faster proximity sensor
  • - faster phone calling
  • - updated Google apps
  • - tweaks for speed
  • - more improvement coming soon
I working on:
- optimize and implement new tweaks for speed and stability
- import new CM7 drivers to MIUI
Download - Stable version
If you have question or problem, pls check first our F.A.Q. post!​
About v4 (ICS) ROM:
  • - based on MiuiAndroid 4.0.3 (ICS) 2.1.20
  • - based on CM9 latest nightly
  • - added some MIUI apps
Status: closed beta Working on: apps Release date: this week
Own port based on Miuiandroid & CM9
thnx for developers
Installation GUIDE:
1. Select Recovery/Stable Recovery. Choose "Wipe Data/Cache" option. Let finish.
2. Choose Install zip from SD Card, select WajkIUI_multilang .zip and let it finish.
3. select "Wipe Cache" then go to Advanced and select "Wipe Dalvik Cache". Reboot Now!
4. After boot, set your prefered language in Settings menu
5. Done! Recommend: use Battery Calibration for maximum battery
Tips&Tricks:
Check our F.A.Q. post!
RTL Fix Addon for FULLY Arabic support
My favourites
Programs/addons
:cool:
MIUI Lockscreen themes
MIUI themes
Change stock font with Theme Manager
Swype on WIUI
Thnx to:
Erpy for testing
gokhanmoral for SiyahKernel
miui.com for MIUI ROM
miuiandroid for ROM&translating
zeppelinrox for his tweaks
Juwe11 for his tweaks
xavierjohn22 for cool apps
Andy Thomson for volume button tweak
XJ, dRaCID01, Mish, Accid, roenano, langthang, omosiro, IoDa, pdazevedo, Xenon007, student926, mnlk2, 1982strand, slukk, gepardus, stefi for translating
Miui.cz for czech and slovak language files
Miui Germany for german language files
Finn for greek language files
zaherb and miuiarabic for arabic language files
Xda for more android tweaks
:) If you like what I do, use Thanks button and/or consider a small donation.
Donators: abumhmmd1, thebiker, enorlin, Atomicman, Kaffka, br3tty...
thnx guys!
ROM from Hungary
Multiupload.com - upload your files to multiple file hosting sites!
Reaktionen: Temur und Veltins85
Wajk schrieb:
Addons:
- RTLFix for WajkIUI 2.1.20
install from Recovery, thnx Roeano for his scripts
DON'T FORGET WIPE CACHE & DALVIK CACHE!
- NoService_fix for WajkIUI 2.1.20
install from Recovery, thnx bmarko for his fix
DON'T FORGET WIPE CACHE & DALVIK CACHE! If you use this fix, MIUI Lockscreen with weather not working!
- MIUILauncher for WajkIUI 1.12.9 ICS
install from Recovery, this addon replace stock LauncherPRO
- RTLFix for WajkIUI 1.12.9 ICS
- stillBOOT for WajkIUI
install from Recovery, this addon replace bootanimation an still image from header.
- Gallery3D optimized for WajkIUI
install from Recovery, this addon replace stock Gallery.
Animation Addons:
BlurAnimation - BounceAnimation
DrodAnimation - FlipAnimation
FlyInAnimation - FlyInMixAnimation
FoldAnimation
install from Recovery, this addon replace stock animation. NOT working with ICS addon!
  • MIUILauncher_1.12.9.zip
  • RTLFix_4WiUi_1.12.9.zip
  • RTLFix_4WiUi_2.1.20.zip
Wajk schrieb:
Changelog:
Real ICS version will arrive, when we will get MIUI v4 or i will do it ;)
v2.1.20 (released)
- updated default theme to v4 style thnx for PhysX
- stock theme included
- added new tweaks
- ringtone bug fixed thnx for magawa
- optimized framework settings
- applied my recent tweaks
- many new upgrade from MIUI guys
v2.1.13 (released)
- updated Siyah kernel to 2.6.7
- updated modem
- improved first boot
- smoother Market control
- disabled MiUi logger
- disabled monitoring
- optimized animations
- updated video drivers from CM7.2 nightlies
- updated Camera app from CM7.2 nightlies
- updated Camera drivers from CM7.2 nightlies
- updated APN settings from CM7.2 nightlies
- optimized some tweaks for stability
- updated Google Maps to 6.1.0
- added ultimate kernel cleaning script thnx for Mecss & buster041284
v2.1.6.1 (2254 downloads - 1 donation)
- fixed lockscreen bug
- kernel change to Siyah 2.6.6
- updated modem
- reconstruct full ROM
- recompiled all apps
- updated language files
- added Smooth scroll mod, thnx for AndroidON
- added Multitouch tweak, thnx for Chainfire
- updated Google Maps to 6.0.3
- added "Skip track via volume press" mod
v1.12.23 (3000+ downloads - 1 donations)
- kernel changed to void.echo if you want Siyah, you find it here
- optimized boot scripts
- optimized tweaks
- updated modules from CM7
- added NoService_fix addon to post #2
v1.12.16 (2000+ downloads - 1 donations)
- updated Bravia Engine with missing lib
- fixed MIUI Backup
- merge framework with NoSignal fix
- updated Market to 3.4.4
- updated GenieWidget from ICS
- default launcher will be MIUI Launcher
- removed Telocation Provider
- improved voice quality
v1.12.9 (2375 downloads - 2 donations)
- released HybridICS ROM version from WiUi ()
* framework based on GalnetICS
* reworked BlackICE theme
* added ICS goodies (ringtones, sounds, wallpapers...)
- added Bravia Engine
- added new and optimized recent tweaks
- render UI with GPU
- faster gps lock
- updated Google Maps to 6.0.1
- updated database manager from Android 4.0
- updated drivers from CM7 nightlies
- updated framework from CM7 nightlies
- updated APN settings from CM7 nightlies
- updated AdFree host file
- enabled Advanced settings
- optimized image files for faster control
v1.12.02 (1331 downloads - 2 donations)
- added IceCreamSandwich addon to post #2
* added Black ICE theme
- added Slovak language support thnx for miui.cz
- updated DeskClock with weather
- updated APN settings from CM7 Nightlies
- updated Market to 3.3.12
- updated Google Maps to 6.0.0
- added RTLFix for Arabic users to post #2
- optimized kernel tweaks
- improved framework settings
v1.11.25(1401 downloads - 1 donation)
- lots of new driver from CM7 Nightlies
- updated some HW driver (button, lights...)
- updated DSPManager
- improved recorded video&audio quality
- optimized tweak values
- added system mount script to addons
v1.11.18 (2000 downloads - 3 donations)
- added tweaked CM7 Camera
- optimized video quality
- group widgets by packages thnx for boombuler
- added new tweaks
- lot of new optimization
- optimized LauncherPRO
v1.11.1 (closed betatest)
- first release
Neues Rom auf Miui und CM7 basierend. Ich spiels mir mal drauf, gefällt mir auf den ersten Blick.
klingt interessant. Werd es später mal testen
Hay,
wie kann man denn updaten?
Also wenn ich update kommt die Bootschleife vom Motorola Logo das rote das...
Waikiki schrieb:
Hay,
Hi das Rom hier ist fürs SGS 2 bist leider im Falschen Post gelandet!!
Hat das rom schon wer probiert.
ja ... problemlos installiert .... soweit ich gestestet hab alle funktionen tun was sie sollen ....
für MICH PERSÖNLICH fehlt irgendwas ...
nichts an deer ausstattung oder performance .....
eine gewisse extravagenz ;)
ich weis nicht
Was fehlt ?:confused:
@zakdeni
Am besten selber Flashen denn jeder hat einen eigenen GESCHMACK
:smile:
So würde dir jeder was anderes sagen....:unsure:
Ich habs jetzt seit gestern laufen, bis jetzt alles so wie es sein soll. Null Probleme. Mir fehlt jedenfalls nichts!
Ein paar Sachen sind noch in Englisch, ist aber nicht gravierend. Ich werde erstmal dabei bleiben!
Ich weiß was mred33 meint... es ist einfach nichts besonderes... es läuft seht gut aber das gewisse extra, dass es anders macht bzw von der masse abhebt fehlt einfach =(
Aber die CM7 Kamera und die Tatsache das die Widgetauswahl wie bei CM zusammengefasst wird, bringt dem Rom definitiv einige symapathie punkte ein
:cool2:
Ich möchte diese Rom gerne probieren wollte aber fragen wer sie mit Fluxis Kernel am laufen hat.
:cool2:
Aber die Cm7 Kamera ist doch Schrott? oO
Allein das ist schon grund genug für mich die Rom nicht zu flashen xD
Hab das Rom jetzt seit 2 Tagen und bin begeistert. Es läuft schnell und flüssig und der Akkuverbrauch geht auch. Ist erstmal mein neues StammRom!!!
Dito.
Das ROM läuft super flüssig, der Autor ist auch recht aktiv, wie es scheint (gibt z.B. ein Animation-Pack auf XDA zum ROM) und z.B. die zusammengefasste Widgetauswahl ist doch klasse und haben die meisten anderen ROMs nicht.
Weiß einer, wie ich den "Tuhht" tone nach Auflegen eines Telefonats wegkriege? der geht mir total auf die Ohren--
Soweit ich weiß ist das ein MIUI "Feature" (ich empfinde es auch eher als Problem mit dem Geräusch). Ich glaube, das kann man nicht abschalten. Falls doch, wäre ich auch für des Rätsels Lösung dankbar. Vielleicht frage ich einfach mal Wajk, ob er das bei seiner ROM rauswerfen kann. Hat noch wer Interesse, das Geräusch loszuwerden?
