beicuxhaven
Ehrenmitglied
- 10.437
cDorid Rom
Und alles wie immer auf eigene Gefahr..
Ori.Thread xda
- App ops (Google secutity management);
- SELinux security by CyanogenMod;
- Privacy Guard + Privacy Guard manager by CyanogenMod;
- Per-user configuration by CyanogenMod;
- Normal or Center Clock Mod with possibility to change color;
- Custom Data formats in Status (day, month and year);
- Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
- Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
- Turn screen on when plug/unplug the USB cable as an option in settings;
- Reboot Menu Enable by default;
- Brightness control sliding through status bar;
- Custom Carrier Label;
- Enable Dual Panel in Settings (Needs Reboot);
- crDroid Version Build in Settings;
- PIE Control Transparency and Custom Colors;
- Status Bar Transparency and Custom Colors;
- Status bar network speed indicator with option to custom colors;
- Option to auto hide network speed indicator when there is no traffic;
- Status bar quick peek;
- Notification drawer + Notification row Transparency, custom Colors and custom image;
- Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors; -> Read Here!!!
- Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
- Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
- Lockscreen based on gestures from ChameleonOS;
- HALO 2.0 by ParanoidAndroid;
- BlackUI (Black Droid), TRDS from Slim Roms;
- App sidebar;
- LCD density changer;
- Option to enable notifications light even with screen on; *
- Option to enable Brightness Slider in Expanded Status Bar;
- Reboot / Reboot Recovery Tile;
- Reboot / Reboot Recovery in Power Widgets;
- Camera Tile;
- Option to enable lock screen rotation;
- Option to hide status bar (Off, Non-permanent only and All notifications);
- Quick settings pulldown (Off, Non-permanent only and All notifications);
- More information on reboot messages;
- RAM bar;
- NFC polling mode;
- Disable fullscreen keyboard;
- Screenshot quick trash;
- Permission management;
- Open tiles in floating window;
- QS tile fast charge;
- Powerwidget toggle fast charge;
- Speed up statusbar / notification drawer;
- Alternate default app picker;
- Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
- Floating window from notification drawer (Long press);
- Option to show Wifi name in notification drawer;
- Option to flip tiles in simple press;
- Listview Animation;
- Listview Interpolator;
Von einer anderen ROM kommend bzw. Erstinstallation:
- ClockworkMod-Recovery
- Boot into Recovery
- DO A DATA WIPE / FACTORY RESET (otherwise your device will be stuck at boot)
- Wipe cache and dalvik cache
- Flash cDroid zip from internal SDCard
- Flash GApps zip from internal SDCard
- Reboot
- Don't restore system data using Titanium Backup!
- Restoring Apps + Data might cause problems and is not recommended, avoid it if possible!
Upgrading from earlier version of cDroid Version
- Copy cDroid ZIP to your internal SDCard
- Reboot
- Reboot
- Reboot
Build 24 - 12.10.13
- Active display: Only fetch next notification if mNotification is null;
- Active display: Don't show active display if call state is not idle;
- Add never sleep screen mode (From Slim Roms);
- Privacy guard: changes part 1 (From Slim Roms) - To access App ops just long press any app in Privacy guard;
- Traffic meter: small clean up (Frameworks);
- Traffic meter: reorganization (Settings);
- Traffic meter: selectable summary timeout (thanks @Der_Schubi);
- Updated with CyanogenMod commits;
Build 15 - 13.09.13
- HALO Mods;
- Re-implemet Appbar;
- Attempt to fix disappearing Appbar (thanks to @temasek);
- Updated with all CyanogenMod commits;
Build 14 - 12.09.13
- Notification long press fix (floating window);
- In line with all SlimRoms commits of navbar, pie and navring until today (12.09.13);
- Several adjustments and fixes in navbar, slim and navring;
- Move complete keyevents into SlimActions class;
- Add Accessibility events to navbar, pie and navring;
- Add expanded desktop to navbar, pie and navring;
- Add power menu to navbar, pie and navrig;
- Add torch to navbar, pie and navring;
- Dynamic PIE menu button + navbar menu logic cleanup;
- Allow theming of lockscreen;
Build 13 - 10.09.13
- LCD density now is keep through crDroid flashes;
- Moving forward with Nav bar / nav ring and SlimPIE port (A LOT OF NEW CODES, COMMING FROM Slim Roms REPOSITORIES)
- Navigation bar, navigation ring and SlimPIE totally revamp, following SlimRoms way;
- Re-order nav bar, nav ring or SlimPIE icons just by drag and droping;
- Set long press in nav bar, nav ring and Slim pie just by long pressing and choosing the behavior;
- New SlimRoms transparency manager with alpha mode working in custom colors;
- SlimPIE from lockscreen;
- Some other stuffs from SlimRoms regarding nav bar, nav ring and SlimPIE (check my github to see all the new ports);
Build 12 - 06.09.13
- Removed App sidebar;
- Navigation bar and Navigation Ring in SlimRoms way with all customizations possible (thare are too much in this changelog);
- SlimPIE with all customization possible (thare are too much in this changelog);
- Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar);
Build 11 - 02.09.13
- Fix in lockscreen custom image transparency;
- Fix in network speed indicator not hiding without reboot;
- HALO: Fix potential NPE
Build 10 - 27.08.13
- CyanogenMod Ribbons;
- CyanogenMod account;
- Google App ops in settings (removed Permissions Management);
- reverted brightness slider (need to ribbon work);
- reverted Hide quick settings panel (need to ribbon work);
- Listview animator;
- Listview interpolator;
Build 9 - 25.08.13
- Merge JSS15Q update;
- Floating window from notification drawer (long press);
- Some HALO bug fixes from PA;
Build 8 - 22.08.13
- Fix in System settings / interface / status bar / Clock and date force close, due a missing String;
- HALO: flip for incoming messages;
- HALO: Protected lockscreen - do not ping on unlock if silenced;
- HALO: performance, batch revamp;
- HALO: code cleanup;
- HALO: bug fixes;
Build 7 - 20.08.13
- Option to hide Quicksettings panel;
- HALO: fix silence bug when notification is dismissed;
- HALO: wrong touch calculation, nap trigger fixed;
- HALO: still wrong multitouchhandling;
- HALO: fancy flip;
Build 6 - 17.08.13
- Auto hide network speed indicator when there's no traffic;
- TRDS new 4.3 png's (frameworks);
- HALO 2.0
- HALO tweaking;
- Updated with all CyanogenMod commits.
Build 5 - 14.08.13
- HALO persistent notifications less pronounced + fixes
- Major settings re-factor by CyanogenMod team;
- Updated with all CM commits;
Build 4 - 12.08.13
- NFC polling mode;
- Option to disable fullscreen keyboard
- Halo changes;
- Halo bugfixes;
- Updated with CM sources;
Build 3 - 12.08.2013
- RAM bar;
- Update CM sources
Build 2 - 08.08.2013
- BlackUI fully ported (Black Droid), TRDS from Slim Roms;
- Fix in nav bar 3 dots button isn't showing automatically, when it's needed
- Update CM sources
Build 1 - 07.08.13
- Initial crDroid 4.3 based build
Build 15 - 13.09.13
- HALO Mods;
Build 14 - 12.09.13
Build 13 - 10.09.13
Build 12 - 06.09.13
Build 11 - 02.09.13
Build 10 - 27.08.13
Build 9 - 25.08.13
Build 8 - 22.08.13
- HALO: bug fixes;
Build 7 - 20.08.13
- HALO: fancy flip;
Build 6 - 17.08.13
- HALO 2.0
- HALO tweaking;
Build 5 - 14.08.13
Build 4 - 12.08.13
- NFC polling mode;
- Halo changes;
- Halo bugfixes;
- RAM bar;
- Update CM sources
- Update CM sources
Build 1 - 07.08.13
