Corndude
Gast
Moin Leute,
nachdem der alte Insanity II-Thread leider nicht mehr aktualisiert wird hab ich das Ok von Kjetal gekriegt nen neuen aufzumachen und hier ist er
Verlinkung zum alten Insanity Thread:
[OFFURL]https://www.android-hilfe.de/custom-roms-fuer-samsung-galaxy-s2/138734-rom-insanity-ii-cm-36-23-08-2011-46mb.html[/OFFURL]
Damit die Arbeit con cpt nicht ganz abhanden kommt.
Screenshots
Features
Multi DPI - 182 dpi Default
SIP Integrated (VoIP)
AOSP Apps & Lock screen
Swype 3.25.91.31127
Removed
A list of all applications can be found in the
i9100 apps Spreadsheet
If anyone would like to help maintain it please let me know
Missing Applications
Use nitrality UI to install any missing applications that have been removed. - Stock in insanity -
Android Market
Install - Stock 2.3.3/2.3.4/2.3.5 ROM
Upgrade
Other Information:
My github / Other Soruces:
https://github.com/nitr8/
https://github.com/CyanogenMod/
[SIZE=+2]insanity ii[/SIZE]
I wanted a basic ROM that was really quick as I only need my phone to Make Calls, Email, Calendar now and then, take a photo or two and listen to music when I am on the plane.Screenshots
Features
Removed
- Flash CF-Root Kernel from here with auto-reboot not ticked, pull battery and put back, use 3 button combo to enter cwm. Your CWM should be 4.0.0.2.
- Flash the latest Insanity Kernel from here in CWM
- Note: If assert fails for whatver reason, edit the zip file by mounting usb, remove the assert ( i had to), reboot recovery, then flash the kernel, reboot recovery. Your CWM now will be 5.0.2.x.
- Flash the latest Insanity zip file from here in CWM and wait for it to reboot to system.
Upgrade
- Copy Insanity ROM to internal SD Card
- Reboot into Recovery Mode
- Flash insanity via CWM
- Reboot
Other Information:
- insanity wiki
- Chat - #insanityrom @ freenode
Donators
Dioser - Dioser (again) - Dioser (again) - antiochasylum - johnny8910 - Rodrigo Vilhena - antiochasylum (again) - v.vibrate - bclark - crazyscow
Thanks To
Tr0jAn - xan
Thanks To
