[ROM][ICS] Black Infinitum AOKP - v0.6.1[23.März.2012]
  • 23 Antworten
STaaFF7o
STaaFF7o
I am the creator of Black Infinitum theme and i wanted to do something new. That's the reason why i'm gonna develop an AOKP based rom fully themed.
ATM i'm using HyDrOG3N-ICS as a base, thx again for letting me use it!
Screenshots gallery:
http://goo.gl/MFz1l
What's themed:
-Phone
-Contacts
-Messaging
-Browser
-Gallery
-Camera
-Google Play
-Keyboard
-Google Talk
-Google Voice
-Email
-Calendar
-YouTube
-Trebuchet launcher
-Nova Launcher
-Genie widget
-CM9 Music and Clock
Quelle:[ROM][ICS][AOKP] Black Infinitum - Totally Black! v0.5 - xda-developers
Features:
-Fully themed rom (system and apps)
-AOKP amazing features
-Siyah kernel v3.0
-LPQ modem
-Replaced stock Mms.apk with CM9
-Added CM9 file manager
-Added CM9 music app
-Added Nova and Apex launchers (both themed)
-Custom bootanimation
-Facebook sync is working
-Grouped widgets
-Removed Galaxy4.apk
-Removed MagicSmokeWallpapers.apk
-Removed HoloSpiralWallpaper.apk
What's themed:
-Phone
-Contacts
-Messaging
-Browser
-Gallery
-Camera
-Google Play
-Keyboard
-Google Talk
-Google Voice
-Email
-Calendar
-YouTube
-Trebuchet launcher
-Nova Launcher
-Genie widget
-Circle battery
v0.4: -added Siyah kernel v3.0 beta 3 -LPQ modem -themed GalaxyS2Settings icon v0.3: -MTP finally working -AOKP build 28 -fully themed camera -grouped widgets -fixed blue contacts -themed SetupWizard.apk -removed Galaxy4.apk -removed MagicSmokeWallpapers.apk -removed HoloSpiralWallpaper.apk v0.2: -fixed a bug in the installation process -added themed Google Reader v0.1: -initial release
FAQ
How to install?
Perform a full wipe, flash the rom then flash gapps.
Thanks to:
-AOKP and CM teams
-Paradoxxx and Netchip for letting me use HyDrOG3N-ICS as base
-Nitroz for his theme
-Travp624 for help and his inverted apps LINK and also B-boy and tgwaste
-gsxrdon for his keyboard LINK
-avlopp for the bootanimation
-david1171 for minimalist icons LINK
-evilkal for circle battery LINK
Download:
rom - Infinitum Project
gapps -
Für alle die auf schwarz stehen,läuft richtig Kernig.
auch meins
Ist das selbe wie es mein Rom war.
Ich hab mir auch mal das Rom drauf gemacht...bin soweit zufrieden außer das es kein google talk gibt...wollte eine Version drauf machen aber es zeigt mir an Anwendung nicht installiert...hat jemand eine Idee?
Hast du die GoogleApps installiert?
ja die die in dem package dabei waren ganz unten die
jetzt hab ich alles neu aufgespielt mit den neuen apps jetzt kommt das nächste problem...ich bekomme keine mobile internet verbindung...wenn ich eine apn eingeben will und auf speichern gehe dann bleibt das feld leer...bitte um hilfe
hat sich erledigt...hab einen anderen kernel genommen und dann ging es
Aktuell bereits in der v0.4 fürs SGSII als Rom verfügbar!
Wie findet ihr die neuste Version? Welchen Launcher preferiert ihr?
Lasst ihr den Siyah Kernel drin? Ich benutze mittlerweile den Stock Kernel wieder. warte jedoch Sehnsüchtig auf v0.5 und nutze als Launcher den Nova Launcher ! :)
Wollte mal fragen ob jemand mal über die rom berichten könnte - stable,smooth? was funktioniert nicht?
Sent from my GT-I9100
Die Version 0.5 ist verfügbar.
Changelog
-back to stock kernel, Siyah still too laggy
-added CM9 DSP Manager
-added Adfree feature (no more advertising!)
Ich habe mir diese ROM heute abend geflasht und ich bin vom Design schier begeistert. Schwarz Weiss, mein feuchter Traum ;)
Da diese ROM auf https://www.android-hilfe.de/forum/...2-hydrog3n-ics-byedrog3nics-sdfix.211840.html basiert kannst du dich da gut einlesen.
Da ich sie erst ein paar Stunden drauf habe kann ich nicht viel sagen, siehe am bestem in dem anderen Thread nach.
Lg SouLLesS
Reaktionen: Chris1996
Habe mal den Thread-Titel aktualisiert... ;)
Reaktionen: STaaFF7o
Kannst gleich nochmal aktualisieren, v0. 6 wurde released. ;)
Sent from SGS2 using Tapatalk
Ahh so ein Mist. Und ich hab noch nicht mal alles eingerichtet ;(
Falls hier einer ein flash ohne wipe wagt kann er bitte mal Rückmeldung geben ob und wie es geklappt hat.
Danke.
Lg SouLLesS
Gibt schon 0.6.1. Statt Netchip jetzt
Siyah v3.0b6. Kernel.
