[CM9/AOKP-ROM][ICS] *11.08.12* Kaffee4Eck | CM9 -> Online v7 [AROMA][CM9 STABLE]
  • 37 Antworten
Kaffee4Eck
Kaffee4Eck
▬▬▬▬▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬▬▬▬▬▬
Kaffee4Eck/RiDDiX CM 9 Customize Ur Phone v7
ROM-Info:
- Based on Android 4.0.4 Cyanogenmod 9 Final/Stable
- 4 Launcher (Ur choice
- APN for almost all networks.
- 3G/Data/Phone/Bluetooth/GPS/Audio/Everything
- ADFREE Hosts File to block Spam/Advertisements
- SD Card (under external_sd) with ICS Bind (added)
- WIFI Tethering and USB Tethering
- Rooted
- 3 Kernel (Ur choice)
- 4 Way Reboot (Hold Power Button)
- CRT-OFF
Third-Party Apps:
- Beats Audio Files
- Audio Manager
- Ak Notepad
- LiveWallpaper FireFlies
- Quadrant
- AdFree
- FasterFix / GPS Fix
- GPS-Status
- ES File Explorer
- Titanium Backup / Dont use this App with Crack buy it to help the developers.
- DPI Changer <-- Now included
- More included in AROMA Installer
AROMA Installer:
Apps:
- MiHome
- MiLocker
- MiFileExplorer
- GO Launcher EX
- Go Locker
- Go SMS
- Handcent
- Nova Launcher
- Apex Launcher
- Trebuchet Launcher
- Titanium Backup
- BeatsAudio "Awesome Beats"
Kernel:
- Siyah 3.2.8
- Dorimanx 4.0A
- Fluxxi XX.02 Beta10
Download ROM:
[URL="http://egu-rel.de/Downloads/K4E_CM9_07t.zip"]K4E_CM9_07
[/URL]
Download GApps + Faceunlock:
GAPPS
Faceunlock
MIUI Music
Changelog:
Changelog:
v7
Updated to CM9 Stable (as known as Final Version)
Updated all Kernels
Reworked all Frameworks.
v5
Update to Cyanogenmod RC2
Retweaked Frameworks
Stability improvement
Performance improvement
Battery improvement
v04
Updated to latest Nightly
Tweaked Frameworks
Added BeatsAudio into AROMA
Added TitaniumBackup into AROMA
Updated AROMA Apps and Kernels
Many other things.
v03
Updated to RC1
Tweaked Frameworks(Stability, Speed and Smoothness)
Added BeatsAudio / BeatsAudio Manager
Improved Battery (Frameworks and some APK tweaks)
Updated all Kernels and App's
v02
Updated to latest nightly
Tweaked Frameworks
Sorted AROMA UI
Added and Updated Apps in AROMA
Much more.
v01
Initial Release
AROMA Installer
Modified Frameworks (Sorry i forogt most things because I worked over 5 hours on AROMA :))
Added more Kernels
Added more Apps
Information:
Please mark in Aroma only ONE KERNEL for Installation!!!
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
:cool:
Reaktionen: Drak0 und Marcel2580
Fängst'e noch 'ne Baustelle an?
CM9 läuft mittlerweile viel stabiler und man kann in den Changelogs von CM nachvollziehen welche Dateien bearbeitet wurden. Weit besser als MIUI aber dies bleibt mein Hauptaugenmerk.
Desweiteren versuche ich MIUI auf CM9 aufzubauen was bereits gut klappt aber dennoch Fehler in sich hat. ^^
Bis wann ist denn mit der Rom zu rechnen? Suche gerade was neues zum flashen.
Dauert maximal noch eine Stunde.
Ich denke aber nicht gar so lange.
Rom befindet sich nun in der Endphase des Testens. Nur noch ein paar Minuten.
Und dann noch das hochladen, oder? Sorry, aber ich kann es kaum noch erwarten :)
Ich hoffe das ich den AROMA Installer bald zum laufen bekommen bzw zum installieren der Apps. ^^
Nur kein Stress. Würde es zwar gerne noch flashen aber wenn nicht ist auch nicht schlimm.
Wird das dann auch noch weiter entwickelt?
Ja klaro. Wird immer weiterentwickelt. So lange CM updates liefert und ich noch Probleme finden kann.
Reaktionen: Marcel2580
Das freut mich.
Die letzten Tests, dann lasse ich es hochladen und geh ins Bett.
So v01 ist gleich online. Bitte noch ne gute halbe Stunde warten, da ich noch einen Filecheck machen lasse.
Wünsche allen eine gute Nacht.
Also habe es mal getestet, habe mich aber noch nicht für ein launcher entscheiden können.. und muss erstmal vollkommen durchsteigen... mit den Launchern komme ich auch son bissl durcheinander...
Wo ist mein Mi Musik ;(??
Miui Music auf der Startseite hinzugefügt. Wird beim nächsten Release mit ins AROMA eingebaut.
Wie ist das wegen den Lockscreens? Ich habe irgendwie 2-3 Lockscreens hintereinander... Kann man irgendwie auch die Dropdown Leiste für die Shortcuts von MIUI einfügen und nicht die von standard CM9?
Dafür müsste man die SystemUI bearbeiten und das geht leider nicht so leicht. Du solltest die Lockscreen apps öffnen und die deaktivieren die du nicht haben willst. ^^
v2 kommt heute...
Changelog:
- Ad Hoc Support
- Updated to latest nightly
- Some improvements
v2 ist online!!
:cool:
Nächstes Update wird auf einem RC aufgebaut sein. :cool:
V03 ist online!!!
:cool:
Reaktionen: cc_sirob_cc
Pr0TuRk38
mahaseno
dj3d
karu2003
beicuxhaven
RobertAntonio
