[AOSP-ROM][KK][4.4.4] *29.09.14* Dirty Unicorns [V. 8.0][Official]
  • 68 Antworten
Pr0TuRk38
Pr0TuRk38
Dauer-User
1.551
Dirty Unicorns ROM
OMNI Basis
Features
Code:
-- Theme chooser!
-- Heads up
-- Built-in ad blocker (able to update hosts on the fly)
-- Ability to disable FC notifications
-- Enable pointer/user microphone options (screen record)
-- Download Center (Gapps, Xposed, etc)
-- Ability to force Expanded Notifications
-- Over 100 cloud based wallpapers
-- Facebook Sync Hack
-- Immersive mode
-- Hot Reboot In Power Menu
-- Appbar (app sidebar)
-- Customizable Quick Settings
-- Customizable power menu
-- Customizable lockscreen shortcuts
-- App Ops access in Settings
-- TRDS (built in theme in settings)
-- Statusbar Clock options
-- NavBar Options
-- Halo (multi-tasking tool)
-- Halo size/color changer
-- Hardware key remap mod (only for HW button devices)
-- Battery Bar / Circle batteries
-- Network speed indicators in statusbar
-- SuperSU (chainfire)
-- Build.prop mods
-- Init.d Tweaks
-- Active Display (Moto X notifications)
-- ListView Animations
-- Custom System Animations
-- Toast Animations
-- Custom BusyDialog
-- Advanced Low Battery Indicator options
-- ScreenShot QuickTrash
-- Color Changing PhaseBeam
-- Gesture Anywhere
-- Button Light Notification
-- Statusbar Color options
-- OmniSwitch (multi-tasking tool)
-- Driving Mode
-- Lockscreen theme options
-- Lockscreen notifications / options
-- System App Remover
-- Identicons
-- Suspend Actions
-- Wakelock Actions
-- SlimROM based recents
-- Contextual notification panel headers
-- SlimROMs privacy guard
-- Blacklist calls/sms
Installation
0. BackUp anlegen
1. Neustart in ein aktuelles Recovery
2. Wipe Data/Factory Reset
3. Wipe Cache partition
4. Wipe Dalvik Cache
5. Format System
6. Dirty Unicorns ROM.zip flashen
7. GoogleApps.zip flashen
8. Neustart und Willkommen bei der Dirty Unicorns ROM !
Installation von einer vorherigen Dirty Unicorns ROM:
1. Neustart ins Recovery
2. Wipe Cache/Dalvik Cache
3. Rom flashen
4. Wipe Cache/Dalvik Cache
5. Neustart !
_______________________________________________
Downloads
Dirty Unicorns ROM 4.4.4
Google Apps:
Google Apps für Android 4.4
Changelog:
Code:
[B]v8.0 - 29-09-2014[/B]
- Camera: exposure time support
- PIE from ParanoidAndroid added
- PIE color settings
- More PIE targets
- NavBar keyboard arrows toggle
- WiFi power menu
- Calendar enhancements and fixes
- Dirty Tweaks tile
- Added Power Menu / Quick Settings button in pulldown
- Theme engine improvements and fixes
- Add moar default tiles/toggles
- Quiet Hours up to date with slim rom
- Gallery enhancements and fixes
- Show Heads Up on Bottom
- Carrier logo statusbar option
- Complete translations for five languages added
- Rebase to cleaner looking traffic indicator
- Remove blur lockscreen
- More DU wallpapers added
- Heads Up background color/transparency
- Vibration options
- Keyguard: Bring back fast unlock
- Custom Tile
v7.9 - 21-08-2014
- MIUI Style carrier text in the statusbar
- Bring Slim Recents up-to-date with SlimROM
- Show notification when charging
- Modify Location Tile
- Filter spam notifications
- Move Dark UI into themes
- Theme chooser fixes
- Toggle boot audio on and off
- Add ability to play audio to Boot Animation
- New shutdown animation and busy dialog
- 6-bar signal icon style
- Overscroll effects
- Add moar Gapps to the Download Center
- Camera2: Make navigation bar and status bar transparent
- User defined wifi/usb tether network
- Toggle nav bar through power menu
- Add hardware tunables for some devices
- Show plugged type (AC / USB) on QS battery tile
- Option to always show heads up in expanded mode
- Option to disable heads up in lockscreen
- G+ system ui f/c fix
- DU Neon Clock
- Add option for setting device phone number
- Removed redundant features from tablets
v7.8 - 02-08-2014
- Update to android-4.4.4_r2
- New Bootanimation
- Left handed navbar during landscape mode
- CPUFreq Tile
- Fix hot reboot
- Fake Id vulnerability fix
- Allow changing theme to Holo.Light without crashing
- Themes: Make notification list bg themeable
- Move LCD density from build.prop to it's own category
- Fix holo dark background
- DU about app: Add/Remove People/Devices and General Cleanup
- Moar Double tap to sleep options
- Back to kill app mod
- Fix crash when set .gif as wallpaper
- Fix themes not sticking on reboot if using Xposed framework
- Weather panel
- Fix SwiftKey disappearing issue
- Fix QS layout for camera tile
7.7 - 07-07-14
- Updated the ASCII art for flashing
- Theme chooser
- Heads up
- Ability to disable immersive messages
- Blacklist/configureable timeout for heads up
- New sound recorder
- Roboto Fonts from Android L
- Updated SuperSU to v2.01
- Many "under the hood" changes
7.6 - 06/29/14
- Redesigned the Dirty Tweaks
- Some security patches for smdk4412
- Apollo updates
7.6 - 06/22/14
-Initial kitkat i9100 release
For a more detailed changelog, feel free to check out our Gerrit
http://gerrit.dirtyunicorns.com/#/q/status:merged,n,z
Bugs
Links
Dirty Unicorns ROM XDA-Thread
Es wird keine Haftung für eventuelle Schäden übernommen. Flashen geschieht auf eigene Gefahr!
Reaktionen: eliazTeez, aw2206, walangoo und 3 andere
Was mir aufgefallen ist, viele Eingaben sind in Deutsch gehalten was schon mal sehr gut ist. Einige Englische sind auch dabei aber verständlich, auch mit wenig Englischverständnis. Das Eingabefeld für die PIN Eingabe beim Start des Gerätes ist sehr stark verschoben. Ansonsten reagiert das Gerät unter dieser ROM sehr schnell und die Einstellmöglichkeiten sind umfangreich. Über die Akkudauer kann ich noch rein gar nichts sagen.
Ich finde es auch ganz gut. Aber die verschobene PIN - Eingabe gefällt mir nicht. Daher erst mal wieder runter geflogen.
Finde die ROM Klasse.
Da ich keine PIN - Eingabe habe kann ich nichts sagen.
Vielleicht hilft ja eine DPI Veränderung
Hallo ! Vielleicht klappts mit diesem script .Hat schon bei verschieden anderen Roms geklappt :cool2:
  • CeleriterRom v2.2_DPI to 240.zip
Danke für die Möglichkeit, aber ich hab es ausprobiert = Kein Erfolg.
Hi , kann schon jemand etwas über die Akku Leistung sagen?
Von der Akkuleistung her sehe ich keinen großen Unterschied zu OMNI noch zu SlimKat. Allgemein sind ist die Akkunutzung ca. 80% vom Nutzer abhängig. Die restlichen 20 % bilden sich zusammen aus Kernel, Kernel-Tweaks und der ROM an sich. Am besten ist es, selbst ein Bild von der Lage zu schaffen.
Vielen Dank, ich bin am überlegen, welche ROM ich mir flashen soll.. entweder "Bam Droid", oder "Carbon Rom".
Kann mir jemand vllt. eine Empfehlung geben?
@JensGoro Wie gesagt, selber testen. Zudem ist es doch etwas unpassend andere ROMs im Dirty Unicorn Thread bevor zuziehen.
Heute gab es ein Update mit einigen Fixes. Ein Update ist empfehlenswert.
Mit freundlichen Grüßen,
Pr0TuRk38
Hallo !
Die Rom generell ist toll,mit vielen eingedeutschten Einstellungsmöglichkeiten.Muss man halt mal ausprobieren.Ein Problem hab ich im Moment mit GPS in Maps und Navigation.Funktioniert nicht richtig.Als Kernel verwende ich den Gustavo TWRP vom 17.1. mit dem ich sehr zufrieden bin ,auch auf anderen KK Rom.Wenn ich auf die neue BeansTalk vom 21.1. wechsle mit dem gleichen Kernel ,funktioniert das GPS bei Maps einwandfrei .Liegt wohl an der DirtyUnicorn :unsure:
Folgendes versucht:
etc/gps.config:
Den NTP_Server auf Deutschland umzustellen, sowie die A-GPS Daten so aktuell wie möglich halten.
Geh in die Einstellungen / Standort
1) Zugriff auf mein Standort auf "An" umstellen
2) GPS Satelliten Haken reinsetzten
3) Standort per Wlan und Mobilfunknetz kannst du einen Haken setzten, musst du nicht, weil sobald du keine Internetverbindung besteht, wird/kann die Funktion nicht genutzt werden.
Ein Check mit GPS Status ist empfehlenswert.
Pr0TuRk38
Reaktionen: sourly
Bei mir funktioniert das 2G/3G Toggle nicht. Jemand eine Idee?
Thread-Titel aktualisiert. Vielen Dank an Sourly. Einen Changelog habe ich leider nicht finden können.
Reaktionen: sourly
Frage an den Moderator: Ist es nicht ratsam, die neusten Versionen als Download auch im ersten Post anzupassen wenn eine neue Version rauskommt oder werden die Folgeversionen innerhalb des Post veröffentlicht?
Reaktionen: sourly und Pr0TuRk38
Tut mir Leid walangoo. Beim Editieren habe ich anscheinend den alten Download-Link eingefügt. Jetzt ist es so, wie es sein soll. :)
Reaktionen: sourly und walangoo
Anscheinend gibt es ein keyboard Problem .Hab sie selber noch nicht drauf,bin auf der neuesten BeansTalk .Die mit Abstand die beste Rom im Moment ist
Der ursprüngliche Beitrag von 13:59 Uhr wurde um 13:59 Uhr ergänzt:
Keybord not working
After install i get the error that y keybord (google) is not working. I can do anything without the keyboard. I cannot not install a new keybord f i copied a other keyboard.apk to my drive.
Can some body has a solution for this.
Und der changelog ist hier
Gerrit Code Review
Reaktionen: walangoo und Pr0TuRk38
Noch immer schade, dass die Devs die vermurkste PIN-Eingabe nicht hin bekommen.
Keyboard funktioniert bei mir einwandfrei. Hab die ROM auf 210 dpi eingestellt. Dann stimmt auch die PIN-Eingabe.
X IE N o T IR i X
X IE N o T IR i X
Pr0TuRk38
dernettemann
dernettemann
dj3d
karu2003
