[AOSP-ROM][KK][4.4.4] *25.09.14* AOSP NeatROM [v8.0st]
  • 119 Antworten
Maki.
Maki.
Ehrenmitglied
957
Welcome to AOSP NeatROM for S2
Simple, clean and reliable
Hallo, ich präsentiere euch hiermit die AOSP Version der NeatROM.
Features:
  • AOSP NeatROM for Samsung Galaxy S2 I9100
  • September 25, 2014
  • Firmware: I9100 AOSP NeatROM v8.0st (4.4.4)
  • Compiled from the latest SlimKat repos
  • The Real Dark Slim
  • Notification drawer Shortcuts
  • Full hardware key rebinding
  • Keyboard rotation
  • Nova Launcher
  • Superuser
  • Darker Camera - colour filter options, gps indicator, picture quality, smart capture, shutter sound...
  • Darker Gallery
  • Phasebeam LiveWallpaper
  • Wifi country code
  • Mediascanner behaviour on boot
  • Volume key cursor control
  • Show permanent enter key on keyboard
  • IME selector notification
  • Auto keyboard rotation feature
  • Systemwide blacklist support for calls and sms/mms
  • Pattern size customizing
  • Lock before unlock the new way
  • Lockscreen shortcuts
  • Fully revamped lockscreen target options
  • Start widgets maximized on lockscreen
  • Enable carousel animation on lockscreen
  • Enable/disable camera widget on lockscreen
  • Full customizable low battery warning
  • Wake up on charge
  • Volume rocker wake
  • Volume rocker music control
  • CRT animation the new way with new animation as well
  • Fully customizable auto brightness
  • Display rotation options (0, 90, 180, 270)
  • Fully customizable volume panel
  • Power connectivity alert
  • Less frequent notification sounds
  • Ascending ringtone
  • Control safe headset warning
  • Mute Camera shutter sound
  • Quiet hours new extended version
  • Mute Volume adjust sound
  • SlimCenter
  • Fully global menu customization
  • Fully revamped navigation bar and navigation ring customizations
  • Statusbar brightness control
  • Full Clock and date customization on status bar
  • Battery icons
  • Quick settings style options
  • Quick pulldown for quick settings
  • Easy full swipe access between notification drawer and quicksettings
  • Wifi access point is shown in notification drawer
  • Hide carrier label on notification drawer
  • Notification drawer shortcuts
  • Notification transparency
  • Notification drawer and quicksettings background as well with tablet support
  • Fully customizable quick settings the new way with new included music tiles and features
  • Battery tile new click/longpress behaviour
  • Allow to disable QuickSettings completly
  • Option in Dev Set to customize the device hostname
  • SystemUI - double tap to sleep gesture
  • IPV6 tethering support
  • Allow applications to override power key
  • DeskClock - back flip and shake actions
  • Navigation bar
  • Global menu - Expanded desktop
  • Wakeup Options
  • Enable/Disable Root (Enabled by default)
  • Fixed StatusBar Back Button
  • Es File Explorer
  • www.NeatROM.com as default home page for browser
  • NeatROM Bootanimation v4 Big thanks to @momo.martinovic
  • Added Mass Storage option (MTP/PTP/Mass Storage)
  • Init.d Support
  • Added support for ADB over network
  • Disabled charging LED
  • Fully Customizable Hardware Buttons
  • Disable/Enable Menu Key Unlock
  • New Tweaks
  • Better Battery Life
  • Noise suppression for phone calls
  • Super advanced Custom Toggle
  • Browser-Enabled Bookmarks Sync
  • No Call Ring delay ~0ms
  • Fixed Custom Toggle
  • Browser-Blue Progress Bar Thanks @tarzan11
  • Added SlimPie
  • Added Download Speeds in notification
  • Added Battery Animation while Charging
  • SlimKat Stable
  • New Dialer - Bigger Caller Photo
  • Install Non-Market Apps Enabled by Default
  • Package Verifier Disabled by Default
  • New Tweaks
  • Notification Reminder
  • Smart pull down
  • Slim recents app switcher
  • Option to add favorite apps in recents menu
  • Lockscreen rotation
  • Traffic meter
  • Battery Bar Toggle (StatusBar, Top of Navigation Bar or Bottom of Navigation Bar
  • Battery Bar Color Picker
  • Battery Bar Alignment
  • Battery Bar Thickness
  • Battery Bar Charging Animation
  • Implement SIM card management
  • Fixed Camera v6
  • exFAT support
  • Support more media types
  • Added lockscreen shake events
  • Added shake sensitivity adjustments
  • All widgets on keyguard
  • Added more battery icons
  • Added option to hide battery icon
  • Added hardkey light control
  • Added custom lockscreen options
  • Added option to set lockscreen color (color picker)
  • Added option to set lockscreen transparency
  • Added lockscreen blur effect
  • Added option to set lockscreen blur radius
  • Added option to set lockscreen custom image
  • Updated ES File Explorer
  • Email attachment/Enabled download
  • Enabled moving apps to SD
  • Heads up
  • Color picker for quicksettings styles
  • Added support for chromecast
  • Added font scaling slider
  • Updated TWRP recovery
  • Added back reboot confirmation (Cancel - OK)
  • Added network traffic upload/download
  • Added network traffic indicators
  • Added network traffic color picker
  • Added network traffic update frequency
  • Added signal icon color picker
  • Added data icon color picker
  • Added wifi icon color picker
  • Added airplane icon color picker
  • Added ability to answer call with hardware home button
  • Long press delay 0.8sec
  • Added Hot Reboot
  • Added Lockscreen notifications Thanks to Griffin Millender
  • Added ADB over network tile
  • Added Slimrecents card/text color
  • Based on the latest sources from Slim (stable)
    and many more...
    I probably forgot something
Downloads:
September 25, 2014
MD5 Sum: fb1d48314039623b61ecf7b0f9b76ed1
Gapps
CWM-Recovery: Dev-Host - CWM-KitKatCompatible-i9100.zip - The Ultimate Free File Hosting / File Sharing Service
ältere Downloads:
I9100 AOSP NeatROM v8.0 (4.4.4)
I9100 AOSP NeatROM v7.4 (4.4.4)
I9100 AOSP NeatROM v7.0(4.4.4)
I9100 AOSP NeatROM v6.4.1 (4.4.4)
I9100 AOSP NeatROM v6 (4.4.4)
I9100 AOSP NeatROM v5.9(4.4.3)
I9100 AOSP NeatROM v5.8(4.4.3)
I9100 AOSP NeatROM v5.6(4.4.2)
I9100 AOSP NeatROM v5.0(4.4.2)
I9100 AOSP NeatROM v4.9(4.4.2)
I9100 AOSP NeatROM v4.6(4.4.2)
I9100 AOSP NeatROM v4.2(4.4.2)
I9100 AOSP NeatROM v3.10 (4.4.2)
I9100 AOSP NeatROM v3.6 (4.4.2)
AOSP NeatROM Sim V 3.2 (4.4.2)
I9100 AOSP NeatROM Slim v2.1 (4.4.2)
I9100 AOSP NeatROM Slim v2.1 (4.4.2) Mirror 1
I9100 AOSP NeatROM Slim v2.1 (4.4.2) Mirror 2
GApps 4.4.2 beta
AIO_gapps.4.4.2.build.3.zip | by NeatROM for Galaxy S 3
Google Apps v3
Google Apps v3.1
Google Apps v4
Google Apps v4.6
Google Apps v5.0
Google Apps v5.6
Google Apps v5.8
Google Apps v5.9
Google Apps v6
Google Apps v6.x-151
Normal Gapps v7.x-187
Normal Gapps v7.x-205
Normal Gapps v8.x-261
Minimal Gapps v5.0
Minimal Gapps v5.6
Minimal Gapps v5.8
Minimal Gapps v5.9
Minimal Gapps v6
Minimal Gapps v6.x-151
Minimal Gapps v7.x-187
Minimal Gapps v7.x-205
Minimal Gapps v8.x-261
Installation:
Schritt 1 - Backup
Bevor man mit der Installation beginnt, sollte man auf jeden Fall seine Daten sichern.
ACHTUNG
: Die Wiederherstellung der Apps mit TitaniumBackup ist ab Android 4.3 NICHT mehr möglich. Daher am besten ein CWM-Backup machen. Alternativen siehe HIER.
Schritt 2 - Downloaden
Als nächstes müsst ihr die Daten runterladen, das S2 mit dem PC verbinden und sie auf die interne SD-Karte kopieren.
Schritt 3 - Wipe
Nun geht ihr auf DATA WIPE / Clean to install a new ROM. Weiters geht ihr auf Advanced und wählt dort Wipe dalvik Cache. Danach geht ihr auf Mounts and storage und wählt dort Format system, Format preload aus.
Schritt 4 - Installation
Zunächst geht ihr auf Install zip from SD card und flasht dort das KitKat CWM Recovery. Danach wählt ihr in den Power Options "Reboot Recovery" aus. Anschließend werden die AOSP NeatROM, sowie die GoogleApps, welche optional sind, geflasht.
Wenn ihr das erfolgreich abgeschlossen habt, könnt ihr euer S2 rebooten und die AOSP NeatROM genießen. :cool2:
Screenshots
Screenshot_2014-01-09-15-44-09.pngScreenshot_2014-01-09-15-44-34.pngScreenshot_2014-01-09-15-46-09.pngScreenshot_2014-01-09-15-47-15.pngScreenshot_2014-01-09-15-48-08.pngScreenshot_2014-01-09-15-48-25.png
Screenshot_2014-01-09-15-48-32.pngScreenshot_2014-01-09-15-51-54.pngScreenshot_2014-01-09-15-51-21.pngScreenshot_2014-01-09-15-51-05.pngScreenshot_2014-01-09-15-50-16.pngScreenshot_2014-01-09-15-50-02.png
Für mehr Screenshots siehe Originalbeitrag!!
Ich übernehme keine Haftung für eventuelle Schäden oder Fehler!!
Mit einem kleinen Klick könnt ihr mir schon etwas Freude bereiten und mich für meine Mühe und den Aufwand belohnen. :rolleyes2:
Quellen:
[ROM][July 3][4.4.4] I9100 AOSP NeatROM v6
NeatROM | Simple, Clean & Reliable
Gruß,
Maki535
Reaktionen: shurka, tennesigi, GS750 und 11 andere
Mit diesem Thread hast du unseren Moderatoren sicher ein gefallen getan :thumbsup:
Aber das wiederherstellen der Apps mit Titanium hat bei mir bisher immer funktioniert, egal von 4.1.2 nach 4.4.2 und wieder zurück. Auf was man achten sollte wenn man ART verwenden möchte. Zuerst die Apps wiederherstellen und dann auf ART switchen.
Leider gehen bei allen von mir getesteten aosp-rom manche spiele leider nicht. ... oder ist das bei der rom anders?! Mfg
Das ist generell so !!! Da fehlen eben die Samsung treiber.
Wenn du dein Gerät eher als Gameboy nutzt, must du leider wieder zurück auf Stock.
Habe folgendes Problem:
Nach der Installation und Einrichtung (WLAN und Google) bleibe ich nach dem Restart immer beim Samsung Logo hängen.
Hat jemand eine Idee wie ich weiterkomme ??
Gruß Klaus
@Kai Obey, also ich habe gelesen, dass TitaniumBackup ab Android 4.3 nicht mehr richtig oder vollständig funktioniert. Ich kann jedoch nicht aus eigener Erfahrung sprechen, da ich nicht wirklich viel mit Android 4.3+ zu tun habe.
@Klaus20, bei mir hat das Einrichten von WLAN und Google keine Probleme verursacht. Versuch eventuell nochmal alles platt zu machen um anschließend die Rom erneut zu flashen.
Ich hatte jedoch auch eine Bootloop nach dem zurückspielen des Backups, jedoch lag das an mir.
[OFFURL]https://www.android-hilfe.de/root-hacking-modding-fuer-samsung-galaxy-s2/279717-bootloop-brick-andere-gruende-fuer-den-nicht-start-des-os-der-2te.html[/OFFURL]
Vielleicht findest du eventuell hier eine Lösung. Wie bereits erwähnt, ich hatte das Problem "leider" nicht.
Gruß,
Maki535
Schon mehrmals mit anderen KitKat Roms erfolgreich praktiziert.
kann jemand sagen wie die Menüführung (Sprache) in den Einstellungen ist ??
ist alles eingedeutscht, ist es ein Mischmasch oder nur Englisch ???
Ich möchte das schon in Deutsch alles haben
also die Advanced Settings und die Advanced Options sind schon in englisch, aber das kann man an den Screenshots meiner Meinung nach doch prima erkennen. Aber die Menüführung ist nicht wirklich kompliziert und sollte auch kein Problem für die darstellen, die nicht besonders gut die englische Sprache beherrschen. :D
Gruß,
Maki535
So mittlerweile konnte ich das Problem mit den Samsung Logo lösen:
"Full wipe, install rom, install gapps, reboot, enable art, reboot, wait 10-15min"
Mit "enable art" konnte ich noch nichts anfangen - vielleicht kann mir jemand was dazu sagen.
Habe noch die Schwierigkeit mit
a. USB - wie kann ich über den PC auf das Handy kommen ??
b. ext SD - wie komme ich auf die ext SD ??
c. wie kann ich auf den Touchwiz wechseln ??
Vielleicht kann mir jemand dabei helfen ??
Gruß Klaus
ich hatte die jetzt mal drauf, bin aber wieder zurück auf CM11.
Es ist mir einfach zu viel englisch, fast nichts auf deutsch, ist für mich nicht aktzepdabel. Dann hat die Rom eine Auflösung da braucht man zum lesen eine Brille. Sowas sollte doch nach dem flashen die richtigen Einstellugen haben.
Einstellmöglichkeiten Farbänderungen der Statusbar sind gut aber eben nicht alles, das bieten andere Roms auch mit 4.4.
Wie ich aber Sale so kenne wird er da noch viel arbeiten um die ROM voran zu bringen
@PrOTuRK38
Erst mal Danke für die Antwort.
Kannst Du mir sagen welcher Launcher der richtige ist ??
Galaxy S4 Launcher For XHDPI
Galaxy S4 Launcher For HDPI
Galaxy S4 Launcher For MDPI
Galaxy S4 Launcher For LDPI
zu meinem USB Problem habe ich zwar was gefunden weiß nur nicht wo ich den Terminal emulator finde.
"I can't find how to mount USB storage mode that's Y I don't use it"
Open terminal emulator
Type
su
setprop persist.sys.usb.config mass_storage
reboot
auf meine extSD kann ich immer noch nicht zugreifen - irgendwelche Ideen ??
Gruß Klaus
So den Launcher habe ich gefunden - Galaxy S4 Launcher For HDPI - klappt wunderbar.
Klappt den bei Euch USB und die extSD ???
Die Auflösung ist aber echt winzig. Könnte mir jemand sagen, ob man die DPI wieder auf 240 umstellen kann? In der build.prop konnte ich nichts finden, ob man die DPI dort einfach umändern kann.
@Klaus20 Ich habe die Rom gerade installiert und bei mir kann ich ohne Weiteres auf die interne und externe SD-Karte zugreifen.
*edit offenbar habe ich auch root verloren und frage mich, wie ich wieder rootzugriff bekomme? Ok bin selbst drauf gekommen... :p. SuperSU im TWRP noch mal geflasht und gut ist.
Hallo ernie040,
probier mal diese zip über recovery.Hat bei mir bei etlichen Rom funktioniert :thumbup:
  • CeleriterRom v2.2_DPI to 240.zip
Reaktionen: ernie040
hooly moooly :D Super genau sowas hab ich gebraucht. Aber wenn man nen ganzen Tag mit 182 DPI unterwegs war, kommen einem 240 DPI ja riiieeesig vor ^^.
Jetzt weiß ich auch, welchen Wert ich in der build.prop hätte abändern müssen :).
Für alle Interessierten, die die DPI ändern wollen: Entweder ihr flasht die zip von sourly, wenn die Rom schon installiert ist oder ihr ändert vorab in der build.prop der Rom den Wert "lcd_density" von 182 auf die Standard 240. Abspeichern und danach die rom ganz normal flashen.
Ja mit 220 oder 210 ist man schon gut unterwegs ;)
Aber nicht flashen sondern nur booten
Hab nun auf die v2.3 geupdatet und kann keine Nachteile erkennen :). Kleinere Probleme seit v2.1, wie z.B. die Pin-Eingabe wird etwas abgeschnitten dargestellt und die romeigene Kalender-App kann sich nicht mit Google verbinden. Installiert man einfach den Google Kalender aus dem PlayStore gehts wieder.
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
j1gga84
vonharold
vonharold
