[AOSP-ROM][KK][4.4.4] *04.01.16* SlimKat [Weekly 9.1]
  • 386 Antworten
Erledigt.
Da der momentane Threadführer den Opener nicht aktuell hält, gebe ich den Thread frei. Wer den SlimKat-Thread übernehmen und pflegen möchte (paar Danke-Klicks kassieren möchte ;)), möge mir bitte eine PN hinterlassen.
Mit freundlichen Grüßen,
Pr0TuRk38
Reaktionen: GodyP und leechseed
Opener aktualisiert. Hier der Changelog zur 25.1 Weekly:
Code:
Frameworks base: Return: Custom Carrier Label
Frameworks base: Return: UMS support
Frameworks base: Handle backup transport registration dynamically
Frameworks base: Harden against transiently unavailable backup transports
Frameworks base: Slims Hardware Key Rebinding
Frameworks base: Speed up the navbar
Frameworks base: Make menu unlock configurable
Frameworks base: SystemUI: Pimp-up Media Tile (double tap during play)
Frameworks base: finally fix carrier lable shows on first boot sometimes
Frameworks base: use on virtual POWER_KEY own global menu handling
Frameworks base: TRDS change auto detect light conditions method
Frameworks base: Add support for ADB over network
Frameworks base: Notification : Fix app info long-press
Frameworks base: core: Added national roaming info for Jazztel Movil in Spain
Frameworks base: core: added national roaming info for Spring Mobil in Sweden...
Frameworks base: Initialize pointer members to NULL to avoid illegal reference
Frameworks base: MediaFocusControl: Deny audio focus if notification stream is 0
Frameworks base: Set Settings.Global.WIFI_SCAN_ALWAYS_AVAILABLE default value
Frameworks base: Fix error checking in MemoryFile.
Frameworks base: Fixed stylus eraser being rejected by palm rejection
Frameworks base: Fixed incorrect calculation of dirty invalidation area
Frameworks base: FLAG_PRIVILEGED disappears if privileged app is updated and rebooted
Frameworks base: Only send storage intents after boot complete
Frameworks base: Remove unused field from AssetManager.
Frameworks base: Telephony: Modify code to check that PUK code length is always 8.
Settings: fix Display settings FC on manta or devices without crt mode effect
Settings: Remove notification pulse and light for devices without LED
Settings: Add CPU & RAM info.
Bionic: Moar optimizations
dalvik/vm: Dalvik startup with a low memory footprint
Mms: reload default drawable if it changed during the instance
DashClock: Added condensed font option
DashClock: Added separator between extensions
DashClock: Added text density option
DashClock: Fixed touch feedback, broken in an earlier commit Fixed clock metrics for ...
DashClock: some TRDS adjustments
DashClock: add background color choice + add more colors for text then just ...
DashClock: add preference theme to NextAlarmSettingsActivity
DashClock: add src api paths back
DashClock: make actionbar consisten with KitKat theme and fix
DashClock: disable backgroundcolor preference if opacity = 0
DashClock: Fix menu overflow button on dslv
Updates on display-caf, audio-caf and media-caf
Updates on frameworks native
Tons of device upstream and device specific fixes (see device changelog in download area for details)
Translation updates
Reaktionen: CoMar und leechseed
dirty flash über 2.4 beta incl neueste gapps...bleibt beim slimkat logo hängen
...zurück auf 2.4 beta, bootet...nun hab ich allerdings probleme mit dem sync und playstore zeigt keine verbindung :(
Hast du deine Google Apps nachgeflasht?
Ja allerdings die neuen die für die 2.5 empfohlenen waren. Die alten hab ich nicht mehr
Der ursprüngliche Beitrag von 15:20 Uhr wurde um 16:27 Uhr ergänzt:
Google Konto gelöscht ... Rom und gapps erneut geflashed nun gehts wieder. Soll verstehn wer will
@crocodilechris
Mit undo meinte ich rückgängig machen. Wie du schon geschrieben hast, war zuvor nichts ausgewählt. Ich hab mir auch schon gedacht das dies nicht wirklich der Fall war/ist. und es nur nicht sichtbar war/ist. Frage ist dann halt noch was die Standard Konfig ist.
Hatte eben nur auf ein offizielles Wort gehofft.
Für den Rest der Mitleser, darum gings.
Dachte ich mir schon fast. ;-)
Wollte deinen Beitrag auch nochmal pushen, weil der so übergangen wurde...
Reaktionen: leechseed
RC1? :O heißt das die sind bald fertig? :)
Betrifft die Statusbar. Wo kann man die dauerhaft einblenden? Ich finde dazu nichts. Weis das Jemand?
Einblenden?
Expanded Desktop ausschalten.
Oder in den Einstellungen der Statusleiste das automatische Verstecken ausschalten.
Bei den Einstellungen zur Statusleiste habe ich nur die Möglichkeit zu bestimmen, ob die Uhr angezeigt werden soll oder nicht. Ich habe wirklich alle möglichen Einstellungen angeschaut; finde aber leider nichts. Ich habe RC1 installiert.
Was willst du denn alles einstellen?
<--das
Ich denke das wird eine Launcher-Einstellung sein und keine slimkat
Neue Weekly online mit Tag RC 2:
http://www.slimroms.net/index.php/changelog/419-slimkat-build-2-6-rc2-weekly
Changelog:
Code:
 Changelog:
New devices: p5100 and p5110
Frameworks base: Fix Derp in Chamber of secrets
Frameworks base: Appears black screen fix for a while
Frameworks base: AssetManager cookies should be int32_t and not void*.
Frameworks base: Fix dest == src bugs in Matrix.cpp.
Frameworks base: Fixed race condition in Spinner.DialogPopup on null reference.
Frameworks base: [ActivityManager]: Fix the activity visibility state not sync between ...
Frameworks base: GpsLocationProvider: look for config file in /etc/gps.<ro.hardware.gps>.conf
Frameworks base: Framework: Super advanced Custom Toggle
Frameworks base: implement noise suppression for phone calls
Frameworks base: fb: handle for our navigation bar recentspreload in the button
Frameworks base: SystemUI: Fix missing top task in recent panel.
Frameworks base: fb: handle globalmenu in SlimActions not over Powerbutton anymore
Frameworks base: Perform NTP lookup at Mobile data connections
Frameworks base: fb: unbreak recents animations on thumbnail click or dismiss recents screen
Frameworks base: fb: Handle navbar heights correct on dpi changes + more
Frameworks base: fix search textfield
Frameworks base: fix number picker blue line and highlight
Frameworks base: Fixed cancel() not working correctly
Frameworks base: Fix the issue that the top of fullscreen dialog is clipped away
Frameworks av upstreams
InCallUI: do not use reflection
Bluetooth: roll back phonebook sync changes
Bluetooth: Fix BT failed to enable issue.
Telephony: White emergency dialer
MediaProvider: Allow holders of WRITE_MEDIA_STORAGE to write to secondary external storage
Mms: Fix Null pointer expection when Phone is in low memory
Mms: The draft still exists after forwarding mms to the same sender
Mms: Display message type properly for MMS and SMS
Mms: Resize the image in background
ContactsProvider: make lookupAndCacheId() synchronized
Torch: add 2nd sysfs luminosity
Settings: 'When to daydream' dialog does not follow the JB dialog design guide
Settings: Bleed keyguard widget picker list into translucent bars
Settings: Fix memory leak in ManageApplication
Exchange: Fix mismatched function arguments in Contact query
Camera2: add option to prevend autofocus cancel if preview stopped
Camera2: Add an option to maintain the focus mode when using touch-to-focus
DashClock: fix dialog blue divider
Email: trds: fix white bg on email compose for sw600dp
Browser: Implement client-side incognito mode
Browser: Show a startup page in incognito mode
Browser: blue to grey browser's progress bar
Gallery2: gallery: change typo '&&' to '||'
SlimCenter: improve navigation
Bionic: Fix problems with certain games and apps
Bionic: fix toro and toroplus problems
Several translation updates
A lot small fixes
For device specific changes check the changelog which is published on the download section.
And as usual a lot device tree upstreams, fixes and ehancements
Reaktionen: bbfh, Pr0TuRk38, Lizzy1965 und eine weitere Person
Vielen Dank crocodilechris :)
ich habe das gleiche problem.
um es einmal klar zu stellen:
statusbar: die leiste, die man normalerweise immer sieht (mit uhr, akku, datum etc.)
notifaction bar: wo neue nachrichten etc angezeigt werden.
QS Drawer: mit diesen kacheln
man kann unter "navigation" - "navigation bar" diese dauerhaft anzeigen lassen, jedoch werden dann auch die softkeys angezeigt, die ja beim S3 überflüssig sind (wegen der hard keys).
und ist es irgendwie möglich die notifaction bar (beim herunterziehen), wieder die verschiedenen optionen, wie Wlan, 3g und optionen anzuzeigen? das geht meiner meinung nach nicht und das finde ich nützlich. es ist zu umständlich immer zum qs drawer zu wechseln um zu den optionen zu gelangen.
Ich merke zudem gerade, dass es nie ständig angezeigt wird... gibts da eine lösung für?
walangoo
walangoo
walangoo
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
