Sir Charles
Neueste Stable 9.0 ist heraußen (für uns leider nur Weekly)
SlimRoms presents
Features:
Stable 9.0
Features:
- Settings revamp
- Heads up transparency and colour
- Added SlimLauncher [remove nova launcher]
- Proximity Wake: Add support for checking proximity when waking device (for specific devices)
- Volume panel time out
- Status bar ticker
- Automatic Proximity Speaker
- Fix notification icons overlapping with centre clock
Updates:
- frameworks/av updates aosp caf
- frameworks/base updates aosp caf
- frameworks/native updates aosp caf
- APN updates
- Translations
- rhine updates
- Revert "ril: Support for SEEK on Android",cleanup fstab,Add IPC Security Config,Remove IPC router security configuration Updates
- samsung_qcom-common updates
- Copy recovery scripts to correct place,Place files in correct location for real
- p31XX/p5XX updates
- Automatic translation import,P31XX: allow OC,P31XX: add PVR to Kernel,P31XX: quash SELinux denial for healthd,P31XX: update smc service again
- d2lte updates
- Migrating XTRA from gpsonextra.net to cloud based izatcloud.net
- samsung_msm8960-common updates
- Update HAL API versions and fix warnings
- oppo_msm8974-common updates
- build: Avoid poisoning the host binaries with bad ABIs
- kernel_sony_msm8974 updates
- intellidemand: cumulative updateis to version 5.5,Final version bump!,scripts: remove localversion "+" from kernel version strings
- samsung_espresso10 updates
- Massive Upstream
- V500
- Toro
- Toro+
- I9100
- I9500
- N7000
- Crespo
- Maguro
- Taoshan
- Galaxysmtd
- Moto_msm8960 (won't get the update)
- Moto_msm8960dt (won't get the update)
