[AOSP-ROM][KK][4.4.4] *04.01.16* SlimKat [Weekly 9.1]
  • 386 Antworten
Ja hab es jetzt einfach mal an die Steckdose gehangen. Am PC wird es leider auch nicht erkannt.
Wenn nichts hilft werde ich mir wohl ein neues zulegen müssen.:/
Würde ein USB-JIG helfen?
Weekly 6.2 Changelog
Code:
Hey guys
New weekly is rolling out now. This week we have aside a lot bug fixes and improvement two major original slim features merged
Attention: moto_msm8960 devices now have 3.4 kernel and require KK bootloader
M8 failed and will not be receiving a weekly
1. Quiet hours rework. You ever wished to setup your quiet hours different on different days? No problem anymore. A big interface allows now nearly everything you can imagine to setup your quiet times exactly like you want to have. For more info see this post.
2. Slim Heads Up! Under the title.....heads up meets SlimKat....SlimKat meets Google IO....we merged an own heads up version into our source. The difference to the known other solutions is that we stay near to googles idea. Heads up is for important notifications and for nothing more. We do not use blacklists or similar or do not need to parse long settings values.....with ease you can simply enable it on the apps you want with a long press on the notification. It is deeply integrated into the system and feels simply natural now for every app. Of course we have on top some useful features, native heads up support on dialer MMS and email app and most important a lot work went into fixing the remaining bugs of the hidden heads up aosp code.
For more information check following links:
Heads up meets SlimKat....SlimKat meets Google IO
The main code with explanation in the commit message.
Edit: Jenkins is having trouble so builds might be broken. Team will verify tomorrow. Night
Features:
Settings: Rewrite Quiet Hours
Contacts: add TRDS resources for menu expander icons
Dialer : Don't hold on to views used in listviews
major frameworks/base updates
major frameworks/av updates
major frameworks/native updates
upstream hardware_qcom_display-caf-new
upstream hardware_qcom_media-caf-new
upstream hardware_qcom_audio-caf
LTE icon instead of 4G on all devices
more translations
Devices:
 jflte updates
allow mpdecision to manage sleep modes,add permissions for mmcblk1 scheduler; increase read ahead cache size,support flashing loki'd recovery images
i9500 updates
Update init script from XXUFNB3,Add Mobicore support,Select Exynos 5410 specific EGL flags
i9500 kernel updates
v4l2: Add RGB32 pixel formats to header,Kbuild: export videodev2_exynos_camera header,cypress-touchkey: Add keydisabler
m8 updates
Revert "Include HTC EasyAcess" Included from vendor as it should have been,update adreno,Remove unnecessary LTE overlay option, BoardConfig: remove unused (and incorrect) flag,remove mpdecision no sleep flag,evert "selinux: set permissive for now"
rhine-common updates
Include missing header,secure tad socket,remove unused flag,Remove unnecessary data icon overlay options
sony_msm8974 kernel updates
Rhine: Update version after CM merge,msm: kgsl: Protect CP_STATE_DEBUG_INDEX,msm: kgsl: Mark the IOMMU setstate memory as read only, msm: kgsl: Protect SMMU registers from being written by the GPU,msm: kgsl: Enable protected mode for A3XX,stereo call recording support
kernel_lge_hammerhead updates
Massive kernel updates. A lot improvements from the AOSP L preview release.
p31xx updates
P31XX: add BOARD_NO_APSME_ATTR flag
p51xx updates
P51XX: add BOARD_NO_APSME_ATTR flag
moto_msm8960dt updates
CM upstream
falcon updates
proprietary-files: No need for seperate xt1033 libs
motorola_msm8226-common updates
GPS: Minor hal update, proprietary-files: Use stock rild/libril to fix missing phone number,root: Update post_boot and switch to interactive
motorola_msm8226 updates
CM upstream
motorola_qcom-common updates
root: Fix up the thermald.conf symlinks for 3.4 kernels, proprietary-files: Commonize msm8960 and msm8960dt where possible,Disable lpa.decode to fix headset playback on msm8960
moto_msm8960 updates
CM upstream
Reaktionen: Sir Charles
bekomm mit der aktuellen weekly ein com.android.phone FC. kann das jemand bestätigen?
Mal versucht unter Einstellungen/Apps die Daten/Cache der Telefon-App zu löschen?
nun ein 3tes mal geflashed und nun gehts. soll verstehn wer will :flapper:
Moin. Das Slim Team hat jetzt einen YouTube-Channel, indem sie u.a. neue Features zeigen und erklären.
Den Anfang macht:
SlimRoms - SlimKat 4.4.4 Weekly 6.2 New Features: http://youtu.be/3McmrQfw67s
weekly 6.4 ist up!!!
Features:
HeadsUp: Correctly add and remove the window
QuiteHours: Extra daily times
Major frameworks/base updates aosp caf
Major frameworks/av updates aosp caf
Major frameworks/native updates aosp caf
Update to recovery (TWRP)
display-caf-new updates
audio-caf updates
media-caf-new updates
libhardware updates caf
libhardware_legacy updates caf
frameworks_opt_telephony updates
hardware/ril updates using CM's caf for qcril "without msim"
Update Nova Launcher to version 3.0.2
More Translations
galaxys2-common updates
add netflix hack
media_codecs: Don't try to use absent VP8 decoder
Enable use of FFMPEG codecs for extended formats
fix front cam video recording
Exynos camera fixes
camera: add video snap param and set to "false"
Fix sdcard mounting
recovery.rc cleanup, fstab cleanup
Repo cleanup/fixes
http://www.slimroms.net/index.php/downloads/dlsearch/viewdownload/625-i9100/12485-slim-i9100-4-4-4-build-6-4-weekly-5587
greetz
Thread aktualisiert.
Mit freundlichen Grüßen,
Pr0TuRk38
Hi
Habe grade die stable Version der slimkat installiert, jetzt fehlt mir super su.
Habe es aus dem play store runter geladen, jedoch kommt dann die Meldung: Installation fehlgeschlagen.
Wie kann ich wieder zu root rechten kommen?
Mfg
Edit: ah, ich habe die apk im twrp geflasht. Jetzt geht es!
Noch eine Frage: da ich mein s2 verkaufe, wollte ich dem Nachfolger eine stabile KK Rom installieren. Da bin ich mit dieser stable 4.4.2 besser bedient als mit den weeklys , oder?
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
ich hab die neueste Weekly 6.4 auf mein SGS 2 geflasht und... mir ist mit den neuesten Gapps (sowohl Mini als auch normal als auch die Gapps von der Weekly 6) der Play Store abhanden gekommen. bin nach der Anleitung im ersten Beitrag vorgegangen (Löschung Cache + Dalvik - Installation - neuerliche Löschung Cache und Dalvik - Reboot)
Was kann ich tun, um den Play Store zurückzubekommen? Muß dazu sagen, dass vor einigen Tagen schon Fehlermeldungen in Gmail aufgetaucht sind, dass der Dienst nicht kompatibel sei... hab dem nicht viel beigemessen, aber jetzt....
Hat wer eine Idee?
Edit: bin jetzt auf die Weekly 6 mit den Slim normal 6-118 Gapps zurückgegangen und: Play Store ist wieder da. Bleib dann halt mal beim Weekly 6 und hoffe, dass es bei der Stable 7 (wenn wieder eine kommt) anders wird. Muß halt auf die Heads Up-Meldungen verzichten ;)
Playstore hat nichts mit der ROM zu tun. Wenn du also HeadsUp haben willst, die 6.4 flashen und dann einfach die GAPPS. Dann ist der PlayStore auch wieder da.
SlimRoms presents
Weekly 6.6
update to 4.4.4_r2
New Device: Bacon
LG G2 family will not recieve weekly this week
Features:
Devices:
  • sony_msm8974 kernel updates
    • Update script,Bump version,Togari: Enable Motorola's memutils,Togari: Compile with -Ofast,Remove ffast-math gcc flag,Add -Ofast optimization option, readahead: make context readahead more conservative
  • qcom_common updates
    • qcom/common: Added O_NOFOLLOW to avoid follow the symlink,power: Disable the 8974pro-specific,display on/off path,power: Add support for SET_PROFILE hints,power: Kill logspam,power: Add support for CPU boost hint
  • mako updates
    • prepare for new thermal engine,Enable QRNGD,Enable -O3
  • mako kernel updates
    • mpdec: fix missing log message on resume if !scroff_single_core,mpdec: if !scroff_single_core unboost all cpus while suspending,mpdec: FIX BUG#27,vfp: since we use hardfloat, change the modifer accordingly
  • skyrocket updates
    • Updated kernel source config. Moved kernel source flag to msm8660-common
Hallo beicuxhaven,
danke für die Antwort. Leider hat das aber nicht funktioniert.Weekly 6.4 mit Beta Gapps 6.x - 162 und 6.x - 160 haben beide keinen Playstore gezeigt. Bin dann auf die Gapps der Weekly 6.0 zurückgegangen, also 6.0 -118 und das hatte auch keinen Effekt.
Dann habe ich die Weekly 6.0 geflasht und die Gapps 6.0-118 dazu und der Playstore war wieder da.
Also in Tabellenform
Weekly 6.4 + Beta Gapps normal 6.x-162 ==> kein Playstore
Weekly 6.4 + Beta Gapps mini 6.x-160 ==> kein Playstore
Weekly 6.4 + Beta Gapps normal 6.0-118 ==> kein Playstore
Weekly 6.0 + Beta Gapps normal 6.0-118 ==> Playstore vorhanden
weiß halt nicht, was ich davon halten soll...
werde nach meiner Rückkunft aus dem Urlaub versuchen, die neue 6.8 Weekly zu flashen und schau mir dann an, ob es dort dann gehen wird. ;)
Reaktionen: beicuxhaven
Moin, wichtige Frage:
kann ich "einfach" die neueste Slimkat über die installierte Slimsaber
flashen oder muß auch dann (gleiche Romfamile) ein Full wipe gemacht
werden?
Gruß vom Printer
Erledigt! einfach gemacht und läuft.
@beicuxhaven:
ich hab im Changelog der aktuellsten Beta Gapps folgende Passage gefunden:
2014-07-23 02:13 dankoman * structure/system/priv-app/Phonesky.apk: Phonesky: turn self-updates (and, consequently, auto-updates) back off so play store doesn't update itself to non-multi-dpi/non-trds stock version
Das könnte das Problem mit dem Playstore lösen... werde ich alles sehen ;)
SlimRoms presents
Weekly 6.8
Features:
Devices:
  • oppo_common updates
    • bacon: add other gesture for torch and cleanup,bacon: let the frameworks handle the camera,oppo-common: add screen off gesture control - custom action per gesture
  • i9300 updates
    • Set multi-colored battery led,enable eject sdcard,Fix battery led control for real this time
  • oppo_msm8974_common updates
    • Overlay mms_config to increase allowed picture size,Increase volume of handset-mic to match stereo level,Separate handset-stereo-dmic-ef from dmic-ef,Remove custom bitwidth from audio devices,Multi-offload supportreenable gapless,Enable support for true 24-bit audio,set correct permissions for flashlight_enable proc
  • i9500 updates
    • Remove deprecated defines,Move camera ID file to sane location,Set correct pixel format for recovery,enable eject sdcard
  • jflte updates
    • disable zsl for ffc,remove unused gps-nomsb.conf,Utilize charger class for offmode charging,tcp buffer config,wifi: bring in settings from msm8960-common
  • exynos5410 kernel updates
    • [media] fimc: Move camera file paths to sane location,[media] fimc: Move camera ID file to sane location
  • d2lte updates
    • d2: Enable built-in WiFI,fix usb,revert blobs libinvensense_hal.so "fixes bootup issues",Utilize charger class for offmode charging
  • msm8226-common updates
    • root: Update post_boot and switch to interactive,Add CM performance profiles and recovery power modes,Remove local copy of ebtables as it is tracked now
  • kernel_moto_msm8226
    • Up to par with CM again.
mit jeder weekly gibts neue überraschungen hrhr
hab die 6.8 geflashed, gapps hinterher also alles wie immer, nur diesmal ist beim reboot beim Samsung Logo schluss. komme auch nicht mehr ins recovery
und nun...?
Wipe>Rom drauf>Start ins OS>Neustart>Recovery>Gapps installieren>Start ins OS
kann nix wipen wenn ich nicht ins recovery komm
walangoo
walangoo
walangoo
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
