[AOSP-ROM][KK][4.4.4] *04.01.16* SlimKat [Weekly 9.1]
  • 386 Antworten
Neue Weekly 5.9 samt neuer Gapps ist online :thumbup:
Feature
  • more translations
  • Add color values for ease of TRDS theming
  • fixed quick record on specific languages
  • Telephony: Glowpad transparency setting easier to find now
  • audio-caf: upstream from cm
  • qcom-fm: upstream from cm
  • libhardware_legacy upstream from cm
  • allow build with OpenJDK,javac 1.7,Some changes added to compile and run with Java 6 and Java 7.
  • Fix compilation of Enum on JDK 7,java7: Implement new Locale APIs,art: Fix building under JDK7
  • bootable_recovery: updated twrp tp 2.7.1 (for devices that apply)
  • FB:QuickRecord: Fix crash on other languages,Grant qcom_oncrpc group to system_server,decouple SW FLP and HW FLP overlay flags,Combo Provider: Get the package name from resource,Combo Provider: Specific location screening,Fix for crash in LocationManagerService,Clear cached locations when location providers disabled Bug: 12118307,
  • Slim Recents: Option to show topmost task,Always show topmost task collapsed
  • fmapp2: Fix the build
  • Frameworks AV: upstream from cm
  • System UI: update circle battery UI to be inline with CM
Device Specific
  • m7-kernel upstream
  • m7 common-upstream
  • m8-kernel upstream
  • m8-common upstream
  • Update Flo blobs for 4.4.3
  • Update Deb blobs for 4.4.3
  • vendor_qcom: Remove unneeded blobs
  • P31xx: Preload libjhead in init
  • P51xx: Preload libjhead in init
  • i9100G: Preload libjhead in init
  • jflte: clean up overlays
  • d2lte: update blobs
  • mako-msm:camera Check if client is NULL before calling ion_free,Check if client is NULL before calling ion_free,Fix camera crash when ctrl_q is empty,Fix mctl release crash issue
  • g2: kernel upstream
  • geeb: camera fixes for race conditions in abnormal snapshot stop,fix race condition in snapshot,N4 configuration to enable IPv6 RA filtering,upstream merge from 4.4.3
  • falcon: updates both base and kernel,starting lag is now gone,if anyone has camera issues to do a full wipe include /data
  • motorola_qcom-common: massive upstream from cm
  • motorola_msm8226-common: massive upstream from cm
Reaktionen: Pr0TuRk38 und Sir Charles
Changelog 5.10 Weekly 6/22 Weekly
Time for weekly!!!!
4.4.4 is here..........
New Devices: pyramid,i9500 (build error),*Skyrocket,*moto_msm8960dt (Moto X,*Droid Maxx-Dev Edition)
Feature
Introduce controls on wake lock interface
more translations
frameworks base- Keyguard updates,Add Dialpad key padding
Dialpad padding is a feature for dialer apk
Correctly close IME keyboard if Calculator is launched
Camera2: add missing 4MP option string
Settings: Change desc for battery charging text color
bluedroid: Disable AVRCP 1.5 by default
Device Specific
d2lte: Revert "d2lte: update blobs"
galaxys2-common: Enable Apps2sd for galaxy2-common devices
jflte: jflte: fix the auto brighness curve
hammerhead:*fix offline charging,update blobs for 4.4.4,update fingerprint for 4.4.4,add slim govenor,make slim governor as default
flo: make SlimPie more sensitive,Update Flo blobs for 4.4.4,
deb: make SlimPie more sensitive,Use Flo blobs for 4.4.4 till we get the proper ones from Google
Mako: Update fingerprint for 4.4.4,Update Mako blobs for 4.4.4
Yuga: Enable app2sd
fusion3-common: update selinux policy,update mpdecision startup
p31xx: kernel upstream
p51xx: kernel upstream
motorola_msm8226-common: upstream from cm
motorola_qcom-common: upstream from cm
falcon: upstream from cm
m8: upstream from cm
fusion3-common: Adreno driver cleanup
sony_qcom-common: Adreno driver cleanup
sony_rhine-common: Adreno driver cleanup
sony common: update extract file script
mako: massive kernel upstream from kernel.org,update to 3.4.92
i9300: update camera wrapper
t0lte: update camera wrapper
n7100: move back to prebuilt driver with camera wrapper
Slim beta Gapps für KitKat 4.4.4 gibt's ebenfalls im Downloadbereich auf der Slim Homepage ;)
Reaktionen: twokrass, Sir Charles und Pr0TuRk38
So, nachdem das jetzt auch bei der Weekly 5.10 auftritt, wage ich mal zu fragen:
Ich habe für meine Kontakte mp3-Klingeltöne eingestellt, die auf der SD-Karte (aber auch versuchsweise im internen Speicher) liegen. Solange das Telefon läuft, funktioniert das auch alles, aber nach einem Neustart kommt entweder nur der Standard-Klingelton (der sich überraschenderweise die eingestellte mp3-Datei "merkt") oder irgendein anderer Ton.
Was kann das für Gründe haben?
Bin für jeden Hinweis dankbar!
Stable 6.0
Ok we've gotten to a point where we think we are stable, at least for most devices :D
New devices: I9500 (for real this time) Man we can't get it right, Next time.
Dropped devices: Yuga (dm no longer owns it)
Changes
  • Fix Topmost feature
  • Fix battery charging percentage color applier
  • Fix Battery stat app
  • TRDS: Fix Volume panel background
  • Add ASCII logo to edify script
  • more translations
Device Specific
  • Geeb: Update fingerprint for 4.4.4
  • G2: update loki,recovery: Add a loki script as a recovery transformation step,Fix the loki product name
  • Yuga: use retail name for PRODUCT_MODEL,re-enable "Eject SD card" option,yuga: fix /dev/input/event11 permission,major upstream CM
  • hammerhead: major kernel upstream,update to LINUX 3.4.94
  • manta: update fingerprint to 4.4.4
  • flo: update fingerprint to 4.4.4
  • HLTE: Move to common msm8974 repo,fixup permissions for inputs,disable world_phone overlay,Fix GPS problem for CDMA variants
  • msm8974-common: remove network modes overlay,Fix audio context sepolicy error
  • deb: Update fingerprints to 4.4.3 OTA
  • m8: add bdroid config,enable LCD KCAL sysfs support,LCD_KCAL: Color Control driver for M8,lcd_kcal: Correct the copyright information
Known Bugs:
  • I9300/t0lte/N7100: Graphical glitches on some games
  • Falcon: Slower boot time (~20-30s)
  • moto_msm8960: Graphical glitches in landscape (disable hardware overlays to solve
  • Skyrocket: Ondemand causes random reboot. (stick with Interactive)
  • P31xx: Screen-Off-Animation ignoring our hwrotation=270 (disable screen off animation to solve)
Devices running as Weekly
  • I9500
  • I9300
  • T0lte family
  • N7100
  • I9100 (Inactive DM)
  • I9100g (Inactive DM)
  • N7000 (Inactive DM)
  • I9000 (Inactive DM)
  • Cresoi (Inactive DM)
  • Pyramid (Inactive DM)
  • V500 (Inactive DM)
  • Maguro (No testers)
  • Toro (No testers)
  • Toro+ (No testers)
  • Grouper (No testers)
  • Tilapia (No testers)
Neue Gapps sind auch auf der Slimroms-Webseite verfügbar.
Reaktionen: CoMar und Pr0TuRk38
Bitte noch beachten, dass es für unser I9100 "nur" eine weekly build 6 und keine Final gibt, das liegt wohl daran:
I9100 (Inactive DM)
Inactive DM = Inactive Device Maintainer
-> Sprich für das S2 wird gerade nicht mehr spezifisch entwickelt, daher nur eine weekly und keine stable.
Auch steht in den Sternen ob es für unser S2 jemals Android L geben wird, ich gehe nicht davon aus..!
Changelog der Build 6 weekly:
http://slimroms.net/index.php/downl...lim-i9100-4-4-4-build-6-weekly-5290-changelog
Reaktionen: RedDr4g0n und Sir Charles
Das wäre wirklich sehr schade, da Hardware seitig es keine Probleme geben sollte..
bevor ich gestern SlimKat aufgesetzt habe, habe ich Root erfolgreich durchgeführt und konnte diese auch einsetzen um einige Backups machen zu können. Heute sind die Rechte aber wieder weg.
Bevor ich jetzt irgendwas zerschieße, wie bekomme ich wieder Root?
Habe TWRP 2.7.1
Zum Beispiel im SlimKat-Thread nachzulesen:
Systemeinstellungen=> "Über das Telefon"=> 7Mal auf "Buildnummer" tippen (bis dort steht, dass man Entwickler ist)=> Systemeinstellungen=> Entwickleroptionen=> root-Rechte (oder so ähnlich) und root an Apps vergeben.
Reaktionen: Romario
:blushing: uups ganz vergessen, Danke!!
Nullo Problemo ;)
Also sollte man bei letzter stable bleiben oder auf weekly updaten?
Die weekly funktioniert einwandfrei, sofern ich das beurteilen kann.
Was is da anders zu final 5
@ slu: in der Hauptsache wohl, dass slimkat jetzt auf Android 4.4.4 steht plus die ganzen Änderungen, die hier angeführt sind:
"Changelogs since last stable 5.2, 5.4, 5.6, 5.8, 5.9, 5.10 "
mir ist allerdings heute die Lautstärkeregelung "abgestürzt", also nachdem ich das S2 über die Lautstärketasten auf lautlos gestellt habe, konnte ich es nicht mehr laut drehen, nur über das Menü. Nach Neustart war das Problem aber weg.
kann man Novalauncher Prime installieren oder kommt es da zu Konflikten mit dem installierten Launcher?
@ Romario: also, soweit ich das sehe, verwendet Slimkat den Nova-Launcher. in dessen Einstellungsmenü wird auf die Prime-Funktionalitäten als kostenpflichtiges Detail hingewiesen, also wäre ich der Meinung, dass das funktionieren sollte.
Geht problemlos, keine Konflikte gefunden.
"App wurde nicht installiert.
Ein Paket mit dem gleichen Namen, aber in Konflikt stehender Signatur, ist bereits installiert"
Die Standardversion muss also erst deinstalliert werden, wenn man die App als APK installieren will.
Die interne Upgrade-Funktion habe ich noch nicht ausprobiert.
Hey Leute,
gerade eben ist mein S2 bei 1% Akku einfach ausgegangen ohne die Meldung das Telefon wird heruntergefahren.
Habe es versucht mit einen vollen Akku neuzustarten aber da passiert nichts.(schwarzes Bild)
Habe noch einen dritten Akku leider klappt der genauso wenig.
Ich habe vorher nichts an Apps oder an der Rom geändert sie lief 3 Monate ohne Probleme.
Habe alle sonstigen Tastenkombis ausprobiert ohne Erfolg.
Die Slimkat version 4.4.2 ist drauf + slimkat kernel.
Weiß jemand rat?
Ich hoffe doch sehr für dich, das es irgendein Software problem sein müsste.. Doch es klingt ganz Stark danach das die Hardware (also das Galaxy S2) den Geist aufgegeben hat.. Aber vielleicht weiß ja jemand was man tun könnte etc.. Hast du es schon probiert mal an ein USB Port - Am PC anzuschließen? (vielleicht hilft das was..) Bzw einfach mal ein Ladegerät für etwas längere Zeit drüber laufen lassen. Auch wenn die neuen Akkus voll sein sollten, könnte es sein das das Handy es anders sieht (Software Fehler oder so). Gruß Red
walangoo
walangoo
walangoo
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
