[AOSP-ROM][KK][4.4.2] *09.06.14* Resurrection Remix [V. 5.1.5][Linaro]
  • 140 Antworten
jetzt mal eine blöde frage.. Rom funzt super bislang, aber wie zum henker kann ich bitte screenshots machen?
Leiser Button + Power Button
gibt ein neues Update auf v5.1.4-20140602
Da war wohl einer einen Tock schneller als ich :)
Hier ein Changelog:
Code:
# Resurrection Remix KitKat 4.4.2 - v5.1.4-20140602 # Basic
- Add gesture anywhere
- Add equalizer tile
- Add compass tile
- On-The-Go mode & shake to turn on/off torch
- Add system app remover
- Added Power button to available NavigationBar buttons
- Add on-the-go and volume as Default tile
- Fliptile animation:For Compass Tile & On-The-Go Tile
- SystemUI: Make wifi combo margin themable
- Lockscreen: Avoid SystemUI crash due to NPE - fix all bıtmap derp
- Fix resource leaks
- Fix hiding ADB notification
- CM11 Themes: Use package name from AndroidManifest
- wm: Underp menu key release processing
- Fix circle battery opaqueness for the low battery color
- wm: Make the default menu longpress action configurable at build time
- wm: Simplify menu action decision paths
- quiethours: fix vibrate option
- Keyguard : Fix album art sticking after playback is stopped
- fix default lockscreen targets
- CM11 Themes: Don't kill setup wizards
- Fix wallpapers not applying in full screen
- Added Non-Roaming for carrier BSNL in UP East and WEST INDIA
- frameworks: allow Keyguard package to be defined in overlay
- Keyguard: Make sure disabling Camera widget
- perf: Don't persist the perf profile across a reboot
- perf: Send a boost hint when a key on the navbar is pressed
- Animate circle battery rotation back to 0 after unplugging
- Bluetooth: Fix for device gets stuck in pairing
- Bluetooth: Acquire wakelock to turn on lcd during Connection
- settings: Move headset option, hide MoreDeviceSettings if empty
- Settings: Remove screen rotation from accessibility
- Settings: Allow access for external apps to launch ThemeSettings Fragment directly
- Settings: read keyguard package name from overlays
- Settings: Disable Battery status preference on ModLock.
- Settings: Remove "Make pattern visible" regardless.
- Settings: Device Maintainers: Remove janice & codina
- Settings: Maintainer : add device Galaxy Note int
- n7100 - Fix sensors - audio hal updates - Update fingerprint
- i9300 - Add iso mode settings to the CameraWrapper - fix preview/camera crash after stopping video record
- ResurrectionSetup updates
- Trebuchet updates
- Theme chooser updates
- Camera app improvements
- Calculator updates
- MMS updates
- Included lot of performance,sound and media updates
- Included All CyanogenMod source updates and fixes
- Check out the source activities for more updates https://github.com/ResurrectionRemix
Der ursprüngliche Beitrag von 20:44 Uhr wurde um 20:46 Uhr ergänzt:
Thread-Titel aktualisiert.
Reaktionen: CoMar
hat schon wieder ein Update gegeben.
Bleibt in der Version auf v5.1.4 aber neues Datum 20140603..
Changelog habe ich noch nicht gefunden..
nur das hier..aus dem XDA Forum
..fixes first boot system ui fc and fix for freezes .much stable. but some of old themes won't work on theme chooser . cm updates doesn't allow to work them ..
Reaktionen: Pr0TuRk38
schade, aber für mich nicht soooo schlimm, grundsätzlich läuft die 4.4.2 ja sehr stabil, und Mit Android 5.0 oder 4.5 oder wie es auch immer heißen wird werden wieder andere eine Chance kriegen und ich hoffe die Roms laufen genau so gut wie diese. :thumbup:
Bald wird mein S2 eh nicht mehr erste wahl sein weil ich das G3 bekomme :flapper:
.. 5.1.5-20140609 ist online.. habe es über die 5.1.4 drüber installiert , Gapps Light installiert und dann Cache gelöscht.. läuffft :smile:
Resurrection Remix KitKat 4.4.2 - v5.1.5-20140609 # Basic
- Navigation bar dimensions
- Ability to disable hardware keys via nav bar settings
- Add android:key in hardware keys enable/disable option to forward enable this option
- Themes: Delete icon resources during uninstall
- Themes: remove unused code
- Themes: uninstallThemeForAllApps shouldn't check if map is empty if it's null
- base: remove extra checks
- Don't cleanup overlay mapping for non-theme apps
- appops: enforce appop for bluetooth disabled action
- About Resurrection: devcard layout - fix FC devcard on lanscape mode
- settings: FC on quick settings editor on tablets without a vibrator
- Add a HAF access permission
- Fix layout recreation check
- CameraTile: Launch default gallery app when long pressing active camera tile
- SystemUI: prevent NPE on clear recents double press
- MtpDatabase JNI: Fixed a memory-leak in getObjectPropertyValue().
- Correct stride for drawing to cached glyph bitmap
- Use alpha channel instead of red in drawCachedGlyphBitmap
- Temporarily hide lock screen unlock targets if opening a widget
- fw: media: Handle NPE due to threading race
- FW: LS Notification: fix FC when an expanded notification gets reposted without bigContentView
- fix derp on INotificationListener
- WallpaperCropper: do not display null bitmaps
- Make theme change broadcast a protected broadcast.
- Reduce memory leaks by removing all views.
- appops: do not prune apps that are not present
- apn: national roaming for ONO (Spain)
- fix more keyguard derp
- Mms: Clear notifications and mark messages read in certain situations
- galaxys2-common: fix front cam video recording
- Recovery - Version 6.0.4.9
- included all cm-11.0 m7 updates
- Check out the source activities for more details https://github.com/ResurrectionRemix
# NOTE:
- This is the final release of Resurrection Remix android kitkat series.I ll catch you guys on next android version A.K.A 4.5 or 5.0 . See you soon .Thank you !
ENJOY!
http://forum.resurrectionremix.com/index.php?topic=2037.new#new
Reaktionen: sucram* und Pr0TuRk38
Mit freundlichen Grüßen,
Pr0TuRk38
Reaktionen: CoMar und sucram*
kann das mal jemand testen..
Wenn ich ein Video mache , Samsung Schriftzug oben , ist das Bild am PC verkehrt rum , also nach rechts gekippt . Erst wenn ich das Handy nach links 90° drehe , also Samsung links, passt es am PC..
"edit"..
scheint auch bei Fotos so zu sein... :confused2:
Ist das nicht normal bei Hochkant Videos und Fotos?
Hallo zusammen, ich habe seit 2 Tagen diese Rom auf meinen Samsung S4 und bin sehr zufrieden. Ich habe aber noch die Version 5.1.4 drauf und sehe jetzt das die Version 5.1.5 draußen ist aber finde sie für mein Samsung S4 leider nicht. Kann mir da jmd helfen?
MFG
In Anbetracht der Tatsache, dass wir hier im Galaxy S2 Thread sind empfehle ich den S4 Thread, einen Besuch im S4 Thread bei XDA oder auf der Resurrection Rom Seite gucken.
Edit: Vielleicht braucht der zuständige Maintainer auch nur ein bisschen mehr Zeit?
@m3stolo
hätte schwören können das es nicht so ist / war...evtl liege ich aber auch nur total falsch..
Fiel mir nur auf als ich ein Video gemacht habe und das halt auf dem Kopf war.. Habe das Telefon im Auto in einer Halterung gehabt und nach rechts gedreht..
Hallo Leute,
ich habe es auf meinen Galaxy S2 das nette Feature Double-Tap to Sleep - eingeschaltet, weiß aber nicht mehr wo !!!
Ich werden noch bekloppt.
Kann mir jemand einen Tipp geben?
Gruß und danke im voraus.
Adrogen
Bei anderen Roms geht das, wenn du zweimal kurz hintereinander auf die Statusleiste tippst. Allerdings nicht auf dem Lockscreen, nur auf dem Homebildschirm und in Apps.
@Androgen
Das ist normal unter Einstellungen/Display.
Gruß Nick
Ist es normal dass bei 4.4.2 kein Playstore dabei ist?
Hab alles gemacht wie es in der Anleitung stand, auch alles von dort installiert, nur ich habe keinen PlayStore (keine App).
Hab dann ausm Netz ne .apk gezogen, jetzt ist er zwar drauf, allerdings schließt sich die App beim Starten gleich wieder, und nichts hilft irgendwie... Kein Neustarten, Wipen etc.
Kann man das Problem irgendwie beheben? Brauch den Playstore.
