Pr0TuRk38
Dauer-User
- 1.551
- Themenstarter
- #81
ART wird mit dieser Version nicht funktionieren!
Mount und Unmount Probleme der SD-Karte sollten nicht mehr auftreten.
Code:
# Resurrection Remix KitKat 4.4.2 - v5.0.8-20140402 # Basic
Attention : Art runtime won't work . on this update . this is cm base source issue . switch back to dalvik before flash the rom
- New boot animation (thanx to therichieboy)
- Fix multi-user
- Live Volume Steps
- IME Animations
- Custom scroll mod
- Developer options: long press back to kill configurable timeout
- Pitch Black Theme for Calendar app
- Pitch Black Theme for Email app
- Quiet Hours: Add 4 state (off, timed inactive, timed active and forced on) support
- Settings: Integrate Voice+ into Settings
- Add T-Mobile and AT&T Galaxy S III maintainer Deliberate
- RR Tools Romanian translations - translated by Vlad Daniel Calin
- Bootanimation: Add continuous splash support
- Revert back to CM camera for now - Devices like i9100:fix for front video camera issues - install 5.0.7 camera app
- WallpaperCropper: Fix crash when set .gif as wallpaper
- Lockscreen Blur: Disable if music is playing
- Settings: Fix Quiet Hours Tile long press action
- Add theme support to Ringtone and Profile pickers activities
- Contacts: Holo Light ringtone picker dialog
- Lockscreen Notifications: some fixes
- Update some translations
- SystemUI: add Indonesian translation
- Base: forward port DC-HSPAP support from cm-10
- Base: Proper security labeling of multi-user data directories.
- Base: Fix the random UI corruption
- Halo: Modify behavior
- Halo fixes
- Fix Floating window bug
- Frameworks: do not kill favorite recent apps
- Frameworks: notify arrayadapter early that data has changed on clear all
- Frameworks: fix possible NPE + missing expandable panel
- Base: Mirroring layout on RTL languages
- Contacts: Add support for import contacts to local phone storage
- Galaxy S2: Fix the inability to mount/unmount sdcard
- smdk4412: update fimc_capture and sr130pc20 cam driver
- smdk4412: update camera resources
- smdk4412: update batteryCurrentNowPath
- i9300: audio: bring back removed microphone fix
- i9300: audio: fix input device selection
- Included lot of sound and media updates
- Included CyanogenMod source updates
