Pr0TuRk38
Dauer-User
- 1.551
Die ROM befindet sich im frühen Anfangsstadium von daher können noch Fehler vorhanden sein!
Weder ich, noch Android-Hilfe.de, oder sonst irgendwer gibt Euch Garantie für Schäden oder sonstiges an Eurem Gerät, seit Euch dessen bitte bewusst!!!
Bugs:
Bugs sind die gleichen wie bei CM 10.2
Installation:
0. BackUp der aktuellen Rom anlegen
1. Neustarten in das Recovery-Menü
2. Wipe Data / Factory Reset
2. Wipe Cache
3. Wipe Dalvik Cache
4. Format Data
5. Format Cache
6. Format System
7. Paranoid Android Rom.zip flashen
8. Gapps flashen
9. Neustarten
Changelog
Build 31.10.2013
- Merged 4.3.1
- latest commits from cm and PA
- HALO colors feature
- User selecting bug is fixed so you can change user
Downloads:
Paranoid Android 3.99 Build 31.10.2013
Paranoid Android 3.99 Build 12.10.2013
Paranoid Android 3.99 Build 08.10.2013
Google Apps:
Google Apps vom 13.08.2013
PER-APP-DPI/LAYOUT. This is not tablet mode! Hybrid engine allows you to target apps individually. You get to pick their actual layouts which can tranform content drastically. Keep in mind, this has nothing to do with build.prop hacks or DPI changes. We list all layouts an app brings, you choose one, its as easy as that. It does not matter if your device runs itself in Phone-, Phablet or Tablet-UI, your apps will always look as you like. On top of that you can scale apps, to fit your screen, that way you can even bring full fledged tablet apps and make them run perfectly. Nothing will break, nothing will shrink, your market will be fine. Additionally we have rewritten many parts of the android framework and fixed countless of AOSP bugs to make way for these modifications - our "tablet mode" runs better on a phone than on a real tablet, that is guaranteed.
PER-APP-COLOR, Paranoidandroids newest invention. Define apps in your regular hybrid panel. See your phone fade into the color definition of your current app, press home or go elsewhere and it fades back. Create as many combinations you like, you can even dabble with opacity. This feature is made possible by our hybrid engine, which is unique to this rom.
Credits
PARANOIDANDROID TEAM
CYANOGENMOD TEAM
codeworkx
XpLoDWilD
molesarecoming
D4rKn3sSyS
And many other peoples
Quelle:
Originaler XDA-Thread
