vanch
- 3
Stoecki schrieb:@vanch
Oder hast du aus Versehen im Kontextmenu unter 'Ausschalten', 'Neu Starten', etc.
"Expanded Desktop" gewählt - damit wird der Desktop erweitert...
Ich wollte grade das Handy zerstören
Stoecki schrieb:@phreakkk
Wie ist die Lage mittlerweile? Hat sich dein Smartphone eingependelt, oder tritt immer
noch ein SoftReboot auf? Schonmal alles durchgewiped?
Gruß!
D4rKn3sSyS schrieb:After thousands of lines of code, and days without sleeping cuz of it, finally got it finished
ps. Yes, it was not only UI, but a lot of fixes and improvements for the app, basically entirely rewrote the way how it fetches/writes values, plus cleaned up a lot.
Ibl: pbl_read_emmc441() read 8k
Ibl: pbl_read_emmc441() read 96k
Ibl: pbl_read_emmc441() read download info
Ibl: pbl_read_emmc441() endop
Ibl: jump() verify_binary_integrity...ok
Ibl: jump() jump!!!
Welcome to Samsung Primitive Bootloader.
build time: Apr 3 2012 20:01:22
current time: f0/10/4 38:7f:78
[set_mmc_ocr] Sector Mode
[hsmmc_init] MMC card is detected
Product Name : VYL00M
<display_card_info:1009> ext_csd
<display_card_info:1011>card_size: 15028
Total Card Size: 15029 MByte
mmc_init: card initialization completed!
pbl found bootable sbl in #53248.
jump to sbl 0x4d400000.
Secondary Bootloader v3.1 version.
Copyright (C) 2011 System S/W Group. Samsung Electronics Co., Ltd.
Board: C1 REV 02 / Apr 3 2012 20:01:29
current time: f0/10/4 38:7f:79
booting code=0xc0c0c0c0
CID:150100 56594c30 304d19c6 1540cc7e
<display_card_info:1046> ext_csd
<display_card_info:1048>card_size: 15028
Total Sector Count: 30777344
MoviNand Initialization Complete!
===== PARTITION INFORMATION =====
DEVICE : MMC
FIRST UNIT : 0
NO. UNITS : 0
DEVICE : MMC
FIRST UNIT : 0
NO. UNITS : 0
DEVICE : MMC
FIRST UNIT : 8192
NO. UNITS : 40960
DEVICE : MMC
FIRST UNIT : 49152
NO. UNITS : 2560
DEVICE : MMC
FIRST UNIT : 53248
NO. UNITS : 2560
DEVICE : MMC
FIRST UNIT : 57344
NO. UNITS : 16384
DEVICE : MMC
FIRST UNIT : 73728
NO. UNITS : 16384
DEVICE : MMC
FIRST UNIT : 90112
NO. UNITS : 16384
DEVICE : MMC
FIRST UNIT : 106496
NO. UNITS : 204800
DEVICE : MMC
FIRST UNIT : 311296
NO. UNITS : 32768
DEVICE : MMC
FIRST UNIT : 344064
NO. UNITS : 1048576
DEVICE : MMC
FIRST UNIT : 1392640
NO. UNITS : 4194304
DEVICE : MMC
FIRST UNIT : 5586944
NO. UNITS : 24133632
DEVICE : MMC
FIRST UNIT : 29720576
NO. UNITS : 1048576
loke_init: j4fs_open..success
<start_checksum:1033>CHECKSUM_HEADER_SECTOR :42
<start_checksum:1035>offset:42, size:1024
Not Need Movinand Checksum
load_lfs_parameters valid magic code and version.
switch_sel_str='1'
load_debug_level: read debug level successfully(0x574f4c44)...LOW
init_ddi_data: usable ddi data.
fuelgauge_implementaion - start
fuelgauge_implementaion - end
fuel_gauge_get_version: [1]=0, [0]=92
init_fuel_gauge: vcell = 3769 mV, vfocv = 3821 mV, soc = 50
microusb_get_attached_device: STATUS1:0x3f, 2:0x0
4809 = (374900 - 358802)*29874/100000
[4] 381183 = (4809 * 100000) / 28706 + 364431
init_microusb_ic: MUIC: CONTROL1:0x0
init_microusb_ic: MUIC: CONTROL2:0x3a
reading nps status file is successfully!.
nps status=0x504d4f43
PMIC_IRQSRC = 0x0
PMIC_IRQ1 = 0x9
PMIC_IRQ2 = 0x4
PMIC_IRQ3 = 0x0
PMIC_IRQ4 = 0x10
PMIC_STATUS1 = 0x1
PMIC_STATUS2 = 0x10
PMIC_STATUS3 = 0x0
PMIC_STATUS4 = 0x0
bootloader base address=0x4d400000
LPDDR0 1st. cached=0x40000000, size=0xe400000
LPDDR0 non-cached=0x4e400000, size=0xa00000
LPDDR0 2nd. cached=0x4ee00000, size=0x1200000
RST_STAT = 0x10000
get_hwrev() = 14
board_process_platform: MAGIC c0c0c0c0 at 40000000!
hw_pm_status: jig_status = 0, chg_status = 0
s5p_set_high_clk: ARM Clock = 800MHz.
......kernel is non signed binary.
DISPLAY_PATH_SEL[MDNIE 0x1]is on
div:2, FB_SOURCE_CLOCK:667000000, FB_PIXEL_CLOCK:25067520
MDNIE setting Init start!!
vsync interrupt is off
video interrupt is off
[fb0] turn on
MDNIE setting Init end!!
Autoboot (0 seconds) in progress, press any key to stop
boot_kernel: debug level low!
checkbit: find RECOVERY
checkbit (0)
ATAG_CORE: 5 54410001 0 0 0
MEMCONFIG: 20e01323 20e01323
ATAG_MEM: 4 54410002 10000000 40000000
ATAG_MEM: 4 54410002 10000000 50000000
ATAG_MEM: 4 54410002 10000000 60000000
ATAG_MEM: 4 54410002 10000000 70000000
ATAG_SERIAL: 4 54410006 1540cc7e 304d19c6
ATAG_REVISION: 3 54410007 e
hardware_ID : 0019c61540cc7e
ATAG_CMDLINE: 40 54410009 'loglevel=4 console=ram androidboot.serialno=0019c61540cc7e sec_debug.enable=0 sec_debug.enable_user=0 c1_watchdog.sec_pet=5 sec_log=0x100000@0x4d900000 s3cfb.bootloaderfb=0x5ec00000 ld9040.get_lcdtype=0x2 consoleblank=0 lpj=3981312 vmalloc=144m'
ATAG_NONE: 0 0
Starting kernel at 0x40008000...
