beicuxhaven
Ehrenmitglied
- 10.437
Changelog Weekly Build 1.9
Massive Bluetooth updates from caf
Merged missing 4.3.1 hardware/ril
Various fixes for Gallery2
Updated many translations
Update Nova Launcher
Update Google Music
A lot small fixes
Added Deb
Added m7vzw
Update Google Music
A lot small fixes
Added Deb
Added m7vzw
gov/scheduler
Wer sich mal anschauen möchte, was der DEV dazu sagt:
xda-developers - View Single Post - [ROM][4.2.2][05/08]Slim Bean - I9100 [Build 8][FINAL]
Ist bestimmt sehr interessant für einige
- update PlayStore to newest version
- update Google Music to newest version
- update Google+ to newest version and integrate into Slim_AIO_gapps (themed from scratch)
- add back AOSP Calendar (is now the same as the google one) with several fixes an themed from scratch
- fixes Email.apk
- fixes Exchange.apk
- Google Now moved as system app
- cleanup
- several TRDS fixes
we just updated our Slim_AIO_gapps with following fixes
- fix broken Voice Dialer
- fix some minor Google+ TRDS glitches
download and flash and you are good to go.
- Root ist von Hause aus deaktiviert. Muss also separat aktiviert werden: Settings / Dev Options / Apps (or Apps + ADB)
- Navigation ring on lockscreen does not unlock unsecure lockcreen to start an action
- bottom SlimPie trigger is sometimes unresponsive. All other are fine
- Es gibt noch kein Sphere, Focal und Spiele werden bestimmt freezen
Installation
- full wipe (means: wipe data / factory reset and format /system)
- install Slim 4.3 ROM
- install Slim 4.3 gapps
- Reboot
Downloads und Changelog
Downloads - i9100
slimroms.net
Ori. Thread XDA
