CandyMaster
- 11
Genau so ist es
[B][SIZE="5"]4.2.1 1.0 WIP[/SIZE][/B]
Details
Created on Friday, 15 February 2013 05:38
[B][U]Changes and Features:[/U][/B]
Full JOP40G base
Add Notification Sound Toggle to PowerWidget
Modified Expanded Desktop Mode
Flip to mute/dismiss call
Add shortcut to Gallery from CameraSwitcher
Privacy mode notifications to Mms
More options added to hardware key rebinding (Last app, Power, Custom app)
Bluetooth MAP (Message Access Profile) Upstream Changes
Add support for FM Radio
Add Quiet Hours QuickSettings tile
Notification Shortcuts
Lockscreen shortcuts
5/8 targets selection
Increasing volume alarm
FM radio API from CyanogenMod
Enhanced GPS
Added increasing volume option to deskclock
And a great deal of smaller cleanup and optimizing.
Captivate & Vibrant
Rebinding for search hardware key
[B]D2[/B]
New way to keep clock at 1512 mhz (kernel)
Updated kernel to 3.0.62
Re-Added OC 1900 mhz (kernel)
[B]I9100G[/B]
Updated to 3.0.63
Added ROW I/O Scheduler
BT and Radio Fixes
[B][U]Fixes:[/U][/B]
Camera focus improvements
Fix leftover glow in NavBar
qcom_common: Tuneups and Cleaning
msm8660-common: Cleanup device tree
Fix Korean font
Fix Facebook App FC
Fix Mms audio clip attach FC
Fix clock opens calendar
Fix battery color mods at lower levels
Faster disk operations
Fixed performance parameters reset on boot
Hmh, also 213 konnte ich jetzt wählen, "as is", also mit den GApps von SB. kA, ob und wie da was gemoddet wurde.vivalasven schrieb:Über die build.prop gehen auch 120,aber alles unter 240 braucht den gemoddeten playstore
Density Changer
Modify your device's LCD Density safely and easily, avoiding the common Play Store compatibility issues after dpi change. (...)
