beicuxhaven
Ehrenmitglied
- 10.437
Avatar ROM
mit der Minimalistik von CM und den Themingmöglichkeiten von MIUI
FullWipe und Wipe Script
- Android JB - 4.2.2
- CM10.1
Stable release 3.0 - 07/02/2013
As CM10.1 has hit the general release, Avatar Team is branching with stable and nightly releases.
Stable releases are marked as 3.0. This is the first stable release from Avatar Team. Stable releases will be weekly or bi-weekly and will be tested extensively by our testing team.
Nightly releases will kickstart in a few days. We will merge CM changes every day and it will also contain experiemental features from Avatar.
We highly recommend to wipe cache/data/dalvik before flashing the stable releases.
Changelog:
Based on CM10.1.0 (General Release)
06/16/2013 - AvatarROM 2.15b release
06/08/2013 - AvatarROM 2.14b release
05/25/2013 - Avatar ROM 2.12b release.
18/05/2013 - With more features and fixes Avatar team releasing the latest version 2.11b
Changelog:
- CyanogenMod RC5 merges.
- Fixes in Theme chooser.
- Launcher:
- Grid size issue fixed across all devices and resolutions.
- Transparency setting changed(1 to 10 transparency, also moved from general to Drawer).
- Fixed the issue with the transparent fade animation while going from Apps to Widgets.
- Fixed some crashes.
- Weebo:
- New UI for editing rules.
- Shows a dialog if rule is broken. If the rule is fine, user can directly enable/disable the rule by tapping on it.
- Weebo icon changed.
- Cyanogen Mod RC4
- OTA Updater app can now flash with Gapps( This time also they need to do manual flashing of gapps. From next time it will be automatic if correct recovery is installed.) TWRP and unlocked clockworkmod is supported. Official locked clockworkmod recovery is not supported.
- Lot of Theme chooser crash fixes.
- Theme chooser gets updates from server, when the theme changes.
- Notification for theme updates.
- Fix for lock screen not showing music status for some themes.
- Launcher
- Crashes reported in error reporter have been fixed.
- Some performance optimizations have been made when scrolling the workspace.
- CM 10.1 code merges till 21st May (RC2 Tag)
- Mixing Themes - When applying a theme, you can now pick the components. Eg: If you want only the lock screen and boot animation from WP7 theme you can now choose it. We are one step closer to MiUi style of mixing and matching.
- Rom Toolbox - Rom images will be available for download from Rom Toolbox app instantly. Fully automated.
- Theme Chooser -
- Support for enabling/disabling components when applying a theme
- Improved facebook sharing and brand new gallery page (Avatar Themes)
- Bug fixes and improved graphics.
- Launcher
- Transitions in app drawer (like workspace)
- App drawer can now be made transparent (no more black background)
- Performance improvements in app drawer scrolling
- Weebo
- Ability to map a particular cell id to a location through location logs
- Fixed bug related to mobile network not available
- Merged with CM 10.1 RC2 tag (May 15th, 2013)
- Added Centre Clock feature - can be enabled/disabled from Settings
- Made Navigation bar themeable - the resource name is nav_bar_bg
- Made Statusbar Transparent - Default Status bar is now 25% transparent. Themes which have transparent status bar can make use of this. Seasons is one such theme.
- Weebo
- A 4x3 weebo widget can be added in homescreen. It displays current location and recent actions taken by weebo. This list is updated whenever there is location change or any actions are performed by weebo.
- Fix for change of location when network is not detected
- Removed cell-Id display from recent events logs. Remove cell-Id entries from recent events list shown in weebo.
- Changed location tracking time options from locations page. Put a "recommanded" text for 4 hours option and removed "5 minutes" tracking time.
- Action notifications are getting cleared now
- Removed Actions in the notifications s when notification is cleared. When user removes notification the actions shown in notification are cleared.
- Launcher
- Feature to lock/unlock homescreen. Once homescreen is locked apps or widgets cannot be moved.
- Fix a bug related to Gesture detection
- Theme Chooser
- Some memory leak fixes
- Added support to share a fav theme on facebook
More info about 2.11b release - http://avatarrom.com/update-2-11b-fo...es-draw-along/
05/11/2013 - Avatar team is proud to present the 2.10b version based on the latest CM 10.1 RC base (Stable build).
05/04/2013 - AvatarROM 2.9b release.
04/27/2013
04/19/2013 - AvatarROM 2.7b Release
- Merged with CM 10.1 RC1 tag (May 8th, 2013)
- Added more space between wifi and signal icons in status bar
- Added gapps version in Error Reporter
- Message Bubbles - Reset the bubbles similar to stock version bubble when not themed.
- Theme Chooser - Themes now display the size of the apk.
- Theme Chooser - Fixed memory leaks
- Theme Chooser - Fixed download problems with some themes - cobalt blue, cobalt inferno etc
- Bazooka --> Fixed Widget scolling issue when Widgets are placed on Home screen.
- Bazooka --> Fixed the dockbar pages issue. You can select number of pages in Settings screen of Bazooka launcher.
- Bazooka --> Other minor bug fixes.
- Weebo --> Fixing the issue where files cannot be read from /mnt/sdcard/weebo folder.
- Weebo --> Contact picker to make it simpler to select the contacts you want to call/send message to.
- Weebo --> New categories in "All rules" callled Enabled and Disabled. This shows currently enabled/disabled rules.
- Weebo --> Location exit condition bug fixed. You can now trigger actions when you leave a particular location.
- CyanogenMod merges till May 2nd 2013.
- SystemUI fixes during expanded desktop (the background was not covering till the end. Also portrait - landscape transition, the notifications wouldn't expand fully)
- ThemeChooser : Fixes for text invisible in installed themes tab for dark themes
- ThemeChooser will not handle market links anymore and Memory leak fix.
- Old themechooser is removed completely.
- Launcher : Fix crash without wipe & make dockbar transperant.
- In OTA updater show that the gapps and rom is installed if they are installed. ( Previously it used to show new or downloaded).
- Change Cyanogen Mod Updates to Avatar Updates
04/27/2013
- Merged CM changes till 24th April ( includes Camera driver fixes for lot of devices )
- Bazooka Launcher
- Fixed some critical issues reported in previous build.
- Added Gestures in workspace. A settings page also added to configure gesture actions. Different gestures like swipe-up, swipe-down, double-tap, home-button press are added. Different actions for each of the gesture can be set in preference.
- Added ""edit workspace"" option in menu button.
- Removed ""pinch to preview mode"". This option is currently disabled for some issues as we can go to preview mode through many other ways. It will be added later.
- Many new Customization options."
- Lockscreen
- Fixed a bug
- Fixed Settings crash on Input Method
- Fixed Version Number problem in Error Reporter
- Theme Chooser
- Removed Old theme chooser
- enabled Total download count of themes
- Sorting themes based on download count
- Sorting themes based on date
- Settings App now launches the new Theme chooser
- Merged with CM 10.1 M3 build( 14th April )
- Changed Error Reporter to send requests to server instead of a google document
- New Theme Chooser fixes
- Weebo fixes
- Support for layout theming
04/06/2013 - AvatarROM 2.6b Release
- Full support for OTA
- Merged with latest CM 10.1 base (Upto Apr 3rd, 2013 - Includes Paranoid style pie control, new Super user app etc)
- Changes in the framework to redirect trebuchet and android launcher resources from CM themes to Bazooka launcher
- Fixed launcher menu settings in app space
- New ThemeChooser - Bug fixes, Performace improvements and new features like download count, caching etc
- Performance improvements in theming engine
- Weebo fixes
- Disabled driving rule in weebo as it was causing lot of confusions
Wipe Data/Factory Reset & Wipe cache partition
Flash downloaded .zip file.
Install Gapps package.
