beicuxhaven
Ehrenmitglied
- 10.437
MoKee OpenSource Project
- Odexed for faster performance (only in official releases, nightlies are deodexed)
- Incremental updates
- Native exFAT support (Samsung devices only)
- HALO
- PIE control
- ListView animations
- Active Display
- Multi window
- Calendar - with lunar and solar calenders
- Lunar calendar in lock screen
- Task switching sidebar in recent apps (the list will increase if you install supported apps)
- Bulk SMS recipients
- Adjustable SMS font size
- SMS sending delay
- Smart dialling
- IP dialling
- Adjustable navigation bar height
- Custom transparency for status bar and navigation bar
- Custom carrier name
- Network speed in status bar
- Auto hide status bar
- Status bar quick peek
- Ad-Hoc peer-to-peer network connection - Use MoKee's built-in kernel, otherwise the function is not available.
- Built in timer in Apollo - determine when to stop playing music
- CRT animation switch
- Smart capture
- Preview option in launcher (similar to the preview function in launchers found in Play Store)
- MoKee NotePad
- MoKee Setup Wizard
Official Site:
MoKee OpenSource | Android Community Rom
Statistics:
é*”趣开æºç»Ÿè®¡
Bug Tracker
MoKee Bug Tracker Main Page
GitHub
http://github.com/MoKee
Kernel Sources:
https://github.com/MoKee/android_ker...msung_smdk4412
Code Review:
Gerrit Code Review
Statistics:
é*”趣开æºç»Ÿè®¡
Bug Tracker
GitHub
Kernel Sources:
Code Review:
Gerrit Code Review
[6 November]
MK43.1-i9100-131106-RELEASE.zip
[31 October]
MK43.1-i9100-131031-RELEASE.zip
Gapps(4.3.0):
gapps-jb-20130813-signed.zip | by Site Owner for Generic Device
[31 October]
Gapps(4.3.0):
Installation
1. Wipe data/factory reset
2. Flash ROM
3. Flash Gapps
4. Reboot
Ori. Thread XDA
Der ursprüngliche Beitrag von 17:31 Uhr wurde um 17:37 Uhr ergänzt:
Wer möchte.. Testet mal..
