gewürzwiesel
Philosoph
- 2.054
Flash dir nen Root-Kernel...
[B]to be included in next nightly:[/B]
[URL="http://review.cyanogenmod.com/16139"]add missing file for "Iec99d52f: Load a device specific key handler"[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16137"]libstagefright: Unbreak live effects[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16130"]msm8660: Add missing define for ANC[/URL] (android_hardware_qcom_media)[B][URL="http://download.cyanogenmod.com/?device=galaxys2"]update-cm-9-20120517-NIGHTLY-galaxys2-signed.zip[/URL][/B]
[URL="http://review.cyanogenmod.com/16089"]stagefright: Fix camcorder effects on MSM8660.[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16127"]Camera: Handle error event from HAL + burst mode code clean up.[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16109"]Bugfix: reboot needed for dock audio checkbox 2/2[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/16108"]Bugfix: reboot needed for dock audio checkbox 1/2[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/13314"]Settings : NavigationBar Customization[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/13306"]NavigationBar : Customization[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16092"]correct phone number format for non contact number[/URL] (android_packages_apps_Contacts)
[URL="http://review.cyanogenmod.com/16082"]Phone - Update Italian Translation[/URL] (android_packages_apps_Phone)
[URL="http://review.cyanogenmod.com/15994"]Settings: Update Turkish translations[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/16059"]Updated Hebrew Translation[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/16058"]Updated Hebrew Translation[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16053"]Camera: fix Thai app name[/URL] (android_packages_apps_Camera)
[URL="http://review.cyanogenmod.com/15984"]Browser missing hungarian translation (Corrected)[/URL] (android_packages_apps_Browser)
[URL="http://review.cyanogenmod.com/15948"]Vibrator/airplane overrides (2/2 Settings)[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/14772"]InputManager: Add system setting to define keyboard locales[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/14675"]Load a device specific key handler[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/15947"]Vibrator/airplane overrides (1/2 Frameworks)[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16026"]hardware/libhardware: Send correct channel count on input[/URL] (android_hardware_libhardware)
[URL="http://review.cyanogenmod.com/15980"]CM9-Settings-Update Russian Translation[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/15754"]Add an option to disable the transformation from SMS to MMS when the lenght of the message is > 3 sms.[/URL]
(android_packages_apps_Mms)
[URL="http://review.cyanogenmod.com/15998"]wifi.c: allow devices to specify driver delay if needed[/URL] (android_hardware_libhardware_legacy)
[URL="http://review.cyanogenmod.com/15978"]CM9-Browser-Update Russian Translation[/URL] (android_packages_apps_Browser)
[URL="http://review.cyanogenmod.com/15977"]CM9-DeskClock-Update Russian Translation[/URL] (android_packages_apps_DeskClock)
[URL="http://review.cyanogenmod.com/15987"]Settings missing hungarian traslation (Corrected)[/URL] (android_packages_apps_Settings)
[URL="http://review.cyanogenmod.com/15634"]Updated Torch icons for ICS and xhdpi[/URL] (android_packages_apps_Torch)
[URL="http://review.cyanogenmod.com/15983"]LatinIME missing hungarian traslation[/URL] (android_packages_inputmethods_LatinIME)
[URL="http://review.cyanogenmod.com/15956"]DeskClock hungarian translation[/URL] (android_packages_apps_DeskClock)
[URL="http://review.cyanogenmod.com/15943"]french: accelerometer flip action[/URL] (android_packages_apps_DeskClock)
[URL="http://review.cyanogenmod.com/15891"]LatinIME: Add Czech QWERTY, enable predictive dictionary[/URL] (android_packages_inputmethods_LatinIME)
[URL="http://review.cyanogenmod.com/15761"]U[/URL][URL="http://review.cyanogenmod.com/15761"]pdated Torch widge[/URL][URL="http://review.cyanogenmod.com/15761"]t[/URL] (android_packages_apps_Torch)
[URL="http://review.cyanogenmod.com/12571"]audio/msm7630: Add support for STRATEGY_ENFORCED_AUDIBLE[/URL] (android_hardware_qcom_media)
[URL="http://review.cyanogenmod.com/12570"]audio/msm7627a: Add support for STRATEGY_ENFORCED_AUDIBLE[/URL] (android_hardware_qcom_media)
[URL="http://review.cyanogenmod.com/16088"]libstagefright: Remove assert failure for kKeyHfr[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/16125"]Camera: Restart preview if video resolution changes in application[/URL] (android_packages_apps_Camera)
[URL="http://review.cyanogenmod.com/16090"]camera: Add debug logging when setting parameters[/URL] (android_packages_apps_Camera)
[URL="http://review.cyanogenmod.com/16111"]RIL: Qualcomm: Unbreak LTE[/URL] (android_frameworks_base)
[URL="http://review.cyanogenmod.com/15540"]frameworks: Fix audio routing when plugged to docks[/URL] (android_frameworks_base)
finnq schrieb:Moment, ich mache ihn dir schnell. Welchen denn? Vertumus hat viele.
gewürzwiesel;3289350 schrieb:Flash dir nen Root-Kernel...
wenn du kannst,nocht den mit den kleinen Kästchen rund und der Prozentanzeige in der mitte.Thilo-Dirk schrieb:der Blaue runde Kreis mit der Prozentanzeige in der mitte.
domy1985 schrieb:Welchen Kernel kann ich da nehmen? Siyah nicht...
Cf root ?
Kjetal schrieb:Meistens der Kernel , gründe kann es viele haben, kann man Pauschal nicht sagen.
