[AOSP-ROM] *23.12.11* The-GingerMOD v0.8--95% Pure GoogleExperience!
  • 76 Antworten
Ok, I'll give another try tomorrow.
But some other users also reported bluetooth audio issues.
Ciao Luca,
i tried it again today. Now all is good with Bluetooth-Audio! :)
But from the 5 first calls, just 4 works with Audio. So there still is a (small) problem with A2SP!?
Strange. Don't know what happened. But I'm happy for now.
Reaktionen: 89luca89
Well!
I knew it cause always worked for me :D
Released v0.3
Changelog v0.3
Slimmed down system now only 230mb!!
Update ninphetamine 2.1.3
Update latest gApps 29\07\2011
Updated StatusBar colors look&feel (see screenshots! more AOSP like power widget)
Revised Multimedia quality via build.prop and media_profiles.xml
Revised Automatic Screen brighness level Thx LockedON again! (added more steps, smoother changes!)
Removed Swype keyboard (downloadable as separate pack)
Removed MotionSettings and MobilePrint (downloadable as separate pack)
Added OverClock Daemon! THX rmk40 madmaxx82 mike1986 and Diamondback2010
Added DualCore daemon script! Thx Again madmaxx82!! see in main thread the infos&settings!
Flupt alles, auch BT Audio :) getestet mit
meinem JVC Autoradio.
Gruß Darkwing
sehr empfehlenswert die rom
bluetooth funst einwandfrei : Smile:
genauso wie die rom ,läuft echt super, viel schneller als stock samsung : Smile:
gruß stefan
This ROM is exactly what I was looking for:
  • AOSP - I don't like the Samsung icons and I don't need the additional apps provided
  • Audi MMI (2007) can access Google contacts of phone book (Samsung original ROM could only access SIM contacts) and incoming/outgoing phone calls work properly (not working with DevNull ROM)
  • Internet connection can be used while connected to car kit (Samsung original ROM blocked internet while connected to car kit)
  • Simple (original) music player (no need to build playlist only to play an album like I had to do with the one provided by Samsung)
  • Playback of Full-HD videos without dropped frames (not working with DevNull ROM)
  • Battery usages looks really good so far - fully charged battery should last about 3 days
I would have preferred that GingerMOD automatically installs the apps I had on my phone before flashing (DevNull ROM does it this way).
I liked the fact that additional packages are provided to be installed using CWM - this way I installed TaskUtility.zip to get the notes app.
The BLN patch somehow does not work although enabled: It makes a sound when an email arrives but the buttons are not switched on. Any idea what might be wrong?
I'm really happy and will press the Donate button in the near future :)
Best regards,
Axel
gruß stefan
Also gehen auch Bluetooth Headsets?
@maestro
Yes they works!
@camueller
Thank you!
about bln it works for me the patch! Try reinstalling the patch!! If not works ill re-see it in the mean while you can use noLed.!
Thank You. i Test it
aber das ist kein AOSP Rom GingerMOd Vanilla basiert auf KG6 deswegen geht Bluetooth audio
Ok - ich war ungenau: GingerMOD _sieht aus_ wie AOSP.
89luca89 schrieb:
@maestro
Shame on me: I forgot to enable LED notification in the mail application. Now it works :)
Axel
Hi. Vielleicht könnte jemand der Moderatoren bitte den Thread aktualisieren? :drool:
Version 0.8 ist seit kurzer Zeit released und ist bereits in der Grundversion herausragend.
Lässt sich mit SetCPU wunderbar bearbeiten und wichtige Parameter sind per init.d script veränderbar.
Beim UV ist zumindest bei mir mit Abyss Kernel gegenüber dem letzten Siyah 2.6.2/3 mehr drin. 100 Mhz/800mV funktionieren einwandfrei. Sreen Off mit cpu deepsleep level 6 und screen off 100 Mhz funktioniert tadellos. Musik hören ohne laggs kein Thema und wake up bei ankommenden Anrufen ist ok. 2 Sekunden bis der Screen anspringt. Aber bis ich das Handy aus der Tasche gezogen habe dauert es eh länger :drool:
Auf welcher Stock baut die 8er auf?
Basiert auf der letzten XWKK5 Source, Android 2.3.6. Es ist halt nahezu ein AOSP ROM, Android Open Source Project. Fast alles "untouched" und pur eben. Es fließt förmlich dahin. Ich bin kein Freund von Benchmarks, aber ausm Stand über 6050 Punkte im Antutu Benchmark lassen für sich sprechen.
Ich habe mal den Siyah Kernel 2.6.2/3er (kurzeitig) probiert, aber der integrierte Abyss 3.0 lief damit viel besser.
Akku-Laufzeiten sind meines Erachtens sehr gut, das muss jeder für sich selber anpassen. Spielraum ist dafür da.
Schade das nicht die KL1 genommen wurde denn dann hätte ich es mal getestet.
Welches KL1 ROM benutzt du denn? Weiß echt auf Anhieb was an KL1 neu ist :confused2:
Verwende die XWKL1 und die ist neuer als die KK5.
Super :D Meine Frage war wohl zu schwer für dich, um sie zu beantworten :sad::D
Egal :drool:
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
j1gga84
vonharold
vonharold
