[AOSP-ROM] *20.07.12* Monsta CMMIUI | Online -> v5 [2.7.6][Latest CM9 Nightly]
  • 57 Antworten
Kaffee4Eck
Kaffee4Eck
▬▬▬▬▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬▬▬▬▬▬
Kaffee4Eck's Monsta CM9MIUI Version: 5
ROM-Info:
- Based Android 4.0.4 CM9 RC2
- MIUI 2.7.6
- MIUI Launcher
- CRT-OF
- APN for almost all networks
- 3G/Data/Phone/Bluetooth/GPS/Audio/Everything
- ADFREE Hosts File to block Spam/Advertisements
- USB File Explorer
- WIFI Tethering and USB Tethering
- Inbuilt Root Permissions App
- Fluxi Kernel
- 3 Way Reboot (Hold Power Button)
- Multilanguage
Kown Bugs:
- No FM Radio (I will do my best to add it)
- Need time to boot (CM9 Problem?/Bug?)
- No more known.
Download:
K4E_MONSTA_05
Addons:
Fixes:
gappsmaps.zip
Changelog:
v4
Updated to latest CM9 Nightly.
Performance boosts.
Updated CM9 Apps.
Added Google Maps
Updated Camera
v3
- Updated ALL Files to 2.7.6
- Tweak all Frameworks
- Rework of all Frameworks
- Added more languages in all Apps
- Much more.
v2
Translated all Apps (Only Contacts and Phone need more lang-files "in v3)
Updated to latest CM9 nightly.
Tweaks at Startup
Zipaligen
Updated all Files to MIUI 2.7.6
Fixed Inbuild Root Permissions
Fixed near all Problems.
ThemeFix in first post (Wont work with ROM-Inbuild-Updater-Script.)
Added more Tweaks into APP's
v1
Inital Release.
Everything should work.
Fluxis Kernel
Tweaked Frameworks. (Added CM9 stuff and MIUI stuff)
Tweaked many Apks.
Credits to:
chillzz (For inspiration and some Files.)
Cyanogenmod (For CM9 Versions)
Xiaomi (For MIUI Versions and frustrated, confused times)
My family​
K4E_MONSTA_04
K4E_MONSTA_03
K4E_MONSTA_02
Screenshots unten:
  • gappsmaps.zip
Reaktionen: anime und Laux007
Gibt es noch Screenshots?
Kommen gleich
Gesendet von GT-I9100 Kaffee4Eck
EDIT:
Scrennshots hinzugefügt.
Reaktionen: Marcel2580
geht bei dieser rom audio over usb?
und fm radio?
FM Radio wird direkt getestet. Ich benutzte dies nie.
Audio über USB abspielen leider auch noch nie probiert. Sollte aber eigentlich funktionieren.
Changelog v2:
Translated all Apps.
Tweaks at Startup
Zipaligen
Reaktionen: Scum
Da ich seit langem den Look von MIUI haben will und auf CM9 nicht verzichten möchte, wäre diese Combi super.
Ist das nur der MIUI Launcher?
Wird die ROM an die aktuellen Nightlys angepasst?
Ansonsten sehen die SC gut aus.
ROM: CM9
Kernel: Fluxi XX
Dies ist die komplette MIUI v2.7.6 basierend auf der letzten CM9 Nightly, ja diese ROM wird immer an die neueste Nightly angepasst.
Es traut sich wohl keiner an eine Installation ran. ;-)
Was ich nicht ganz verstehe ist, dass MIUI und CM9 ja eigentlich eigenständige ROM sind.
Wie kann man diese verbinden?
Indem die Basis für die Rom, auf die MIUI aufbaut normalerweise seit v4 von Samsung ist. Der gute Chillz (Ich denke mal die Rom baut auf seiner auf ??) hat sich die Mühe gemacht und die Samsung Basis mit CM9 Basis getauscht.
Ich habe von cmiui lediglich 4 smalis benutzt. Der Rest ist komplett cm9 und miui
Worin liegt der Unterschied zu dieser ROM:
[AOSP-ROM] *04.07.12* cMIUI 2.7.4 [4.0.4][AOSP][Aroma][xxKernel][OTA][Multi
Damit wollte ich auch nicht sagen, dass du iwas kopiert hast. :unsure:
Der Unterschied liegt an der Verarbeitung der ROM und der Updates bzw. der CM9 and MIUI Version. Ich versuche immer so schnell wie möglich alles aktuell zu halten.
Habe sie schon geladen! Mit testen habe ich keine Probleme!
Teste alles mögliche gerade die etwas ausgefalleneren Roms gefallen mir gut! 99% der SII Roms sind doch AOKP/AOSP/CM9 mischungen wo es keine wirklich extreme unterscheide gibt (tweak hier tweak dort)!
Ich wäre über etwas mehr Infos zu diesem CM9/MIUI mix auch denkbar.
Installation problemos. Läuft bis jetzt sehr gut.
Das Bootlogo könnte etwas cooler sein. ;)
Habe es auch gerade geflasht ...
da es die erste Version ist bleibt ja noch genug zeit um es zu verbessern :drool:
Wobei mir die Bootanimation relativ egal ist! Auf den Inhalt kommt es an :tongue:
Hi
Hab die ROM auch installiert. Aber jedes mal wenn eine App Root Rechte anfordern sollte kommt immer wieder der Homescreen. Erst nachdem ich es manuell in der Rechte App erlaubt habe funktionierte es problemlos.
Ansonsten find ich die ROM mit dem Fluxi sehr Smooth.
Changelog v2:
Translated near all Apps.
Tweaks at Startup
Zipaligen
Reaktionen: hermi327
Wann wird damit zu rechnen sein? :D
dj3d
karu2003
X IE N o T IR i X
X IE N o T IR i X
j1gga84
vonharold
vonharold
