Chris1996
Stamm-User
- 141
Hi Leute! Den einen oder anderen wird es bestimmt freuen, dass es nun auch AOKP offiziell für unser s2 gibt
 Mehr Infos kriegt ihr auf der Aokp-Page oder im XDA-Thread.
Viel Spaß damit und Happy Flashing!
JB-MR1 Bild 6
 New features
 Milestone 1
 New Features:
 Build 5
 New features:
Build4
Build 3
 Official Releases
goo.im | androtransfer | Google Apps
 Nightlies
 Hier klicken für den mit JB kompatiblen Flash Player
 Hier klicken für den Apollo Music Player
	JB-MR1 Bild 6
 New features
		Code:
	 Fully rEvamped NavBar and Lockscreen UI in ROMControl
Themeable lockscreen
Scrollable toggleS are back
WebGL on the Nexus 10
Option to daydream on wireless charger
Volume adjusT sound preference
Open sOurce Superuser thanks to Koush
StatusBar hide toggle
Sleep toggle
	 Milestone 1
 New Features:
		Code:
	 Adjustable NavBar width for Tablets
 Allow "Vibrate on Touch" behavior for Slide unlock
 Toggles can be hidden like in ICS - long press on the Settings button!
 Clickable (short & long configurable) Clock and Calendar in the Notification Slider
	 Build 5
 New features:
		Code:
	 Custom NavBar for Tablets
 NavBar widgets are back from ICS
 Highly customizable Lockscreen Ring targets, with a shiny new editor in ROMControl! (also thanks to CM for the base of the framework part)
 Alternate default app picker (like in GB)
Menu UI Overflow Toggle
Option to disable vibration for Notification expansion
RAM Bar in the Recents panel
Timeout and instant lock options for Slide lock
Tons of beautiful new icons by Kwes
VPN Traffic amount in human readable format
We are working with the guys at CyanogenMod to submit our features & enhancements back upstream to their source.
[B][COLOR="Red"]Warning:[/COLOR][/B] If you are a flashoholic and not coming straight from Build 4 (you built it from source, or tried some unofficial/nightly builds), you might have to reset your Lockscreen targets, as we changed some critical code in the last few days.
Adam made an awesome app for AOKP - [URL]=https://play.google.com/store/apps/details?id=com.cashew.kangerator]Kangerator[/URL] - you can track / download our new releases or even the Gapps packages with it. Dont forget to check it out!
Gapps has been updated as well, please flash the newest one with this release.
		Code:
	[B]New features:[/B]
 Custom NavBar Ring on tablets
 Force dual panel view on any device
 Flip or shake your device to snooze/dismiss the alarm (check alarm settings)
 Take screenshot from NavBar
 Enabled USB mass storage emulation for certain devices (i9*)
We fixed the NavBar custom icon bug, and some minor issues with eg. fastcharge and autobrightness as well.
		Code:
 SMS QuickReply
 Stopwatch & Countdown in the Clock app (CM)
 Expert Calculator functions (Graph, Matrices, etc.) (CM)
 IME Switcher & Vib/Ring toggle as NavRing target
 We fixed some serious bugs (you can set custom
ringtones now), and made a few other fixes & improvements as usual.
		Code:
	1) Macht ein Nandroid Backup
2) führt einen Fullwipe durch
3) flasht die [URL="http://androtransfer.com/get.php?p=AOKP/i9100/aokp_i9100_jb_build-4.zip"]ROM[/URL]
4) flasht die [URL="http://goo.im/gapps/gapps-jb-20121011-signed.zip"]Gapps[/URL]
5) reboot
	 Official Releases
 Nightlies
