[AOKP-ROM][JellyBean] *30.03.13* [4.2.2] Android Open Kang Project [JB-MR1][BUILD 6]
  • 689 Antworten
Wieso postet nie jmd den Changelog dazu?
Changelog:
Code:
Project name: frameworks_base
•gdanko - Volume music controls (1/2)
•Will DeBerry - SystemUI: Add option to hide signal bars
•Mike Wilson - SystemUI: WiFi Signal Text
•Roman Birg - SystemUI: add signal text (1/2) WIP
•Steve Kondik - am: Don't crash if cacheDir can't be created •Michal Stawinski - Fix SkBitmap::fPixels not being locked correctly
Project name: packages_apps_ROMControl
•gdanko - Volume music controls (2/2)
•Jonathan Steadman - ROMControl: statusbar signal options (2/2)
Kaum erwähnenswerte Änderungen
Reaktionen: janosik
Changelog:
Project name: vendor_aokp •Pierpaolo Pernici - Goo.im updater suppor
Project name: frameworks_av •Andrew Sutherland - fixup for non QCOM targets •Ricardo Cerqueira - CameraParameters: Underp non-qcom hardware •Shashi Kumar - libstagefright: Enable suspension policy •Ed Carrigan - camera: add missing symbols for HTC 8660 camera HAL •Ethan Chen - camera: remove redundant QCOM_HARDWARE ifdefs •Mingming Yin - AudioFlinger: Disable AUDIO_WATCHDOG to reduce high audio power
Project name: frameworks_base •Stevespear426 - Powermenu: Add screenshot, make airplane mode removable •Mike Wilson - framework: hide NavBar on demand, and basic Nav controls in Power Dialog. •Danesh M - Kill App on Long-Press Back Key (framework) •Dirk Rettschlag - LED: add LED brightness control (2/3) •Stevespear426 - Navbar: Allow for up to seven navbar buttons
Project name: packages_apps_ROMControl •Jonathan Steadman - RC: moar streamlining •Stevespear426 - Powermenu: add screenshot and airpane mode back in. •Mike Wilson - Option to enable NavBar controls in Power Dialog •PhantomGamers - Kill app on long-press back key (ROMControl) ported from David van Tonder •Dirk Rettschlag - LED: add LED brightness control (3/3) •Dirk Rettschlag - LED: enable charging LED (1/2) •Jonathan Steadman - RC: Signal text strings cleanup •BMc08GT - Add Theme.Translucent.NoTitleBar to ShareClipBoard
Project name: android_system_core •Naveen Kalla - Define TCP buffer sizes for HSPAP, HSDPA, HSUPA and EVDO
Project name: android_hardware_qcom_display •Steve Kondik - hwc: Correct default value of dynThreshold •Steve Kondik - hwc: Set premultiplied alpha flag appropriately •Neti Ravi Kumar - hwcomposer : Use system property to set DYN composition threshold •Saurabh Shah - overlay: Remove OVASSERT from getFormatString utility •Ramkumar Radhakrishnan - libgralloc: Allocate buffer Fix. •Prabhanjan Kandula - libcopybit: fix YUV buffer alignments as per gralloc •Prashant Surana - Add support for PIP, picture in picture feature •Ramakant Singh - libqdutils::Use qcomuiClearRegion for dynamic composition •Steve Kondik - hwc: Enable MDP_BACKEND_COMPOSITION
von [ROM][JB] Android Open Kang Project - i9100 - Build-1+ [Unofficial][06/09] - Page 42 - xda-developers
Latest build:
Changelog:
goomanger will now show up and announce updates.
Code:
Project name: proprietary_vendor_samsung •Steve Kondik - quincy: Update blobs •Steve Kondik - msm8660: Update props •codeworkx - p31xx: variant specific sensor module Project name: vendor_aokp •Pierpaolo Pernici - add new goo.im team username AOKP Project name: android_system_core •Aviral Gupta - include/system: JB upgrade for the MPQ8064 Project name: platform_manifest •Pierpaolo Pernici - Track AOKP platform_dalvik Project name: android_hardware_libhardware •Adam Farden - audio: fix when using ICS audio blobs •Aviral Gupta - libhardware: Load the MPQ HAL for the MPQ8064 target AOKP Project name: android_hardware_libhardware_legacy •Aviral Gupta - audio: JB upgrade for the MPQ 8064 AOKP Project name: android_hardware_qcom_audio •Ethan Chen - audio/msm8660: add ifdefs around LPA implementation •Giulio Cervera - audio/msm8660: always show device list •Y Mehta - audio/msm8660: Fix for LPA playback stops when suspend happens •Giulio Cervera - audio/msm8660: ifdef ANC •Sidipotu Ashok - audio/msm8660: Fix for native crash during LPA swith to BT. •Giulio Cervera - audio/msm8660: underp routing/ifdef •Giulio Cervera - audio/msm8660: fix build after ANC patch •Deepa Madiregama - audio/msm8660: Add ANC headset support •Y Mehta - audio/msm8660: Fix to use low power audio session for MP3 and AAC clips •Giulio Cervera - audio/msm8660: allow building with LPA •Giulio Cervera - Revert "audio/msm8660: disable caf policy for now"
Reaktionen: Marcel2580, Redbull320 und janosik
So sollte es aussehen, wenn es ein update gibt.
+1
Bei der neuesten Version "20120906" kommt wenn man in den Einstellungen auf Mobilfunknetze und dann auf Zugangspunkte (APNs) geht ein FC.
Hat noch jemand den Bug?
@alex
Eben geflasht, funzt bei mir einwandfrei :) evtl nochmal flashen, Cache/Dalvik wipen oder Neustarten :) vieleicht hilft das.
Andi
Also ich habe gerade nochmal neu geflasht. Aber es gibt immer noch das selbe Problem. AAuch wenn ich in die Rom-Einstellungen gehen will kommt ein FC.
Kann es sein dass es was damit zu tun hat, dass ich in der .zip Datei meine eigenen Klingeltöne in den media Ordner einfüge?
________________________________________________________________________________________________________
Also ich habe jetzt mal die unveränderte Rom neu geflasht (sauber geflasht) aber immernoch der selbe Fehler (mit dem FC bei APNs).
Hm okay, sehr komisch. Ich persönlich bin bei Vodafone und du? Eventuell liegts daran. Aber mobiles Internet funzt bei dir oder was willst du in den Einstellungen machen? :)
Andi
Gesendet von unterwääägs :D
Mh.. mal ein anderes Modem probiert? Oder mach mal die Simkarte raus. Kann nicht an der ROM liegen.
Gesendet von meinem GT-I9100
@andro
Naja er hat ja nur die aktuelle Version wie ich heute auch geflasht, aber das mit der SIM Karte ist auch ne Idee :)
Problem gelöst. Jetzt funktioniert sogar meine modifizierte Rom (also eigene Klingeltöne drinnen und diverse apps gelöscht).
Ich bin bei Telekom bzw. Congstar. Und bei manchen Roms sind die APNs schon drinne und bei manchen irgendwie nicht.
Modem hatte ich bis jetzt immer dasselbe und es hat auch immer funktioniert.
Aber jetzt zu meiner Lösung: Ich habe mir invertet Gapps geladen und die geflasht. Das hat wohl die Rom nicht ganz verkraftet. Jetzt habe ich mir die normalen Gapps geflasht und es funktioniert alles.
Hat jemand invertet Gapps die funktionieren?
http://forum.xda-developers.com/showthread.php?p=29343474
Die funktionieren bei mir sehr gut keine probs. Kann mir garnicht vorstellen das es bei dir die gapps waren.
In xda nach justinbean inverted gapps suchen. Funktionieren bei mir perfekt.
bei mir auch. :biggrin:
Hallo zusammen!
Ich bin neu hier und möchte mich hier mal mit einbringen! ;)
Erst einmal vielen dank für die klasse ROM! :thumbsup:
(Bin aktuell auf der Version vom 4. Sep.)
Und dazu direkt mal meine Frage:
Wie kann ich die neueste Version flashen, ohne das ich meine Daten/apps verliere?
(Bevor die frage kommt, ich habe schon oft mein SGS2 erfolgreich geflasht und kenne mich auch gut mit "High Tech" aus)
Ich habe halt nur noch nie ein "update" geflasht.
Ich würde mich sehr über eine hilfreiche und schnelle antwort freuen! ;)
Gesendet von Iconia Tab A510
Einfach per recovery flashen, ohne Data wipe/ factory Reset, dann wird nichts gelöscht. Solange du bei der selben Rom bleibst, brauchst du nix beachten. Bei Problemen nomma die Caches wipen.
Reaktionen: AyDee
Ganz normal drüber flashen, ohne wipe data, nur wipe dalvik und wipe Cache ausführen. Danach die gapps flashen und dann neustarten. Fertig.
Reaktionen: AyDee
dj3d
karu2003
Pr0TuRk38
Pr0TuRk38
Pr0TuRk38
j1gga84
vonharold
vonharold
