[AOKP-ROM][JellyBean] *30.03.13* [4.2.2] Android Open Kang Project [JB-MR1][BUILD 6]
  • 689 Antworten
[Ironie on] Na dann schalt doch Bluetooth an dann geht es.[Ironie off]
Nee mal im ernst. Was meinst du denn damit? Schildere doch mal dein Problem dann kann man dir auch helfen.
Neue Nightly verfügbar:
Goo.im Downloads - Downloading aokp_i9100_unofficial_Jan-22-13.zip
Changelog for aokp_i9100_unofficial_Jan-22-13.zip
AOKP Project name: frameworks_base
•kecinzer - FW: Updated czech translation
•Dirk Rettschlag - Lockscreen: provide haptic feedback on longpress unlock
•João Ventura - Mms auto-retrieval (1/3): framework
•Roman Birg - SystemUI: simpler RAM bar implementation
•dhacker29 - TelephonyProperties: Alpha ID fix for OPEN_CHANNEL and other p-commands (1/2)
•Zaphod - Alternate Signal Layout (1/2)
•Dirk Rettschlag - Lockscreen: enable longpress on expand challenge handle (1/2)
•Dirk Rettschlag - Lockscreen: option to use carousel animation when switching widgets (1/2)
•Roman Birg - SystemUI: unlock keyguard to open nav ring apps
•Dirk Rettschlag - QuickSettings: enable theming of user label
•Danesh M - Camera : Powerkey shutter (1/2)
•jt1134 - Camera: add ISO mode support
•Emerson Pinter - camera: add power mode support
•codeworkx - telephony: set additional audioparameters for incall audio
•Roman Birg - new toggle: sound state (ring/vib/silent)
•Roman Birg - Framework: NavBarColor (1/2)
•Roman Birg - SystemUI: fix GPS toggle not changing states properly
•Roman Birg - SystemUI: cleaner recents key implementation
•Roman Birg - SystemUI: update nav bar keyguard logic
•Dirk Rettschlag - Lockscreen: add missing import to fix building
•Dirk Rettschlag - Lockscreen: fix hiding of initial page hints for landscape
•rdgate - Updated Japanese translations
•Gergely Szell (sethyx) - Hungarian translations by Klasszsrac
AOKP Project name: frameworks_av
•codeworkx - camera: add cityid parameter and getInt64 stub for t0lte camera hal
•madmack - Make an exception for MR0_AUDIO_BLOB in loadHwModule_l
•codeworkx - libmedia: implement samsungs isSeparatedStream, built audioparameter
•Ricardo Cerqueira - audioflinger: Allow mixed use of JB A2DP HALs and ICS policy
AOKP Project name: frameworks_native
•Vishrut Shah - JB_MR1: native/libs/ui: Adding fix for conf 2.0 seg faults
CyanogenMod Project name: android_frameworks_opt_telephony
•Ankit Vani - SamsungExynos4RIL: Allow signal strength to be handled for GB modems
•João Ventura - Mms auto-retrieval (2/3): framework
•dhacker29 - CatService: Alpha ID fix for OPEN_CHANNEL and other p-commands (2/2)
•athurh - SamsungExynos4RIL: fix signal strength
•jt1134 - SamsungExynos3RIL: don't send IccStatus notification on CDMA devices
•João Ventura - Fix restoring network mode preference on reboot
•Danny Baumann - Make ringing audio focus handling work with 'Speed up audio on MT call' flag enabled.
•Alex Yakavenka - Telephony: Unregister from UiccController when disposed
•Jeevaka Badrappan - Telephony: Start DataStallAlarm only on Data CONNECTED state
•codeworkx - telephony: set additional audio parameters for incall audio (2/2)
•Mike Kasick - SMSDispatcher: Add option for sending pseudo-multipart SMSes
•Jerome Pilliet - Some changes added to compile and run with Java 6 and Java 7.
•Shareef Ali - d2ril: change readint offset of one
AOKP Project name: device_lge_mako
•faux123 - mako: updated kernel
•Alex Yakavenka - Add overlay for config_speed_up_audio_on_mt_calls
•xoomdev - Add hardware info for Mako
•Ricardo Cerqueira - Enable low latence audio
•Stevespear426 - Fix sound for mako
AOKP Project name: device_samsung_tuna
•Gergely Szell (sethyx) - Bump kernel to LeanKernel 5.8
AOKP Project name: device_samsung_manta
•Sam Mortimer - Enable OTG storage
•xoomdev - Update proprietary list
Project name: device_samsung_i9100g
•Ankit Vani - i9100g: fix signal strength for updated RIL
•codeworkx - i9100g: build libnetcmdiface
AOKP Project name: android_device_samsung_d2-common
•Bajee11 - Enable Focus Modes on d2 devices
•invisiblek - d2: bluetooth: disable BOARD_BLUETOOTH_USES_HCIATTACH_PROPERTY
•Shareef Ali - d2: adds support for 5.1 sound
•Steve Kondik - d2: Add VOIP and call recording inputs
•invisiblek - d2: re-enable Trebuchet overlays
AOKP Project name: device_samsung_d2vzw
•xoomdev - Update hardware info for d2vzw
AOKP Project name: device_samsung_maguro
•xoomdev - Update hardware info for maguro
AOKP Project name: android_device_samsung_d2tmo
•xoomdev - Update hardware info for d2tmo
AOKP Project name: device_samsung_toro
•xoomdev - Update hardware info for toro
Project name: android_device_samsung_galaxys2-common
•Andrew Dodd - permissions: Remove some nasty 777s
•codeworkx - galaxys2: don't hide focus modes
•codeworkx - galaxys2: fix permissions on exynos-mem
AOKP Project name: android_device_samsung_msm8960-common
•Steve Kondik - msm8960: Update msm_mdp header to match kernel
AOKP Project name: device_samsung_d2att
•xoomdev - Update hardware info for d2att
Project name: android-device-samsung-smdk4412-common
•codeworkx - smdk4412: set cityid parameter for t0lte camera hal
•Espen Fjellvær Olsen - Camera needs access to exynos-mem as well
•codeworkx - smdk4412: use sysfs for vsync notification
AOKP Project name: device_samsung_d2usc
•xoomdev - Update hardware info for d2usc
Project name: device_samsung_i9300
•codeworkx - i9300: blow headphones away
AOKP Project name: device_asus_tilapia
•aaronpoweruser - Add Apn file
•Stevespear426 - Fix build, remove some cm stuff
•Janson Kang - tilapia: enable Tethering & portable hotspot
•Brandon Bennett - tilapia: enable USB OTG storage
•Brandon Bennett - Add default APN for AT&T
•xoomdev - Add hardware info for tilapia
AOKP Project name: android_device_asus_grouper
•Janson Kang - Enable rndis support for USB Tethering
•David Thompson - grouper: enable USB OTG storage
•xoomdev - Update hardware info for grouper
AOKP Project name: pseudo_buildbot
•Gergely Szell (sethyx) - Adjust pseudo to the new build output
AOKP Project name: vendor_aokp
•KAsp3rd - Fix colorized output while building
•Stevespear426 - Manta: Toggles overlay
•Roman Birg - Revert "Nova Launcher 2.0"
•xoomdev - Remove prebuilt PC app, build OS version
•Johan - Nova Launcher 2.0
•PhantomGamers - README: Update branch to reflect mr1
•xoomdev - Add manta to menu, update overlay, update fingerprint to 4.2.1
•Roman Birg - fix md5 output on OS X
•Oliver Gjoneski - cm: apns-conf.xml: (eHRPD/LTE handoff) Change pdp type for default APNs
•xoomdev - Add d2att, d2tmo, d2usc, d2vzw
AOKP Project name: vendor_samsung
•codeworkx - smdk4412: cleanup
•codeworkx - smdk4412: update bt and wifi firmware
•codeworkx - smdk4412: add t0lte
Project name: buildscripts
•Bajee11 - Add N7000 to nightlies
AOKP Project name: packages_providers_DownloadProvider
•YULIANGMAX - Updated simplified Chinese translations
AOKP Project name: packages_input_LatinIME
•elektroschmock - Make keyboard hints a better visible
AOKP Project name: packages_apps_Camera
•kecinzer - Camera: Updated czech translation
•codeworkx - camera: extend supported exposure compensation range
•jt1134 - Camera: port additional settings from jellybean 4.1
•Danesh M - Camera : Powerkey shutter (2/2)
AOKP Project name: packages_apps_Settings
•xoomdev - DeviceInfo: Add chipset to supplement cpu display in device info
•kecinzer - Settings: Updated czech translation
•xoomdev - Add PerformanceControl Quick Link in Settings
AOKP Project name: packages_apps_Phone
AOKP Project name: packages_apps_Mms
•Gergely Szell (sethyx) - derp typo
•Tamás Tóth - Mms auto-retrieval (3/3): mms app
AOKP Project name: packages_apps_PackageInstaller
AOKP Project name: packages_apps_Contacts
•Gergely Szell (sethyx) - Add Call statistics to Contacts (Phone)
•pvolkov - Add Russian T9 Buttons-CM10.1
•Gergely Szell - Stop background Thread in Phone app
•Barami - Contacts: Fix dialpad image for korean. It's my mistake. One xhdpi image has not transparent background. Changed that image to transparent background, and permissions of image files.
AOKP Project name: packages_apps_PerformanceControl
•bmc08gt - PC: Remove app from app drawer
•xoomdev - Add Android.mk to enable building in the Android source tree.
AOKP Project name: packages_apps_ROMControl
•kecinzer - RC: Updated czech translation
•Bajee11 - Fix Statusbar Toggles for spanish users.
•Roman Birg - new bootanimation (2/2)
•Roman Birg - custom bootanimation improvements
•Zaphod - Alternate Signal Layout (2/2)
•kecinzer - ROMControl: Cleanup czech translation
•Dirk Rettschlag - Lockscreen: enable longpress on expand challenge handle (2/2)
•Dirk Rettschlag - Lockscreen: option to use carousel animation when switching widgets (2/2)
•Jubakuba - RomControl: NavBarColor (2/2)
•xoomdev - Clean up some leftover performance files and strings
•kecinzer - ROMControl: Updated czech translation
•Jubakuba - RomControl: Comment Back Lockscreen Rotation
•rdgate - Added Japanese translations
•KhasMek - Sound: cleanup
•task650 - Fix a couple spelling derps. Wether is whether now. Signed-off-by: task650
AOKP Project name: packages_apps_DeskClock
CyanogenMod Project name: android_hardware_qcom_audio-caf
•Steve Kondik - Revert "qcom_audio-caf: disable support for LPA playback on bluetooth."
•Shashi Kumar - audio/msm7630: Fix for volume change during voice call
•Vineela Tummalapalli - audio/msm8655: Fix for AAC recording failure.
•Vineela Tummalapalli - audio/8655: Enabling LPA playback by adding AudioSessionOutLPA class
•Kalyani polepeddy - Remove audio_poliy.conf from msm7630
•Arne Coucheron - audio/msm7x30: Support for Samsung audio devices
•Arne Coucheron - audio/msm7x30: Fix log tags and disable debug logging
•Arne Coucheron - audio/msm7x30: Fix build in CM
•Arne Coucheron - audio/msm7x30: Rename folder to CM naming standard
•Vineela Tummalapalli - msm7630 : Propagate the flag value to status
•Vineela Tummalapalli - audio/msm7630: Initial commit for MR1 Audio bringup.
•Subhash Chandra Bose Naripeddy - alsa_sound: Fix audio not routed from Speaker to HDMI device
•Subhash Chandra Bose Naripeddy - alsa_sound: Miscellaneous fixes BT and USB playback
•Haynes Mathew George - alsa_sound: Collection of fixes in HAL for EOS
•Phani Kumar Uppalapati - alsa_sound: Decrease the tunnel buffer size to 256Kbytes
•Mingming Yin - audio: add support for FM feature
•Vidyakumar Athota - alsa_sound: Fix for no audio in voice call over USB
•Vidyakumar Athota - alsa_sound:Fix for no audio while playback on USB headset
•Subhash Chandra Bose Naripeddy - alsa_sound: Add support for 8 channel for HDMI device
•Subhash Chandra Bose Naripeddy - alsa_sound: Miscellaneous fixes for LPA and Tunnel Mode playback
•Steve Kondik - Revert "alsa_sound: Fix for, "Music getting played after onpausetimeout""
•Steve Kondik - Revert "alsa_sound: Issue with seek and write"
•Shareef Ali - qcom_audio-caf: disable support for LPA playback on bluetooth.
•Mingming Yin - audio: Fix delay with first voice call and MT voice call
CyanogenMod Project name: android_hardware_qcom_display-caf
•Rudolf Tammekivi - hwcomposer: Use RGB_BORDERFILL only on MDP 4.2 and higher.
•Prabhanjan Kandula - liboverlay: Use camera heap for targets without mm heap.
•Prabhanjan Kandula - hwcomposer: 7x30: disable overlays for video playback
•Rudolf Tammekivi - libgralloc: Set alpha mode only if kernel allows.
AOKP Project name: android_hardware_qcom_power
•Gergely Szell (sethyx) - Change ALOGE to ALOGV (if touchboost socket is not available)
Project name: media
•Danny Baumann - Revert "mm-video:vidc: Add the handling of MPEG-2 extension and user data."
•Maheshwar Ajja - vidc: Align ion buffer length before allocating it
•Arne Coucheron - mm-video: Use CM standard qcom naming
•Maheshwar Ajja - mm-video:venc: Add required ION Heap ID for video encoder buffers
•Maheshwar Ajja - mm-core: initial video bring-up on 8x55 target
•Maheshwar Ajja - mm-video:vdec: Video decoder bring-up on 8x55 target
•Srivalli Oguri - Initial 8x55 mr1 bring up
•Rajeshwar Kurapaty - mm-video: Fix for debug log messages support
•Mohan Kumar Gubbihalli Lachma Naik - mm_video: vidc: Align input buffer size for vdec.
•Shobhit Pandey - mm-core: Add support for display aspect ratio info.
•Shobhit Pandey - mm-video: Add support for display aspect ratio info.
•Rajeshwar Kurapaty - mm-video: vidc: Add support for MPEG-2 sample aspect ratio.
•Deepak Verma - mm-video: vidc: Add PAR value extradata support for H264.
•Shobhit Pandey - mm-core: Add MPEG-2 extension and user data types.
•Rajeshwar Kurapaty - mm-video:vidc: Add the handling of MPEG-2 extension and user data.
CyanogenMod Project name: camera
•sakindia123 - use standard qcom naming for msm7x27a variants
Project name: omap4xxx
•Mykola Ostrovskyy - hwc: Support HDMI as primary display
•Dandawate Saket - hwc: Add support for FB scaling and cloning
Project name: android_hardware_samsung
•Andrew Dodd - gralloc: Remove hacks
AOKP Project name: android_build
•dhacker29 - Fix use of Custom releasetool
•KAsp3rd - Add some AOKP "flare" when flashing
•David Ferguson - build: work around missing readlink -f on Mac
•Chirayu Desai - envsetup: set OUT_DIR to an absolute path always
Project name: android_kernel_samsung_d2
•Steve Kondik - video: msm: Clean up a mismerge
•Stepan Moskovchenko - msm: cache_erp: Handle recoverable L1 errors
•Jin Hong - msm: socinfo: Add support for detecting Krait and Krait Pass 2
•Chiranjeevi Velempati - USB: gadget: Kconfig: Change Max VBUS power usage default value
•Sameer Thalappil - wcnss: Add interface to Reset wcnss
•Rajeshwar Kurapaty - msm: vidc: Add extra data bit masks for MPEG-2
•Anji Jonnala - msm: cpufreq: Implement suspend/resume for cpufreq driver
•Siddhartha Agrawal - msm_fb: display: Evenly balancing load on MDP ports
•Greg Kroah-Hartman - Linux 3.0.59
•Ian Abbott - staging: comedi: Kconfig: COMEDI_NI_AT_A2150 should select COMEDI_FC
•Ian Abbott - staging: comedi: don't hijack hardware device private data
•Daniel Vetter - Revert "drm/i915: no lvds quirk for Zotac ZDBOX SD ID12/ID13"
•Alexander Graf - KVM: PPC: 44x: fix DCR read/write
•Woodhouse, David - intel-iommu: Free old page tables before creating superpage
•Benjamin Marzinski - GFS2: Test bufdata with buffer locked and gfs2_log_lock held
•Sarah Sharp - xhci: Handle HS bulk/ctrl endpoints that don't NAK.
•Oliver Neukum - USB: hub: handle claim of enabled remote wakeup after reset
•Sarah Sharp - USB: Increase reset timeout.
•Sebastian Andrzej Siewior - usb: gadget: dummy: fix enumeration with g_multi
•Denis N Ladin - USB: cdc-acm: Add support for "PSC Scanning, Magellan 800i"
•Tomasz Mloduchowski - usb: ftdi_sio: Crucible Technologies COMET Caller ID - pid added
•Bjørn Mork - USB: option: add Telekom Speedstick LTE II
•Quentin.Li - USB: option: Add new MEDIATEK PID support
•Bjørn Mork - USB: option: blacklist network interface on ZTE MF880
•Dzianis Kahanovich - USB: option: add Nexpring NP10T terminal id
•Johannes Berg - mac80211: use del_timer_sync for final sta cleanup timer deletion
•Jerome Glisse - radeon/kms: force rn50 chip to always report connected on analog output
•Samuel Thibault - staging: speakup: avoid out-of-range access in synth_add()
•Nickolai Zeldovich - staging: speakup: avoid out-of-range access in synth_init()
•Larry Finger - staging: r8712u: Add new device ID
•Ian Abbott - staging: comedi: comedi_test: fix race when cancelling command
•Ian Abbott - staging: comedi: prevent auto-unconfig of manually configured devices
•Mike Dunn - ALSA: pxa27x: fix ac97 cold reset
•Mark Brown - ASoC: wm2000: Fix sense of speech clarity enable
•Eric Wong - epoll: prevent missed events on EPOLL_CTL_MOD
•Eric Dumazet - rtnetlink: fix rtnl_calcit() and rtnl_dump_ifinfo()
•Greg Rose - rtnetlink: Fix problem with buffer allocation
•Greg Rose - rtnetlink: Compute and store minimum ifinfo dump size
•Zhang Rui - ACPI : do not use Lid and Sleep button for S5 wakeup
•Andre Przywara - x86, amd: Disable way access filter on Piledriver CPUs
•David Rientjes - thp, memcg: split hugepage for memcg oom on cow
•Namjae Jeon - udf: don't increment lenExtents while writing to a hole
•Namjae Jeon - udf: fix memory leak while allocating blocks during write
•Ed Cashin - aoe: do not call bdi_init after blk_alloc_queue
•Theodore Ts'o - ext4: lock i_mutex when truncating orphan inodes
•Michael Tokarev - ext4: do not try to write superblock on ro remount w/o journal
•Jan Kara - jbd2: fix assertion failure in jbd2_journal_flush()
•Forrest Liu - ext4: fix extent tree corruption caused by hole punch
•Lothar Waßmann - video: mxsfb: fix crash when unblanking the display
•Malcolm Priestley - staging: vt6656: 64bit fixes: vCommandTimerWait change calculation of timer.
•Malcolm Priestley - staging: vt6656: 64bit fixes: key.c/h change unsigned long to u32
•Malcolm Priestley - staging: vt6656: 64 bit fixes: fix long warning messages.
•Malcolm Priestley - staging: vt6656: 64 bit fixes : correct all type sizes
•Malcolm Priestley - staging: vt6656: 64 bit fixes: use u32 for QWORD definition.
•Malcolm Priestley - staging: vt6656: [BUG] out of bound array reference in RFbSetPower.
•Alasdair G Kergon - dm ioctl: prevent unsafe change to dm_ioctl data_size
•Steven Rostedt - ring-buffer: Fix race between integrity check and readers
•Tatyana Nikolova - RDMA/nes: Fix for terminate timer crash
•Tatyana Nikolova - RDMA/nes: Fix for crash when registering zero length MR for CQ
•Paulo Zanoni - drm/i915: make the panel fitter work on pipes B and C on IVB
•Dan Williams - i2400m: add Intel 6150 device IDs
•Alexey Khoroshilov - jffs2: hold erase_completion_lock on exit
•Trond Myklebust - SUNRPC: Ensure that we free the rpc_task after cleanups are done
•Eugene Shatokhin - ext4: fix memory leak in ext4_xattr_set_acl()'s error path
•Charles Keepax - mfd: Only unregister platform devices allocated by the mfd core
•Yi Zou - target/tcm_fc: fix the lockdep warning due to inconsistent lock state
•Xiaotian Feng - libata: fix Null pointer dereference on disk error
•Aaron Lu - libata: set dma_mode to 0xff in reset
•Mikael Pettersson - sata_promise: fix hardreset lockdep error
•David Jeffery - SCSI: qla2xxx: Test and clear FCPORT_UPDATE_NEEDED atomically.
•Xi Wang - SCSI: mvsas: fix undefined bit shift
•Stephan Gatzka - firewire: net: Fix handling of fragmented multicast/broadcast packets.
•Gabor Juhos - ath9k: ar9003: fix OTP register offsets for AR9340
•Felix Fietkau - Revert "ath9k_hw: Update AR9003 high_power tx gain table"
•Laura Abbott - mm: use aligned zone start for pfn_to_bitidx calculation
•Jason Liu - mm: compaction: fix echo 1 > compact_memory return error issue
•Sebastian Ott - s390/cio: fix pgid reserved check
•Shan Hai - powerpc/vdso: Remove redundant locking in update_vsyscall_tz()
•Anton Blanchard - powerpc: Fix CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n build
•Greg Kroah-Hartman - Linux 3.0.58
•Alexander Stein - can: Do not call dev_put if restart timer is running upon close
•Michal Hocko - mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT
•Tony Prisk - drivers/rtc/rtc-vt8500.c: fix handling of data passed in struct rtc_time
•Tony Prisk - drivers/rtc/rtc-vt8500.c: correct handling of CR_24H bitfield
•Corey Minyard - CRIS: fix I/O macros
•Gustavo Padovan - Bluetooth: cancel power_on work when unregistering the device
•Marcos Chaparro - Bluetooth: ath3k: Add support for VAIO VPCEH [0489:e027]
•Andy Lutomirski - PCI: Reduce Ricoh 0xe822 SD card reader base clock frequency to 50MHz
•David Woodhouse - solos-pci: fix double-free of TX skb in DMA mode
•Al Viro - ARM: missing ->mmap_sem around find_vma() in swp_emulate.c
•Will Deacon - ARM: mm: use pteval_t to represent page protection values
•Eric Dumazet - tcp: RFC 5961 5.2 Blind Data Injection Attack Mitigation
•Eric Dumazet - tcp: tcp_replace_ts_recent() should not be called from tcp_validate_incoming()
•Eric Dumazet - tcp: refine SYN handling in tcp_validate_incoming
•Eric Dumazet - tcp: implement RFC 5961 4.2
•Eric Dumazet - tcp: implement RFC 5961 3.2
•Stefan Hasko - net: sched: integer overflow fix
•Dave Kleikamp - sparc: huge_ptep_set_* functions need to call set_huge_pte_at()
•Steven Rostedt - ftrace: Do not function trace inlined functions
•Tejun Heo - cgroup: remove incorrect dget/dput() pair in cgroup_create_dir()
•Russell Webb - xhci: Add Lynx Point LP to list of Intel switchable hosts
•Thomas Gleixner - genirq: Always force thread affinity
•Peter Popovec - Input: walkera0701 - fix crash on startup
•Xi Wang - nfs: fix null checking in nfs_get_option_str()
•J. Bruce Fields - nfsd4: fix oops on unusual readlike compound
•Trond Myklebust - NFS: Fix calls to drop_nlink()
•NeilBrown - NFS: avoid NULL dereference in nfs_destroy_server
•Rafael J. Wysocki - ACPI / scan: Do not use dummy HID for system bus ACPI nodes
•Sebastian Andrzej Siewior - usb: gadget: phonet: free requests in pn_bind()'s error path
•Christian Lamparter - p54usb: add USBIDs for two more p54usb devices
•Tomasz Guszkowski - p54usb: add USB ID for T-Com Sinus 154 data II
•Takashi Iwai - ALSA: usb-audio: Fix missing autopm for MIDI input
•Takashi Iwai - ALSA: usb-audio: Avoid autopm calls after disconnection
•Hugh Dickins - tmpfs mempolicy: fix /proc/mounts corrupting memory
•Christoffer Dall - mm: Fix PageHead when !CONFIG_PAGEFLAGS_EXTENDED
•Will Deacon - virtio: force vring descriptors to be allocated from lowmem
•Ondrej Zary - x86, 8042: Enable A20 using KBC to fix S3 resume on some MSI laptops
•Kees Cook - exec: do not leave bprm->interp on stack
•Alan Cox - pnpacpi: fix incorrect TEST_ALPHA() test
•Jay Purohit - usb/ipheth: Add iPhone 5 support
•Alexander Shiyan - irda: sir_dev: Fix copy/paste typo
•Alan Cox - ne2000: add the right platform device
•Tommi Rantala - sctp: fix -ENOMEM result with invalid user space pointer in sendto() syscall
•Tommi Rantala - sctp: fix memory leak in sctp_datamsg_from_user() when copy from user space fails
•nikolay@redhat.com - bonding: fix race condition in bonding_store_slaves_active
•Sarveshwar Bandi - bonding: Bonding driver does not consider the gso_max_size/gso_max_segs setting of slave devices.
•Lianwei Wang - cpufreq: interactive: fix race on governor start/stop
•Todd Poynor - cpufreq: interactive: fix deadlock on spinlock in timer
•Todd Poynor - cpufreq: interactive: don't handle transition notification if not enabled
Project name: android_kernel_samsung_smdk4412
•Curtis Menard - mdm: Update mdm
•Samsung OSRC - Sensorhub: Update sensors and firmware
•codeworkx - t0lte: add wake_peer and bcm header back
•codeworkx - t0lte: disable samsung mtp
•sbrissen - use VZW defconfig as common T0LTE cdma defconfig
•codeworkx - t0lte: support for galaxy note 2 lte
•Humberto Borba - configs: i9300, n7100, n80xx: enable uhid
•Vinicius Costa Gomes - HID: uhid: Fix sending events with invalid data
•Jiri Kosina - HID: uhid: silence gcc warning
•David Herrmann - HID: uhid: add example program
•David Herrmann - HID: uhid: add documentation
•David Herrmann - HID: uhid: implement feature requests
•David Herrmann - HID: uhid: forward raw output reports to user-space
•David Herrmann - HID: uhid: forward output request to user-space
•David Herrmann - HID: uhid: forward open/close events to user-space
•David Herrmann - HID: uhid: add UHID_START and UHID_STOP events
•David Herrmann - HID: uhid: forward hid report-descriptor to hid core
•David Herrmann - HID: uhid: allow feeding input data into uhid devices
•David Herrmann - HID: uhid: add UHID_CREATE and UHID_DESTROY events
•David Herrmann - HID: uhid: implement write() on uhid devices
•David Herrmann - HID: uhid: implement read() on uhid devices
•David Herrmann - HID: uhid: allow poll()'ing on uhid devices
•David Herrmann - HID: uhid: add internal message buffer
•David Herrmann - HID: uhid: introduce user-space I/O driver support for HID
Project name: android_kernel_samsung_t1
•Ankit Vani - i9100g: optimize touch input performance
•Ankit Vani - i9100g: Improve touchscreen controller performance on battery
Project name: android_kernel_samsung_smdk4210
•Andrew Dodd - Revert "mach-px: Remove odd ION contigheap #ifndef"
•Andrew Dodd - config: remove PMEM, reduce FIMC1 alloc
•R. Andrew Ohana - tabs: disable Sec_Fifo DAI
AOKP Project name: platform_manifest
•Gergely Szell (sethyx) - Add tilapia
•xoomdev - Track PerformanceControl repo
•Stevespear426 - Track AOKP Manta
•Gergely Szell (sethyx) - track hw_qcom_power
Reaktionen: MusicJunkie666 und Apathie
Einen halben Tag nachdem ich die vom 13. geflasht habe kommt ne neue... Eh klar :p
S2 - CM10.1 - Tapatalk 2
Ich kann mit der Nightly von gestern weder Bluetooth noch BT- oder WLAN- Tethering verwenden.
Hat noch jemand das Problem?
Edith sagt: Mit der vom 13. das selbe. Somit wieder auf CM10.1... Schade, weil AOKP hat mir echt gefallen.
Bluetooth geht bei mir auch nicht, ebenso werden bei mir nun keine Balken mehr beim Empfangs-Symbol dargestellt, obwohl ich Empfang habe.
Auch der RAM-Verbrauch im "letzte Apps"-Menü ist total falsch.
edit: Balken-Problem durch neuflashen des Modems gelöst.
Hm... Kann bittte wer (per PN oder hier im Thread) Bescheid sagen, wenn es ein Build gibt bei dem BT funktioniert?
Ich bin schon seit ICS- Zeiten AOKP- Fan, aber auf BT kann und will ich nicht verzichten.
Letzte Version hat ziemlich viele Probleme und Fehler auch was die Flüssigkeit angeht .
Speicher Option geht nicht
RAM zeigt falsche Werte .
Also was das Thema "Flüssigkeit" angeht, kann ich mich in Verbindung mit dem Dorimanx- oder auch Siyah-Kernel nicht beschweren.
Und, geht Bluetooth inzwischen?
Ich kann es nicht selbst ausprobieren, sorry.
Ne, geht (glaube ich) immer noch nicht. Bin u.a. deswegen nun zu RootBox gewechselt. Da geht alles und man hat noch mehr Optionen wie z.B. Lockscreen Targets.
Anscheinend ist ja seit heute der erste offizielle 4.2 Build fürs S2 draußen.
Wollte mir den Build auch gleich rauf flashen, hab aber noch ne Frage zur Installation.
Ich habe gerade CM10.1 (4.2.1) drauf, wenn ich mir AOKP rauf hauen will muss ich da auch einen Full Wipe machen? Wenn ja, würde es Probleme geben wenn ich ein BackUp mit Titanium/Carbon machen würde und ich mir dann die Apps wieder installiere?
MfG
Full Wipe ja.
Backup wenn du nur die User Apps sicherst und wiederherstellt sollte es keine Probleme geben.
Gesendet von meinem Nexus 7 mit Tapatalk 2
Reaktionen: PwN0GrPhy
Ist es eig. irgendwie möglich die Animationsgeschwindigkeiten zu verändern?
Funktioniert eigentlich hier mittlerweile alles?
Gröbere Bugs kann ich nicht finden. BT funktioniert jedenfalls, das war für mich das größte Problem. Nandroid-Backup machen ist nicht möglich, bricht beim Erstellen der MD5-Checksum ab.
Ich verwende die ROM jetzt als Daily.
Galaxy Tab 10.1 - Ganbarou based on CM10.1 - Tapatalk HD
Reaktionen: Olli von G
Mir gefällt die rom echt gut. Nutze die jetzt ca. 1 Monat. Einziger Bug den ich finden konnte ist die Bildschirmausrichtung. Nach 2, 3 Tagen geht die Automatik nicht mehr. Dann hilft nur ein Neustart. Ansonsten alles flüssig und eine gute Aukkulaufzeit habe ich auch.
Ps. Nutze das build vom 05.03. http://androtransfer.com/get.php?p=AOKP/i9100/aokp_i9100_jb-mr1_build-5.zip
ich habe mittlerweile glaube ich alles an ROMS durch und habe bis dato bis auf die GOA keine gefunden die mir gefiehl.Werde die mir dann am Wochenende mal auf mein S2 schmeißen und testen
Gibt inzwischen ein neues Build. http://androtransfer.com/get.php?p=AOKP/i9100/aokp_i9100_jb-mr1_build-6.zip
Werde das gleich mal flashen :)
Neue Versionen sind hier Releases | AOKP zu finden.
Update:
Läuft ganz gut, auf den ersten Blick. Gmail wollte nach dem Update bei mir nicht. Kann aber auch dadran liegen dass, ich vergessen habe die gapps zu flashen :) Gmail deinstallieren und installieren hat geholfen.
Achtung die Wecker sind ausgeschaltet nach dem Update.
Titel aktualisiert und TE angeschrieben, ob er den Thread noch führen möchte oder nicht.
Notfalls würde ich den Thread übernehmen.
S2 - AOKP 4.2 - Tapatalk 2
dj3d
karu2003
Pr0TuRk38
Pr0TuRk38
Pr0TuRk38
j1gga84
vonharold
vonharold
