beicuxhaven
Ehrenmitglied
- 10.437
...Eine ROM, die bisher hier total vernachlässigt wurde und nun in der Version 9 zur Verfügung steht.
- Basierend auf CM/AOKP 4.2.2 JDQ39
- Google Apps 4.2.2 sind enthalten
- Aroma Installer 2.56
Änderungen V9
- Device Setting
- X-TremE Control
einfach zu viele. Schaut es euch auf XDA an
- Kernels : CM - Dorimanx
- Mods : Default - Galaxy S3-4 - Xperia Z - AOSP
- Apps : 2 Musics - 4 Launchers - Camera Photosphere - Flash Player
- Update AOKP Source
- Update CM Source
- Fix Siyah Kernel bootloop NEED TO REMOVE. NO SUPPORT
- Fix Xperia Z Mod (Activate Audio Driver missing)
- Fix message on GS3-4 Mod
- Rebuild updater-script (V.5 I forgot
- Fully AOSP Mod Theme
- More Samsung Galaxy S4 theme (GS3-4)
- Fully revamped NavBar and Lockscreen UI in X-TremE Control
- Themeable lockscreen
- Scrollable toggles
- Option to daydream on wireless charger
- Volume adjust sound preference
- Superuser merge into settings (thanks to Koush)
- StatusBar hide toggle (Expanded Desktop)
- Sleep toggle
How to Flash ROM
1. Downloading X-TremE ROM
2. Move to Internal/External SD
3. Power off your phone and go to CWM Recovery
4. Wipe Data / Wipe Cache Partition / Wipe Dalvik Cache [HIGH RECOMMEND]
5. Select install zip from SD card and select ROM
6. Fix Permission [RECOMMEND]
7. Reboot your phone
How to use Xposed DPI-Per-App
1. Go to Settings > Xposed Installer and press Install/Update
2. Click Modules if you done with 1.
3. Tick Xposed App Settings
4. Reboot / Fast Boot 1 Time. Then, open Settings > DPI-Per-App and select app that you want to change DPI.
5. ON, Type DPI & Choose resolution. Then, save it. Done
X-TremE JB ROM V.9 Download (Goo.im) Download (Dev Host)
Änderungen V9
Main Change : - Build the new X-TremE and clean many crap files - Add new kernel! Based on TWRP! It's KangBang Kernel! (Thanks sakindia123) - Make it stable - Fix System Memory bug cause many bugs on V7-8 - Reduce some files size - New Dark AOKP (Testing on V.8 but now it's OK
) - Update AOKP/CM sources - Update Dorimanx & CM & Siyah kernel to latest version - Add Cell broadcasts - Temporary remove Multiuser because of some bugs
- Device Setting
- X-TremE Control
- X-TremE Theme
- X-TremE Updater
- CPU Clocking (Performance Control)
- Reduce framework-res & SystemUI size
- AD2P Support
- HSPA+ Support
- HDMI Support If anyone try and not working pls tell me
- Superuser Integrate in Settings
- CM File Manager
- build.prop Tweaks
- Audio Tweaks
- Video Tweaks
- Photo Tweaks
- X-TremE Updater
- AD2P Support
- HSPA+ Support
- CM File Manager
- build.prop Tweaks
- Audio Tweaks
- Video Tweaks
- Photo Tweaks
- Update CM Source
- Sleep toggle
How to Flash ROM
