Kamillo
Ich bin zu CM9 was mir nicht so gut gefallen hat wie Bezke und dann wieder auf CheckROM Rev 4 HD + Siyah Kernel 2.6.6
ALDeeN schrieb:Zitiere doch die Texteile, in denen du meinst, das all meine Fragen beantwortet werden?? ... finde nichts.
Wieso ist denn das Scrollen in jedem Browser so meeega langsam??? Und unealastisch?? Da bekommt man ja die Krise...
Masta_Gee81 schrieb:[ROM]{CWM}İCS REMİX ROM XXKP8 4.0.3 ALL FİXED resurrection hey guys this is bezke's ics 4.0.3 resurrection rom backup...
everythings works perfect i fixed these....
faceunlock,lock wallpaper ,phone ,ics calender ,ics email,replaced go sms pro , no fc anymore ,.AND MORE
İ changed some stock apps from cwm9 and another ics roms now very stable just try out !
whats in _ whats new
Features
lockscreen wallpaper fixed
rooted and superuser
youtube works
replaced gosms pro as stock sms app(because of fc s i cant fix it )
ics calender
ics email
sony scetch font
cm 9 launcher fixed
face unlock fixed works awesome
removed some broken apps
google apps
org ics gallery added
cwm manager
ics org calculator
ics org weather widget added
and more...
first official ice cream sandwich 4.0.3 on samsung galaxy s 2 demo - YouTube
Instructions: (backup old rom before install)
Download the cwm backup
Put it on your internal SD Card . example phone/internal sd/clockworkmode/backup ( NOT EXTERNAL SD CARD )
Enter Recovery
Wipe Everything
select restore and backup
Select restore from internal sd card ( NOT EXTERNAL SD CARD )
After installation reboot the device
Enjoy!
ATTENTİON :İF U DO FULL WİPE AFTER RESTORE THİS BACUP U LL LOSE FACE UNLOCK
enjoy...
CWM backup file no doubt its clean
RESSURECTİON cwm DOWNLOAD LİNK
and this apk fixes lockscreen wallpaper issue .. (just install like standart ipa)
wp fix apk DOWNLOAD LİNK
THANKS BEZKE SAMFİRMWARE AND CM9 YOU ARE THE BEST
Erstmal maddi behruhige dich bitte, dann les dir nochmal durch was er geschrieben hatte nachdem du die seite 7 erwähnt hast.madddi schrieb:Alter... Mein Beitrag mit der Nummer 65 auf Seite 7. Wenn du schon nicht in der Lage bist die Suchfunktion zu nutzen, mach wenigstens die Augen auf -.-
ALDeeN schrieb:Hi maddi,
also bis auf das mit dem Update habe ich auf Seite 7 nichts von dem gefunden, nach was ich gefragt habe, trotzdem thx![]()
Was ist denn eigentlich der Unterschied vom Browser und dem Browser ICS? Scrollt der auch so mega langsam bei euch??
madddi schrieb:
ALDeeN schrieb:Hab leider keine Uhr Widget, ist das normal? Wie ist das WLAN bei euch? Bei mir ist die Reichweite viel geringer als mit anderen Roms, kann das einer bestätigen? Akku ist auch eher schlecht. Ausserdem hängt sich das Rom alle 30 Minuten für 5-10 sec auf und friert ein, dann vibrierts und es geht wieder alles..
Kamillo schrieb:Passst keine Sorge.
Mal ne andere Frage, da ich immoment noch auf der Arbeit bin kann ich leider nicht die neue ROM austesten. Hat irgendwer schon die neue gefixte Version drauf und kann mir sagen ob es sich lohnt auf ICS zu wechseln oder es immer noch zu viele fehler und freezes gibt? Nach der Beschreibung her hört sich es sich eigentlich sehr interessant an. Bitte schreibt mal eure Erfahrungen damit. Danke!![]()
